Having difficulty trying to get my ESP32 to show up in the Integrations page. I’ve upload the .bin and the ESP32 is working per the yaml, but I can not get HA to find the device.
When I got into “Configuration -> Integration” I’ve tried entering the IP manually (both “192.168.100.156” and “test2.local”, I’ve deleted the node and uploaded again with a new name/config, still no dice. Been pulling my hair out for about 3 hours now trying to get this to work. Any assistance would be greatly appreciated!
esphome:
platform: ESP32
board: esp-wrover-kit
wifi:
ssid: "xxx"
password: "xxx"
manual_ip:
# Set this to the IP of the ESP
static_ip: 192.168.100.156
# Set this to the IP address of the router. Often ends with .1
gateway: 192.168.100.2
# The subnet of the network. 255.255.255.0 works for most home networks.
subnet: 255.255.255.0
# dns1: 192.168.100.101
ap:
ssid: "Test2 Fallback Hotspot"
password: "xxx"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: "xxx"
ota:
password: "xxx"
switch:
- platform: gpio
pin: 22
restore_mode: ALWAYS_ON
- platform: wifi_signal
name: "WiFi Signal Sensor"
update_interval: 60s
