I’ve been using a TTGO T5 2.9" v2.2 device with ESPHome, but I can’t get it to display values from HomeAssistant.
Any ideas?
It seems like this should be possible per the alarm example here:
Or the various folks using it here:
YAML:
esphome:
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
level: VERY_VERBOSE
logs:
api: VERY_VERBOSE
homeassistant: VERY_VERBOSE
api.service: VERY_VERBOSE
sensor: VERY_VERBOSE
scheduler: DEBUG
# Enable Home Assistant API
api:
encryption:
key: {REDACTED}
ota:
password: {REDACTED}
spi:
clk_pin: 18
mosi_pin: 23
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Epaper29 Fallback Hotspot"
captive_portal:
font:
# gfonts://family[@weight]
- file: "gfonts://Roboto"
time:
- platform: homeassistant
entity_id: sensor.sensi_09efda_current_temperature_2
entity_id: sensor.zigbee_deep_freeze_110fa523_temperature
text_sensor:
entity_id: cover.garage_door
entity_id: alarm_control_panel.abode_alarm
entity_id: alarm_control_panel.blink_home
#dimensions: 296px by 128px
display:
- platform: waveshare_epaper
cs_pin: 5
dc_pin: 19
busy_pin: 4
reset_pin: 12
model: 2.90in
full_update_every: 60
rotation: 270
lambda: |-
it.print(255,0,id(roboto10), "Testv20");
it.strftime(242, 115, id(roboto10), "%I:%M:%S%p", id(esptime).now());
if(id(abode_alarm).has_state()) {
it.printf(0, 0, id(roboto16), "Abode: %s",id(abode_alarm).state.c_str());
} else {
it.printf(0, 0, id(roboto16), "Abode: No Status");
it.printf(0, 20, id(roboto16), "Blink: %s",id(blink_status).state.c_str());
} else {
it.printf(0, 20, id(roboto16), "Blink: No Status");
it.printf(0, 40, id(roboto16), "Garage Door: %s",id(garage_door_status).state.c_str());
} else {
it.printf(0, 40, id(roboto16), "Garage Door: No Status");
it.printf(0, 60, id(roboto16), "Thermostat: %.1f°F",id(sensi_temp).state);
} else {
it.printf(0, 60, id(roboto16), "Thermostat: No Status");
it.printf(0, 80, id(roboto16), "Deep Freeze: %.1f°F",id(deepfreeze_temp).state);
} else {
it.printf(0, 80, id(roboto16), "Deep Freeze: No Status");
Logs:
INFO Reading configuration /config/esphome/epaper29.yaml...
INFO Detected timezone 'America/Chicago'
WARNING GPIO4 is a Strapping PIN and should be avoided.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO12 is a Strapping PIN and should be avoided.
INFO Starting log output from epaper29.local using esphome API
INFO Successfully connected to epaper29.local
[16:54:50][I][app:102]: ESPHome version 2022.6.2 compiled on Jul 17 2022, 16:49:05
[16:54:50][C][wifi:491]: WiFi:
[16:54:50][C][wifi:353]: Local MAC: 24:0A:C4:2F:98:9C
[16:54:50][C][wifi:354]: SSID: [redacted]
[16:54:50][C][wifi:355]: IP Address: {REDACTED}
[16:54:50][C][wifi:357]: BSSID: [redacted]
[16:54:50][C][wifi:358]: Hostname: 'epaper29'
[16:54:50][C][wifi:360]: Signal strength: -27 dB ▂▄▆█
[16:54:50][V][wifi:362]: Priority: -6.0
[16:54:50][C][wifi:364]: Channel: 6
[16:54:50][C][wifi:365]: Subnet: 255.255.255.0
[16:54:50][C][wifi:366]: Gateway: {REDACTED}
[16:54:50][C][wifi:367]: DNS1: {REDACTED}
[16:54:50][C][wifi:368]: DNS2: {REDACTED}
[16:54:50][C][logger:275]: Logger:
[16:54:50][C][logger:276]: Level: VERY_VERBOSE
[16:54:50][C][logger:277]: Log Baud Rate: 115200
[16:54:50][C][logger:278]: Hardware UART: UART0
