connected to gpio27.
dallas:
pin:
number: 27
inverted: true
mode:
input: true
output: true
[20:24:31][C][dallas.sensor:075]: DallasComponent:
[20:24:31][C][dallas.sensor:076]: Pin: GPIO27
[20:24:31][C][dallas.sensor:077]: Update Interval: 60.0s
[20:24:31][W][dallas.sensor:080]: Found no sensors!
i just don’t understand.
my entire yaml. maybe i’m doing something terrible wrong. All the i2c devices are working. I’m just not being able to make a sensor work.
substitutions:
esphome_name: weather-station
friendly_name: "Weather Station"
esphome_comment: Weather Station
esphome_project_name: PJW.Weather_Station_ESP32
software_version: 2023 12 29 V01
esphome_project_version: Weather Station ESP32, $software_version
devicename: weather_station
upper_devicename: "Weather Station"
log_level: debug # Enable levels logging https://esphome.io/components/logger.html
# none, error, warn, info, debug (default), verbose, very_verbose
esphome:
platform: ESP32
board: nodemcu-32s
project:
version: $esphome_project_version
# on_boot:
# priority: -10
# then:
# - script.execute: flashing
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "${name} Fallback"
password: !secret fallback_hotspot_password
captive_portal:
ota:
password: !secret esphome_ota_password
api:
encryption:
key: !secret esphome_api_encrypt_key
reboot_timeout: 0s
web_server:
port: 80
sun:
latitude: !secret latitude
longitude: !secret longitude
time:
- platform: sntp
timezone: UTC-3
logger:
level: ${log_level}
logs:
text_sensor: WARN
i2c:
frequency: 100kHz
sda: GPIO26
scl: GPIO25
ads1115:
- address: 0x48
dallas:
pin:
number: 27
inverted: true
mode:
input: true
output: true
binary_sensor:
- platform: gpio
pin:
number: 13
mode:
input: true
pullup: true
# analog to digital 4 channels
- platform: ads1115
name: "${friendly_name} ADS1115-0"
multiplexer: 'A0_GND'
gain: 6.144
- platform: ads1115
name: "${friendly_name} ADS1115-1"
multiplexer: 'A1_GND'
gain: 6.144
- platform: ads1115
name: "${friendly_name} ADS1115-2"
multiplexer: 'A2_GND'
gain: 6.144
- platform: ads1115
name: "${friendly_name} ADS1115-3"
multiplexer: 'A3_GND'
gain: 6.144
# anemometer - wind speed detector - in VCC 10 to 14V, out 0 to 5V * 6 = meters / second , meters / second * 3.6 = km/h
- platform: ina226
address: 0x40
shunt_resistance: 0.1 ohm
current:
name: "${friendly_name} wind speed current"
power:
name: "${friendly_name} wind speed power"
bus_voltage:
name: "${friendly_name} wind speed voltage"
filters:
- calibrate_linear:
datapoints:
- 0.0 -> 0.0
- 5.0 -> 30.0
shunt_voltage:
name: "${friendly_name} wind speed shunt voltage"
max_current: 3.2A
update_interval: 5s
- platform: copy
name: '${friendly_name} wind speed (km/h)'
source_id: wind_speed_voltage
unit_of_measurement: 'km/h'
icon: 'mdi:weather-windy'
filters:
- multiply: 3.6
- platform: copy
name: '${friendly_name} wind speed average'
unit_of_measurement: 'm/s'
filters:
- throttle_average: 5s
- platform: copy
name: '${friendly_name} wind speed average (km/h)'
filters:
- multiply: 3.6
on_value:
lambda: |-
if (x < 1) {
id(wind_scale_code).publish_state("0");
id(wind_scale).publish_state("Calm");
} else if (x >= 1 && x < 6) {
id(wind_scale_code).publish_state("1");
id(wind_scale).publish_state("Light Air");
} else if (x >= 6 && x < 12) {
id(wind_scale_code).publish_state("2");
id(wind_scale).publish_state("Light Breeze");
} else if (x >= 12 && x < 20) {
