johnny-f
(yannis)
April 9, 2021, 3:19am
1
Hello i am new on Yaml.
I am trying to create a configuration based on nodemcu that will perform 3 diferent sequential actions.
So if binary sensor is clicked once action1 should be performed next time that will be clicked action2 will be performed and finally when clicked once more action 3 will be performed.
On next click then it should start again from action1.
Could you please assist with an example?
Hi there, you can try this method. First create a script like this and call it with condition in binary sensor.
binary_sensor:
- platform: gpio
pin:
number: D1
on_press:
- if:
condition:
- script.is_running: my_script
else:
- script.execute: my_script
script:
- id: my_script
then:
- switch.turn_on: my_switch1 // first action
- wait_until:
binary_sensor.is_on: sensor
- switch.turn_off: my_switch2 // second action
- wait_until:
- switch.turn_off: my_switch3 // third action
johnny-f
(yannis)
April 9, 2021, 8:17pm
3
Thank you very much. Is working flawlesly.
Bellow the production code:
esphome:
platform: ESP8266
board: nodemcuv2
# on_boot:
# priority: 550.0
# then:
# - switch.turn_off: Relay1
# - switch.turn_off: Relay2
# - switch.turn_off: Relay3
# - switch.turn_off: Relay4
web_server:
port: 80
wifi:
ssid: "ssid"
password: "password"
ap:
ssid: "Thermostat Fallback Hotspot"
password: "p5j1sLDQc65Q"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
switch:
- platform: gpio
pin: D1
restore_mode: ALWAYS_OFF
interlock: [Relay2]
interlock_wait_time: 2s
- platform: gpio
pin: D2
interlock: [Relay1]
- platform: gpio
pin: D3
- platform: gpio
pin: D5
- platform: gpio
pin: D6
- platform: gpio
pin: D7
binary_sensor:
- platform: gpio
pin:
number: D6
mode: INPUT_PULLUP
internal: true
filters:
- invert:
- delayed_on: 900ms
- delayed_off: 100ms
on_press:
- if:
condition:
else:
script:
- id: step1
then:
- switch.turn_on: Beeper
- delay: 500ms
- switch.turn_off: Beeper
- switch.turn_on: Relay1
- switch.turn_on: Relay3
- switch.turn_on: Relay4
- logger.log: "Single-Clicked"
- id: step2
then:
- delay: 500ms
- delay: 200ms
- delay: 500ms
- switch.turn_on: Relay2
- logger.log: "Double-Clicked"
- id: step3
then:
- delay: 10s
- delay: 10s
- logger.log: "Triple-Clicked"
- id: my_script
then:
- delay: 500ms
- wait_until:
- delay: 500ms
- delay: 200ms
- delay: 500ms
- wait_until:
- script.execute: step3
- script.wait: step3
johnny-f
(yannis)
April 10, 2021, 4:13pm
4
Hi going on step further i would like some help to modify my code in order to:
Run step1 then on binary sensor is on run step3 (shutdown) but while step 3 is running if binary sensor is on again to stop step3 and run step2 and then when binary sensor is on again run step3.
So :`
Step1
Step3 (that can be canceled)
Step2
Step3 (that can be calceled)
and then loop the above
switch:
- platform: gpio
pin: D1
interlock: [Relay2]
- platform: gpio
pin: D2
interlock: [Relay1]
- platform: gpio
pin: D3
- platform: gpio
pin: D5
- platform: gpio
pin: D6
- platform: gpio
pin: D7
binary_sensor:
- platform: gpio
pin:
number: D6
mode: INPUT_PULLUP
internal: true
filters:
- invert:
- delayed_on: 900ms
on_press:
- if:
condition:
else:
script:
- id: step1
then:
- delay: 500ms
- logger.log: "Slow Speed"
- id: step2
then:
- delay: 500ms
- delay: 200ms
- delay: 500ms
- logger.log: "Fast Speed"
- id: step3
then:
- delay: 10s
- delay: 10s
- logger.log: "ShutDown"
- id: my_script
then:
- script.execute: step1
- script.wait: step1
- wait_until:
- script.execute: step2
- script.wait: step2
- wait_until:
- script.stop: step3
Please try this.
- id: my_script
then:
- wait_until:
- wait_until:
- wait_until:
