EspHome on T-Display S3 Pro
Does any one have a working yaml file to display text on a LilyGo T-Display S3 Pro?
I believe the main issue that I am having is the correct gpio pin assignments, I have tried using the pin numbers provided by the LilyGo store but no luck. Code that I am trying to display works on the Amoled and a few other displays but not the S3 pro.
# Uses the following devices
# - Lilygo T=Display s3-Pro
# - Blood_Sugar sensor from Home Assistant NightScout Integration
# touchscreen:
  # platform: CST226
# display:
  # - platform: ili9xxx
    # model: ILI9341
substitutions:
  disp_name: CGM Display
esphome:
  friendly_name: cgm-t-display-s3-pro
esp32:
  board: esp32-s3-devkitc-1
  framework:
    type: arduino
logger:
api:
ota:
web_server:
  port: 80
wifi:
  ssid: !secret wifi_ssid
  manual_ip:
    static_ip: 192.168.0.193
    gateway: 192.168.0.1
    subnet: 255.255.255.0
  ap:
    ssid: "CGM Display Fallback"
spi:
  miso_pin: 8
  mosi_pin: 17
  clk_pin: 18
color:
  - id: my_black
    red: 0%
    green: 0%
    blue: 0%
  - id: my_red
    hex: fc0000
  - id: my_green
    hex: 00fc4c
  - id: my_yellow
    hex: e0e637
  - id: my_orange
    hex: ff7728
  - id: my_white
    hex: ffffff
font:
  - file: 'fonts/arialbd.ttf'
  - file: 'fonts/roboto.ttf'
display:
  - platform: ili9xxx
    model: ili9341
    color_order: rgb
    data_rate: 80MHz
    cs_pin: 6
    reset_pin: 47
    dc_pin:  9
    dimensions:
      height: 480
      width: 222
      offset_height: 40
      offset_width: 52
    invert_colors: false
    lambda: |-
      it.fill(id(my_red));
      it.strftime(10, 111, id(font2), id(my_white), TextAlign::BOTTOM_LEFT, "%I : %M %p", id(esptime).now());
switch:
  - platform: restart
time:
  - platform: homeassistant
output:
  - platform: ledc
    pin: 48
light:
  - platform: monochromatic
    output: gpio_48_backlight_pwm
    name: "Display Backlight"
    restore_mode: ALWAYS_ON
# sensor:
  # - platform: homeassistant
    # id: blood_sugar
    # entity_id: sensor.blood_sugar
    # accuracy_decimals: 0
    # unit_of_measurement: mg/dL
  # - platform: wifi_signal
    # name: ${disp_name} WiFi Status
    # update_interval: 10s
captive_portal:
Thanks for any help or suggestions
Have you tried model ST7796?
display:
  - platform: ili9xxx
    model: st7796
st7796 gave slight control of backlight but nothing else, will try more when I get back from the cancer doctor. Thanks
I spent way too much figuring this out, had to hammer it into submission, lol… For the life of me can’t figure out the rest, especially the shared i2c bus with the camera. Undocumented GPIO 39 that I found on ini file at the github repo tip me off but was out of gut feeling, offset were hell to get the right as x y seemed inverted from main website mapping. Hope helps others to figure out the rest. Cheers.
esphome:
  friendly_name: T-Display-S3 Pro
  platformio_options:
    build_flags:
      - '-DBOARD_HAS_PSRAM'
      - '-DUSING_DISPLAY_PRO_V1'                  ##https://github.com/Xinyuan-LilyGO/T-Display-S3-Pro/blob/9ec738e7be324d9897d71498f760474e2dd15669/platformio.ini
      - '-DARDUINO_ESP32S3_DEV'
      # - '-DARDUINO_USB_MODE=1'
      - '-DARDUINO_RUNNING_CORE=1'
      - '-DARDUINO_EVENT_RUNNING_CORE=1'
      # - '-UARDUINO_USB_CDC_ON_BOOT'              ## Enable UARDUINO_USB_CDC_ON_BOOT will turn off printing and will not block when using the battery.