id(wind_scale_code).publish_state("3");
id(wind_scale).publish_state("Gentle Breeze");
} else if (x >= 20 && x < 29) {
id(wind_scale_code).publish_state("4");
id(wind_scale).publish_state("Moderate Breeze");
} else if (x >= 29 && x < 39) {
id(wind_scale_code).publish_state("5");
id(wind_scale).publish_state("Fresh Breeze");
} else if (x >= 39 && x < 50) {
id(wind_scale_code).publish_state("6");
id(wind_scale).publish_state("Strong Breeze");
} else if (x >= 50 && x < 62) {
id(wind_scale_code).publish_state("7");
id(wind_scale).publish_state("Near Gale");
} else if (x >= 62 && x < 75) {
id(wind_scale_code).publish_state("8");
id(wind_scale).publish_state("Gale");
} else if (x >= 75 && x < 89) {
id(wind_scale_code).publish_state("9");
id(wind_scale).publish_state("Severe Gale");
} else if (x >= 89 && x < 103) {
id(wind_scale_code).publish_state("10");
id(wind_scale).publish_state("Storm");
} else if (x >= 103 && x < 118) {
id(wind_scale_code).publish_state("11");
id(wind_scale).publish_state("Violent Storm");
} else if (x >= 118) {
id(wind_scale_code).publish_state("12");
id(wind_scale).publish_state("Hurricane Force");
} else {
ESP_LOGD("main", "It shouldn't happen (wind_speed_kmh_avg: %f)", x);
# wind direction indicator
- platform: ina226
address: 0x41
current:
name: "${friendly_name} wind direction current"
power:
name: "${friendly_name} wind direction power"
bus_voltage:
name: "${friendly_name} wind direction voltage"
shunt_voltage:
name: "${friendly_name} wind direction shunt voltage"
max_current: 3.2A
update_interval: 5s
# wind direction sensor voltage decoding
- platform: copy
name: '${friendly_name} wind direction heading'
source_id: wind_direction_voltage
on_value_range:
- below: 0.70
then:
- text_sensor.template.publish:
state: "N"
- sensor.template.publish:
state: 0.0
- above: 0.70
below: 1.42
then:
state: "NE"
state: 45.0
- above: 1.42
below: 2.14
then:
state: "E"
state: 90.0
- above: 2.14
below: 2.84
then:
state: "SE"
state: 135.0
- above: 2.84
below: 3.56
then:
state: "S"
state: 180.0
- above: 3.56
below: 4.27
then:
state: "SW"
state: 225.0
- above: 4.27
below: 4.99
then:
state: "W"
state: 270.0
- above: 4.99
then:
state: "NW"
state: 315.0
name: "${friendly_name} wind heading"
unit_of_measurement: "°"
# rain volume - tippet bucket - reed switch (pulse)
- platform: pulse_counter
pin: # Don't forget to add a pulling resistor 10K, . 3V3 ---10 K----(gpio 38)-- reed swicth from tippet bucket--- GND
number: GPIO38
mode: INPUT
unit_of_measurement: 'mm'
name: "${friendly_name} rain gauge"
icon: 'mdi:weather-rainy'
internal: true
count_mode:
rising_edge: DISABLE
falling_edge: INCREMENT
internal_filter: 13us
update_interval: 60s
filters:
# Each 0.011" (0.2794mm) of rain causes one momentary contact closure
- multiply: 0.2794
accuracy_decimals: 4
- platform: integration
name: "${friendly_name} rainfall per min"
time_unit: min
sensor: rain_gauge
- platform: total_daily_energy
name: "${friendly_name} total daily rain"
power_id: rain_gauge
# x60 To convert to aggregated rain amount
filters:
- multiply: 60
# temparature and humidity
# dallas or dht
# temparature, pressure and humidity
- platform: bme280
address: 0x76
temperature:
name: "${friendly_name} temperature"
pressure:
name: "${friendly_name} pressure"
humidity:
name: "${friendly_name} relative humidity"
update_interval: 10s
lambda: |-
const float STANDARD_SEA_LEVEL_PRESSURE = 1013.25; //in hPa, see note
