Managed to flash ESPHome onto a Brilliant smart downlight (20bux from Aldi) but I cant figure out how to get the CW/WW to work.
From the tasmota template GPIO5 is brightness and GPIO13 is between CC/WW.
I dont think the inbuilt CWWW light component works given color mixing is just on GPIO13 so I am not sure how to integrate this into the light output. Will this need a custom output?
output:
- platform: esp8266_pwm
pin: GPIO5
frequency: 1000 Hz
# Example usage in a light
light:
- platform: monochromatic
output: pwm_output
Its not pretty but given I wont need to adjust color temp. I just set up a second light instead of having a color temp slider and set it as internal for now. The other option I tried was to set it as RGB with R controlling brightness and G controlling temp.
Had a shot at setting up a custom light to make it neat but alas its too hard for now.
I managed to flash Tasmota onto brilliant devices (a plug and light bulbs and added a template for Brilliant Smart Wifi A60 globe White 20890. See blog post.
It might help with the color temp problem.