[16:54:50][C][logger:280]: Level for 'api': VERY_VERBOSE
[16:54:50][C][logger:280]: Level for 'homeassistant': VERY_VERBOSE
[16:54:50][C][logger:280]: Level for 'api.service': VERY_VERBOSE
[16:54:50][C][logger:280]: Level for 'sensor': VERY_VERBOSE
[16:54:50][C][logger:280]: Level for 'scheduler': DEBUG
[16:54:50][C][spi:097]: SPI bus:
[16:54:50][C][spi:098]: CLK Pin: GPIO18
[16:54:50][C][spi:100]: MOSI Pin: GPIO23
[16:54:50][C][spi:102]: Using HW SPI: YES
[16:54:50][C][homeassistant.time:010]: Home Assistant Time:
[16:54:50][C][homeassistant.time:011]: Timezone: 'CST6CDT,M3.2.0,M11.1.0'
[16:54:50][C][waveshare_epaper:221]: Waveshare E-Paper
[16:54:50][C][waveshare_epaper:221]: Rotations: 270 °
[16:54:50][C][waveshare_epaper:221]: Dimensions: 296px x 128px
[16:54:50][C][waveshare_epaper:245]: Model: 2.9in
[16:54:50][C][waveshare_epaper:251]: Full Update Every: 60
[16:54:50][C][waveshare_epaper:252]: Reset Pin: GPIO12
[16:54:50][C][waveshare_epaper:253]: DC Pin: GPIO19
[16:54:50][C][waveshare_epaper:254]: Busy Pin: GPIO4
[16:54:50][C][waveshare_epaper:255]: Update Interval: 1.0s
[16:54:50][C][captive_portal:088]: Captive Portal:
[16:54:50][C][mdns:084]: mDNS:
[16:54:50][C][mdns:085]: Hostname: epaper29
[16:54:50][V][mdns:086]: Services:
[16:54:50][V][mdns:088]: - _esphomelib, _tcp, 6053
[16:54:50][V][mdns:090]: TXT: version = 2022.6.2
[16:54:50][V][mdns:090]: TXT: mac = 240ac42f989c
[16:54:50][V][mdns:090]: TXT: platform = ESP32
[16:54:50][V][mdns:090]: TXT: board = esp32dev
[16:54:50][C][ota:085]: Over-The-Air Updates:
[16:54:50][C][ota:086]: Address: epaper29.local:3232
[16:54:50][C][ota:089]: Using Password.
[16:54:50][C][api:138]: API Server:
[16:54:50][C][api:139]: Address: epaper29.local:6053
[16:54:50][C][api:141]: Using noise encryption: YES
[16:54:50][C][homeassistant.sensor:030]: Homeassistant Sensor 'sensi_temp'
[16:54:50][C][homeassistant.sensor:030]: State Class: ''
[16:54:50][C][homeassistant.sensor:030]: Unit of Measurement: ''
[16:54:50][C][homeassistant.sensor:030]: Accuracy Decimals: 1
[16:54:50][C][homeassistant.sensor:031]: Entity ID: 'sensor.sensi_09efda_current_temperature_2'
[16:54:50][C][homeassistant.sensor:030]: Homeassistant Sensor 'deepfreeze_temp'
[16:54:50][C][homeassistant.sensor:031]: Entity ID: 'sensor.zigbee_deep_freeze_110fa523_temperature'
[16:54:50][C][homeassistant.text_sensor:023]: Homeassistant Text Sensor 'garage_door_status'
[16:54:50][C][homeassistant.text_sensor:024]: Entity ID: 'cover.garage_door'
[16:54:50][C][homeassistant.text_sensor:023]: Homeassistant Text Sensor 'abode_alarm'
[16:54:50][C][homeassistant.text_sensor:024]: Entity ID: 'alarm_control_panel.abode_alarm'
[16:54:50][C][homeassistant.text_sensor:023]: Homeassistant Text Sensor 'blink_status'
[16:54:50][C][homeassistant.text_sensor:024]: Entity ID: 'alarm_control_panel.blink_home'
[16:54:52][V][component:199]: Component waveshare_epaper.display took a long time for an operation (0.67 s).
[16:54:52][V][component:200]: Components should block for at most 20-30ms.
[16:54:53][V][component:199]: Component waveshare_epaper.display took a long time for an operation (0.11 s).
[16:54:53][V][component:200]: Components should block for at most 20-30ms.
