ESPHome on ESP32 slow and sometimes misses commands
I’m using an ESP32 to control up to 4 fans through PWM. (All fans the same type, frequency is set in the configuration to 1Khz.)
I’m tapping power from the fans themselves to power the ESP32. The fans have a USB C cable to connect to a proprietary speed controller, but the pinouts have been documented (all that’s needed is V+, GND, and D+ lines on the USB connector). The V+ line is +10V. I use a regulator (LM7805) to provide a steady +5V to my ESP32.
Once the system starts up (I give it time to boot up), it can take 2-7 seconds for the ESP32 to respond to commands I send it from my browser, through Home Assistant. I’m using an oscilloscope to watch what’s going on with the PWM output and I find when I change the speed setting on my control page, the PWM square wave doesn’t change for 2-7 seconds. There are times I change the speed on the web page and it doesn’t seem to ever register on the oscilloscope and doesn’t show up on the terminal in the web page, either. (I have noticed this seems to happen a lot if I try to change the speed while it’s off, but has happened while the fan is turned on.)
Also, while I’m working on testing the system, I will leave the command ping <esp32_lan_address> running in my terminal on my desktop and there are times I will see the ESP32 unreachable by ping, but it’s still controlling the fans.
Is controlling 4 fans with PWM a bit much for the chip? (I had the problem with only 2 fans configured, as well.)
Esp32 is fine with as many PWM controls as you want.
What is your power supply for the setup? Can you try behavior when powering Esp32 from separate usb-power supply.
Also, what you have in log when Esp32 misbehaves?
Try to add web server and control fans directly on ESP device - see if it happens same slow as from HA. Had something similar when WiFi channel was overloaded - HA missed lot of sensor readings from ESP devices, OTA failed again & again.
The power supply takes a +10V line from the fans I’m controlling with PWM and I use this circuit:
7805-Voltage-Regulator-Circuit-Diagram
(I’ve seen that same circuit in several different places, but not on the original data sheet, so I figure someone working with it a lot came up with it and it’s been spread around.)
I have used a USB power supply and, if I recall, it was slow that way, too - but that’s a good point. I can’t remember for sure, so I need to pull a few wires and try it with a USB cable connected to a charger to see if that makes a difference. I’ve also rebuilt the circuit yesterday, just after I posted this. I had built it all on a breadboard one circuit at a time, like doing the voltage regulator, then adding the fan control circuit, then redoing that. I ended up with a lot of extra jumper wires, so I’m re-testing it to see if it’s behaving better now. With all the extra jumpers (because the jumper wires were not always long enough), I may have cleaned up something causing the mess.
I’m watching the console while using the controls on the web page (the one directly on the ESP32) and this is about what it looks like no matter what I’m doing - just reports on what I’m doing, no indications of delay or other issues being reported. There are times the log takes time to update. I’m not clear whether that’s due to the ESP32 not responding quickly or if it’s due to buffering of the console data from the chip to my computer.
I’m using the webpage generated by the ESP32 directly. I haven’t been accessing the controls from the HA webpage or app for this. I have as many devices as I can on ethernet because of issues like a concern that wifi could overload. But, as you know, a lot of home automation controls and the ESP32 can’t do a hard wired connection. (I might run another CAT6 cable if it were easy to use some kind of adaptor that I could use for both power and ethernet and plugged into the USB connector on the Devkit C)
I haven’t seen your circuit, not your code, neither your log, so it’s hard to suggest something.
To exclude powering issues, wiring mistakes or interferences from fan, I would power Esp from USB charger and disconnect the fans from board. Observe if it’s still lagging.
So, at least, I can star with a baseline that delays in responding to a signal from HA are not normal?
I can only tell that those delays between your browser and Esphome device are not normal. Can be hardware issue, Wifi, or your code.
I know it’s not my code! There’s no code of mine in there! (Well, a configuration file, but others are using that with no complaint.) I’m betting it has something to do with my wiring, since that’s my least experienced area in this project. But knowing it’s not normal helps a lot.
Texas Instruments data sheet is here https://www.ti.com/lit/ds/symlink/lm340.pdf
I was wondering if you’d found the cause or a solution to this? I’m having the same problem with just one fan. Everything seems to be working but there are delays loading the dashboard and sending commands.
Curious to know if you found the problem?
Interesting that it’s not just me, so, for me, that’s good to know. It doesn’t help you or me much, but at least we know it’s not us. (Well, likely not us!) I would have thought it was just that the fans took time to speed up (inertia and friction), but since the o-scope shows me when the PWM signal changes, and I know it takes time for it to respond to the command, I can be sure there’s a lag.
I haven’t had time to spend on it and it seems like a diminishing returns kind of situation. It works. I’d like to see it respond in a more timely way, but it would take a lot of work to track this down. The easy part would be to track and see if a log entry appears in the debug window immediately after changing the speed on the ESPHome interface. But, from there, trying to track it down will take hours and hours and I don’t have the time to spend on that.
this is probably totally unrelated but I’m also seeing slowdown on esphome-enabled devices in the last few months…and nothing has seemed to fix it…
in my examples specifically, I have two Shelly 1’s that are flashed with ESPhome…they are set as detatched light switches and until a few weeks ago every on or off from the light switches, via NodeRed, was communicated and the attached action was implemented pretty much instantly
There is a similar setup in two different rooms…one feeds a wifi light fitting, the other feeds a group of zigbee bulbs…but both have momentarily delays randomly which can last anywhere from half a second to 2-3 seconds but occasionally longer.
I am getting the same delays when two WLED ESP controllers are turning on 2 identical sets of LED strips…they are controlled in turn by ESPhome WLED controllers which in turn are controlled by esphome MMwave sensors…so they sense presence, they turn on the lights, presence is clear, lights turn off…again these were all working perfectly a few months ago but somewhere along the line a delay has entered the system.
For clarity, IF I control said lights themselves directly via their individual entities, they have zero delay…
Part of me thought Node Red was the culprit, but I set up some basic HA automations to perform the same steps, and the delays are identical.
So part of me is thinking ESPhome is somehow the culprit here and a few other posts I am finding on a search come up with similar results
Whilst I appreciate wifi can be an issue here, the esp home devices are static, and wifi hasn’t been adapted in any way…all signals are strong an no other devices have issues…signals appear to be strong as reported by the ESP devices themselves too
