ESPHome not compiling YAML
I just installed ESPhome for some projects but can’t seem to compile any code. I am running Hassio on an RPi4, but any effort to compile code in ESPHome results in a blank screen. No error codes, no activity and blank logs when downloaded. Even just an new device with only a name will not compile. This is what I see after trying to compile a legacy file to flash using ESPHome flasher
ESPHome seems to be running just fine from the add-on logs. Tried this as a fresh installation of the ESPHome add-one and have entered SSL information in the configuration tab after failing to compile as is. Tried using both Brave browser and Chrome, using a remote connection via DuckDNS with HTTPS enabled.
Does it work locally (ie without a remote connection)
Yes, when logged in locally, it compiles just fine. Another system I installed using a mini-PC works fine remotely. Guess the CloudFlare on the mini PC works better than the DuckDNS in my RPi.
