so for some reason my esphome wont compile this is the error i get.
INFO Reading configuration /config/esphome/glovedryer.yaml… INFO Generating C++ source… INFO Compiling app… INFO Running: platformio run -d /config/esphome/glovedryer Processing glovedryer (board: d1_mini; framework: arduino; platform: [email protected]) -------------------------------------------------------------------------------- HARDWARE: ESP8266 80MHz, 80KB RAM, 4MB Flash PACKAGES: - framework-arduinoespressif8266 3.20704.0 (2.7.4) - tool-esptool 1.413.0 (4.13) - tool-esptoolpy 1.20800.0 (2.8.0) - toolchain-xtensa 2.40802.200502 (4.8.2) Looking for ESPAsyncWebServer-esphome library in registry Conflict: More than one library has been found by request {“name”: “ESPAsyncWebServer-esphome”, “requirements”: “1.2.7”}: ESPAsyncWebServer-esphome ========================= #ID: 12620 Asynchronous HTTP and WebSocket Server Library for ESP8266 and ESP32 Keywords: http, async, websocket, webserver Compatible frameworks: Arduino Compatible platforms: Espressif 8266, Espressif 32 Authors: ESPHome Team ESPAsyncWebServer-esphome ========================= #ID: 6758 Asynchronous HTTP and WebSocket Server Library for ESP8266 and ESP32 Keywords: http, async, websocket, webserver Compatible frameworks: Arduino Compatible platforms: Espressif 8266, Espressif 32 Authors: ESPHome Team LibraryManager: Installing id=12620 @ 1.2.7 Automatically chose the first available library (use --interactive
option to make a choice) UndefinedPackageVersion: Could not find a version that satisfies the requirement ‘1.2.7’ for your system ‘linux_armv7l’: File “/usr/local/lib/python3.6/dist-packages/platformio/builder/main.py”, line 168: env.SConscript("$BUILD_SCRIPT") File “/root/.platformio/packages/tool-scons/script/…/engine/SCons/Script/SConscript.py”, line 597: return _SConscript(self.fs, *files, **subst_kw) File “/root/.platformio/packages/tool-scons/script/…/engine/SCons/Script/SConscript.py”, line 286: exec(compile(scriptdata, scriptname, ‘exec’), call_stack[-1].globals) File “/root/.platformio/platforms/espressif8266/builder/main.py”, line 238: target_elf = env.BuildProgram() File “/root/.platformio/packages/tool-scons/script/…/engine/SCons/Environment.py”, line 219: return self.method(*nargs, **kwargs) File “/usr/local/lib/python3.6/dist-packages/platformio/builder/tools/platformio.py”, line 62: env.ProcessProjectDeps() File “/root/.platformio/packages/tool-scons/script/…/engine/SCons/Environment.py”, line 219: return self.method(*nargs, **kwargs) File “/usr/local/lib/python3.6/dist-packages/platformio/builder/tools/platformio.py”, line 131: project_lib_builder = env.ConfigureProjectLibBuilder() File “/root/.platformio/packages/tool-scons/script/…/engine/SCons/Environment.py”, line 219: return self.method(*nargs, **kwargs) File “/usr/local/lib/python3.6/dist-packages/platformio/builder/tools/piolib.py”, line 1036: project.install_dependencies() File “/usr/local/lib/python3.6/dist-packages/platformio/builder/tools/piolib.py”, line 868: lm.install(uri) File “/usr/local/lib/python3.6/dist-packages/platformio/managers/lib.py”, line 281: force=force, File “/usr/local/lib/python3.6/dist-packages/platformio/managers/package.py”, line 704: pkg_dir = self._install_from_piorepo(name, requirements) File “/usr/local/lib/python3.6/dist-packages/platformio/managers/lib.py”, line 119: requirements or “latest”, util.get_systype() ========================== [FAILED] Took 1.95 seconds ==========================
help_outline DOWNLOAD BINARY STOP