[16:55:05][VV][api.service:373]: on_ping_request: PingRequest {}
[16:55:05][VV][api.service:043]: send_ping_response: PingResponse {}
[16:55:20][VV][api.service:373]: on_ping_request: PingRequest {}
[16:55:20][VV][api.service:043]: send_ping_response: PingResponse {}
[16:55:35][VV][api.service:373]: on_ping_request: PingRequest {}
[16:55:35][VV][api.service:043]: send_ping_response: PingResponse {}
[16:55:50][VV][api.service:373]: on_ping_request: PingRequest {}
[16:55:50][VV][api.service:043]: send_ping_response: PingResponse {}
[16:55:52][V][component:199]: Component waveshare_epaper.display took a long time for an operation (0.67 s).
[16:55:52][V][component:200]: Components should block for at most 20-30ms.
[16:55:53][V][component:199]: Component waveshare_epaper.display took a long time for an operation (0.11 s).
[16:55:53][V][component:200]: Components should block for at most 20-30ms.
[16:56:05][VV][api.service:373]: on_ping_request: PingRequest {}
[16:56:05][VV][api.service:043]: send_ping_response: PingResponse {}
[16:56:20][VV][api.service:373]: on_ping_request: PingRequest {}
[16:56:20][VV][api.service:043]: send_ping_response: PingResponse {}
[16:56:35][VV][api.service:373]: on_ping_request: PingRequest {}
[16:56:35][VV][api.service:043]: send_ping_response: PingResponse {}
[16:56:50][VV][api.service:373]: on_ping_request: PingRequest {}
[16:56:50][VV][api.service:043]: send_ping_response: PingResponse {}
[16:56:52][V][component:199]: Component waveshare_epaper.display took a long time for an operation (0.67 s).
[16:56:52][V][component:200]: Components should block for at most 20-30ms.
[16:56:53][V][component:199]: Component waveshare_epaper.display took a long time for an operation (0.11 s).
[16:56:53][V][component:200]: Components should block for at most 20-30ms.
[16:57:05][VV][api.service:373]: on_ping_request: PingRequest {}
[16:57:05][VV][api.service:043]: send_ping_response: PingResponse {}
[16:57:21][VV][api.service:373]: on_ping_request: PingRequest {}
[16:57:21][VV][api.service:043]: send_ping_response: PingResponse {}
[16:57:36][VV][api.service:373]: on_ping_request: PingRequest {}
[16:57:36][VV][api.service:043]: send_ping_response: PingResponse {}
[16:57:46][VV][esp-idf:000]: I (476105) wpa: GTK 2 is already in use in entry 3, it may be an attack, ignore it.
[16:57:46][VV][esp-idf:000]: I (476116) wpa: GTK 2 is already in use in entry 3, it may be an attack, ignore it.
[16:57:51][VV][api.service:373]: on_ping_request: PingRequest {}
[16:57:51][VV][api.service:043]: send_ping_response: PingResponse {}
[16:57:52][V][component:199]: Component waveshare_epaper.display took a long time for an operation (0.67 s).
[16:57:52][V][component:200]: Components should block for at most 20-30ms.
[16:57:53][V][component:199]: Component waveshare_epaper.display took a long time for an operation (0.11 s).
[16:57:53][V][component:200]: Components should block for at most 20-30ms.
[16:58:06][VV][api.service:373]: on_ping_request: PingRequest {}
[16:58:06][VV][api.service:043]: send_ping_response: PingResponse {}
[16:58:21][VV][api.service:373]: on_ping_request: PingRequest {}
[16:58:21][VV][api.service:043]: send_ping_response: PingResponse {}
[16:58:36][VV][api.service:373]: on_ping_request: PingRequest {}
[16:58:36][VV][api.service:043]: send_ping_response: PingResponse {}
[16:58:51][VV][api.service:373]: on_ping_request: PingRequest {}
[16:58:51][VV][api.service:043]: send_ping_response: PingResponse {}
[16:58:52][V][component:199]: Component waveshare_epaper.display took a long time for an operation (0.67 s).
[16:58:52][V][component:200]: Components should block for at most 20-30ms.
[16:58:53][V][component:199]: Component waveshare_epaper.display took a long time for an operation (0.11 s).
[16:58:53][V][component:200]: Components should block for at most 20-30ms.
[16:59:06][VV][api.service:373]: on_ping_request: PingRequest {}
[16:59:06][VV][api.service:043]: send_ping_response: PingResponse {}
Picture of what it’s doing:
It does run fine and the display reloads, time runs fine too. It’s just not getting a state from any sensors on Home Assistant. Any help would be greatly appreciated! Thank you
