I know I’m asking a lot of ESPhome with this conditional automation.
- If it is December, turn on the RGB “XMAS” light effect.
- If it is January, turn on the RGB “Random_60_15” light effect.
- If it is February, turn on the RGB “Flicker” light effect with pink.
I can set the colors using on_time
and leave the effect as flicker, but I’m trying to create a conditional that evaluates the month on sunset and sets the light effect based on the month.
The problem is that on_sunset
doesn’t accept time conditionals as far as I can tell, so I’ve fallen back to lambdas.
As I read the documentation, yaml only allows for nested if statements. So I have to use this cascade of if statements. Am I understanding the limitations of ESPhome correctly. I’ve tried most of the other possible configurations short of just coding it all in C++ as a single lambda (possibly in a switch), which is probably about as hard as what I’m doing here once I call setting all the RGB light variables.
sun:
latitude: 00.00
longitude: 00.00
on_sunset:
# Original
# - then:
# - light.turn_on:
# id: h801_2_rgb
#just for december effect: "XMAS"
# New Code to apply the light effect at sunset when it turns on.
then:
if:
condition:
lambda: |-
auto time = id(sntp_time).now();
return time.month == 12;
then:
- light.turn_on:
effect: "XMAS"
else:
if:
condition:
lambda: |-
return time.month == 1;
then:
- light.turn_on:
effect: "Random_60_15"
else:
if:
condition:
lambda: |-
return time.month == 2;
then:
- light.turn_on:
effect: 'Flicker'
red: 100%
green: 0%
blue: 75%
brightness: 0
# - logger.log: "Valentines Flicker Activated"