return ((id(bme280_temperature).state + 273.15) / 0.0065) *
(powf((STANDARD_SEA_LEVEL_PRESSURE / id(bme280_pressure).state), 0.190234) - 1); // in meter
update_interval: 15s
icon: 'mdi:signal'
unit_of_measurement: 'm'
- platform: absolute_humidity
name: "Absolute Humidity"
temperature: bme280_temperature
humidity: bme280_humidity
lambda: |-
return (243.5*(log(id(bme280_humidity).state/100)+((17.67*id(bme280_temperature).state)/
(243.5+id(bme280_temperature).state)))/(17.67-log(id(bme280_humidity).state/100)-
((17.67*id(bme280_temperature).state)/(243.5+id(bme280_temperature).state))));
unit_of_measurement: °C
icon: 'mdi:thermometer-alert'
# ambient light
- platform: tsl2561
address: 0x39
name: "${friendly_name} tsl 2561 ambient light"
is_cs_package: false
update_interval: 4s
integration_time: 14ms
gain: 1x
# UV and Ambient Light
- platform: ltr390
address: 0x53
uv_index:
name: "${friendly_name} ltr390 uv index"
uv:
name: "${friendly_name} ltr390 uvs"
filters:
lambda: |-
float wfac = 1.0; // wfac
float gain = 3.0; // gain
return ( ((id(ltr390_uvs).state * wfac) / 2300) * 4 * ( 18 / gain ));
# - multiply: 0.010434782608695652173913 # UVI = ( uv / 2300 * wfac ) * 4 * ( 18 / gain ); gain=3, wfac=1
# - sliding_window_moving_average:
# window_size: 15
# send_every: 1
light:
name: "${friendly_name} ltr390 light"
# filters:
# window_size: 12
# send_every: 6
ambient_light:
name: "${friendly_name} ltr390 ambient light"
resolution: 18
gain: X3
window_correction_factor: 1.0 # wfac
update_interval: 4s
text_sensor:
- platform: version # Expose ESPHome version as sensor.
name: $esphome_name ESPHome Version
hide_timestamp: false
- platform: wifi_info
ip_address:
ssid:
bssid:
name: "${friendly_name} wind cardinal direction"
name: '${friendly_name} Beaufort wind scale'
icon: 'mdi:tailwind'
update_interval: never
name: '${friendly_name} Beaufort wind scale code'
display:
- platform: ssd1306_i2c
model: "SSD1306 128x64"
address: 0x3C
lambda: |-
// Print the string "Weather Station" at [1,11]
//it.print(0, 10, id(roboto), "Weather Station");
if (id(bme280_temperature).has_state()) {
it.printf(0, 0, id(roboto), "%.1f°", id(bme280_temperature).state);
if (id(bme280_humidity).has_state()) {
it.printf(35, 0, id(roboto), "%.1f %%", id(bme280_humidity).state);
if (id(bme280_pressure).has_state()) {
it.printf(70, 0, id(roboto), "%.2f kpa", id(bme280_pressure).state);
if (id(wind_speed_voltage).has_state()) {
it.printf(0, 13, id(roboto), "%.2f V-1", id(wind_speed_voltage).state);
if (id(wind_direction_voltage).has_state()) {
it.printf(0, 25, id(roboto), "%.2f V-2", id(wind_direction_voltage).state);
it.printf(54, 25, id(roboto), "%.1f", id(wind_heading).state);
it.printf(90, 25, id(roboto), "%s", id(wind_dir_card).state.c_str());
if (id(wind_speed_kmh_avg).has_state()) {
it.printf(0, 38, id(roboto), "%.2f V-2", id(wind_speed_kmh_avg).state);
it.printf(54, 38, id(roboto), "%.1f", id(wind_scale_code).state);
it.printf(90, 38, id(roboto), "%s", id(wind_scale).state.c_str());
# if (id(dht_temperature).has_state()) {
# it.printf(0, 51, id(roboto), "%.1f°", id(dht_temperature).state);
# if (id(battery_voltage).has_state()) {
# it.printf(0, 47, id(roboto), "%.1f V", id(battery_voltage).state);
font:
- file: "fonts/Roboto-Regular.ttf"
# gfonts://family[@weight]
- file: "gfonts://Roboto"
- file:
type: gfonts
family: Roboto
weight: 900
