Recently got ESPHome flashed onto an LED bulb. It was working, but I wanted to avoid the ugly white color that flashes when it first turns on, so I was experimenting with the on_boot command. It was almost working but then I monkeyed with the priority setting, and now it no longer boots correctly (or connects to my network).
I’d rather not dink around with trying to reflash it via USB, but I will if I have to.
Is ESPHome supposed to set up a SSID if it comes across errors? Or is there another way to fix this?
Has anyone else experimented with the priority settings on this? What numbers work? (I think I set it too high; it was sort of working as 250.)
There must’ve been a problem flashing it early on over wifi, because I pumped the priority up to 801 and it still flashed properly, the bulb didn’t respond to the initial on_boot command, but it still wasn’t bricked.
The optimal setting I found is to set priority to 700. It goes bright white for less than a second then immediately transitions nicely to warm white.
Would be nice if there was a setting somewhere to set the initial brightness/color settings, instead of relying on the on_boot param. I haven’t found those in the docs, though.
