ESPHome node not connecting to shelly 1PM Gen4 configured as range extender
Hey there,
I have an ESP8266 controlling my irrigation system with 3 zones. It has very poor wifi reception, so I added a shelly 1PM gen4 nearby and configured it to be a range extender (wifi is configured, signal weak but stable, ap with ssid and pw configured, option range extender enabled).
Somehow my ESPHome node does not connect to the shelly. It always connects to my IoT wifi (at about -90db), not the IoT-extender. Is there a configuration problem on my end? Can someone please help?
esphome:
  friendly_name: Bewässerung
esp8266:
  board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "XXXX"
ota:
  - platform: esphome
    password: "XXXX"
wifi:
  networks:
    - ssid: !secret wifi2_ssid
      password: !secret wifi2_password
      priority: 10
    - ssid: !secret wifi_ssid
  min_auth_mode: WPA2
  ap:
    ssid: "Bewasserung Fallback Hotspot"
    password: "XXXX"
captive_portal:
switch:
  - platform: gpio
    pin: D1
    icon: mdi:thermostat
  - platform: gpio
    pin: D2
  - platform: gpio
    pin: D5
[21:12:11.984][C][wifi:1526]: WiFi:
[21:12:11.984][C][wifi:1526]:   Local MAC: 44:17:93:0D:B5:49
[21:12:11.984][C][wifi:1526]:   Connected: YES
[21:12:11.984][C][wifi:1237]:   IP Address: 192.168.39.3
[21:12:12.003][C][wifi:1248]:   SSID: [redacted]
[21:12:12.003][C][wifi:1248]:   BSSID: [redacted]
[21:12:12.003][C][wifi:1248]:   Hostname: 'bewasserung'
[21:12:12.003][C][wifi:1248]:   Signal strength: -95 dB ▂▄▆█
[21:12:12.003][C][wifi:1248]:   Channel: 6
[21:12:12.003][C][wifi:1248]:   Subnet: 255.255.254.0
[21:12:12.003][C][wifi:1248]:   Gateway: 192.168.38.1
[21:12:12.003][C][wifi:1248]:   DNS1: 192.168.38.7
[21:12:12.003][C][wifi:1248]:   DNS2: 0.0.0.0
Regards,
Anduril
Could it be the minimal WiFi setup the Shelly is running? I notice that some embedded devices are very picky about what types of WiFi they choose to join.
Does your phone connect okay to the Shelly range extender network?
Since you have the captive portal fallback, can you try connecting the ESP to only the Shelly network, or use a spare 8266 for testing? If you have a spare one, try configuring it to connect only to Shelly, and then watch the serial logs in VERBOSE/Debug mode which will show all the steps of the WiFi connect.
