Hello all,
is there anyone who can help?
Error:
INFO ESPHome 2024.7.2
INFO Reading configuration /config/esphome/testesp.yaml…
Failed config
on_boot: [source /config/esphome/testesp.yaml:25]
Component not found: on_boot.
esphome:
friendly_name: TestESP
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "<my key>"
ota:
- platform: esphome
password: "<my pw>"
wifi:
ssid: !secret wifi_ssid
on_boot:
priority: 250
then:
- http_request.post:
url: https://api.pushover.net/1/messages.json
headers:
Content-Type: application/json
json: !lambda |-
return {
"token": "my-token",
"user": "my-user",
"message": "Device Booted",
"title": "ESPHome Alert"
Background Info:
I’m using an esp8266 as a battery powered sensor for a server room door. It gets power when the door is open and sends a pushmessage using pushover immediately with standard arduino code.
Now I wanted to connect it to HomeAssistant with ESPhome but I still want it to send the push message directly instead of sending it over homeassistant. So I thought it might work with the on_boot option.
