ESPHome on Brilliant Smart WiFi A60 Globe White
I bought one of these globes recently and managed to successfully flash it (ESPHome) and control it (On/off and dimming) from Home Assistant. I thought I’d document my ESPHome config file here as I could not find it anywhere else and had to do a bit of trial and error with the GPIO pin allocation to make it work. SSID and PASSWORD redacted.
Cheers,
Paul
esphome:
  platform: ESP8266
  board: esp01_1m
wifi:
  ssid: "yyyyyyyyyyy"
  password: "xxxxxxxxxxxxxxxxxx"
  ap:
    ssid: "Brilliantwg1 Fallback Hotspot"
    password: "ov5gq1O8HE9n"
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
binary_sensor:
  - platform: status
light:
  - platform: monochromatic
    name: "Brilliant Smart White Globe"
    output: output_component1
    # Ensure the light turns on by default if the physical switch is actuated.
    restore_mode: ALWAYS_ON
output:
  - platform: esp8266_pwm
    pin: GPIO12
    #was GPIO13 (tried 14)
web_server:
  port: 80
Part No. 20890 from what I can tell.
I managed to flash Tasmota on it as well using Tuya convert. I wrote down all the steps in this post. Hope that helps.
The device template is there too