      # - '-DCORE_DEBUG_LEVEL=1'
    board_build.flash_mode: qio
    board_build.f_flash: '80000000L'
    board_build.partitions: 'default_16MB.csv' ##https://github.com/Xinyuan-LilyGO/T-Display-S3-Pro/blob/9ec738e7be324d9897d71498f760474e2dd15669/board/t-display-s3-pro.json
    # board_build.partitions: 'huge_app.csv' ##https://github.com/Xinyuan-LilyGO/LilyGO-T-ETH-Series/blob/077f8e89705f89ab438918c78d2e22b570c186f5/platformio.ini
    board_build.arduino.memory_type: 'qio_opi'
    board_upload.maximum_size: '16777216'
    board_upload.maximum_ram_size: '327680'
    board_upload.speed: '921600'
esp32:
  board: esp32s3box
  # variant: ESP32S3
  framework:
    type: arduino
    version: latest
    platform_version: 6.7.0
  flash_size: 16MB
external_components:
#   - source: github://latonita/esphome-ltr303
#     components: [ ltr_als_ps ]
psram:
  speed: 80MHz
# i2c:
#    - id: bus_a
#      sda: 5
#      scl: 6
#      scan: False
    #  frequency: 100kHz
logger:
  baud_rate: 0
  level: DEBUG
  logs:
    # esp32_ble: DEBUG
    # esp32_ble_tracker: DEBUG
    # ble_dist: INFO
    # sensor: INFO
    # vl53l0x: NONE
    light: INFO
    ltr_als_ps: INFO
    # ledc.output: INFO
    # component: INFO
    # ili9xxx: WARN
    # tt21100: WARN
    # tdisplays3: DEBUG
    # touchscreen: WARN
    # wifi: DEBUG
    # es8311: WARN
    # i2s_audio: DEBUG
    # voice_assistant: DEBUG
    # es7210: WARN
    # graph: ERROR
api:
  encryption:
    key: !secret api
  # on_client_disconnected:
  #   - switch.turn_off: ble_active_scan
ota:
  - platform: esphome
    # safe_mode: true
    password: !secret ota
wifi:
  domain: !secret domain
  fast_connect: on
  #power_save_mode: none
time:
button:
  - platform: restart
    entity_category: diagnostic
    icon: mdi:restart
  - platform: safe_mode
    name: 'MCU Restart in Safe Mode'
  - platform: factory_reset
    disabled_by_default: True
    name: 'MCU Factory Reset'
output:
  - platform: ledc
    pin: 48
    channel: 1
    frequency: 20000
  - platform: ledc
    pin: 38
    channel: 2
light:
    output: gpio_38_cam_light_pwm
    restore_mode: ALWAYS_OFF
binary_sensor:
# these are the hardware "key" buttons at the right side
  - platform: gpio
    pin:
      number: 12
      inverted: true
    # internal: True
  - platform: gpio
    pin:
      number: 16
      inverted: true
    # internal: True
    # filters:
    # - invert:
    # on_press:
    #   then:
    #   - display.page.show_next: disp
    #   - component.update: disp
# sensor:
#   - platform: ltr_als_ps
#     address: 0x23
#     auto_mode: true
#     type: ALS_PS   # ALS, PS, ALS_PS
# # gain and time ignored in auto mode
#     gain: 2x
#     integration_time: 100 ms
#     glass_attenuation_factor: 1.0
#     ambient_light: Ambient light
# # Following sensors are not really of a lot of use, to be honest :)
#     # full_spectrum_counts: Full spectrum counts
#     # infrared_counts: Infrared counts
#     # actual_gain: Actual gain
#     # actual_integration_time: Actual integration time
# # proximity section
#     ps_cooldown: 1 s
#     ps_high_threshold: 300          #590
#     ps_low_threshold: 10
#     on_ps_high_threshold:
#       then:
#         # - logger.log: "Proximity high threshold"
#         - binary_sensor.template.publish:
#               id: proximity
#               state: true    #!lambda 'return id(some_sensor).state > 30;'
#     on_ps_low_threshold:
#       then:
#         # - logger.log: "Proximity low threshold"
#               id: proximity
#               state: false    #!lambda 'return id(some_sensor).state > 30;'
#     # ps_counts: Proximity counts
# binary_sensor:
#   - platform: template
#     name: "Proximity"
#     id: proximity
#     device_class: motion
#     publish_initial_state: true
    # lambda: |-
    #   if (id(ultrasonic_sensor1).state > 30) {
    #     return true;
    #   } else {
    #     return false;
    # filters:
    #   - delayed_off: 2s
    # on_press:
    #   then:
    #     # - delay: 3s
    #     # - binary_sensor.template.publish:
    #     #       id: proximity
    #     #       state: false    #!lambda 'return id(some_sensor).state > 30;'
    #     - delay: 50ms
    #     - light.turn_on:
    #         id: back_light
    # on_release:
    #   then:
    #     - delay: 50ms
    #     - light.turn_off:
    #         id: back_light
    # filters:
    #   - delayed_off: 30s
# esp32_camera_web_server:
#   - port: 8080
#     mode: stream
#   - port: 8081
#     mode: snapshot
# esp32_camera:
#   name: "CAM"
#   id: cam
#   #internal: False
#   external_clock:
#     pin: 11
#     frequency: 20000000
#   i2c_pins:
#     sda: 5
#     scl: 6
#   data_pins: [45,41,40,42,1,3,10,4]
#   vsync_pin: 7
#   href_pin: 15
#   pixel_clock_pin: 2
#   # power_down_pin: 46
#   reset_pin: 46
#   #resolution: 800x600
#   resolution: UXGA
#   jpeg_quality: 11  # max. 63
#   max_framerate: 13.0fps
#   idle_framerate: 0.3fps
#   vertical_flip: False
#   horizontal_mirror: True
#   brightness: 0 # -2 to 2
#   contrast: 1 # -2 to 2
#   # special_effect: none
#   # special_effect: grayscale
#   # exposure settings
#   # aec_mode: auto
#   # aec2: false
#   # ae_level: 0
#   # aec_value: 300
#   # gain settings
#   # agc_mode: auto
#   # agc_gain_ceiling: 64x
#   # agc_value: 0
#   # white balance setting
#   wb_mode: OFFICE
spi:
  mosi_pin: 17
  clk_pin: 18
  # miso_pin: 8
  # interface: hardware
# // SD , TFT share SPI Bus
# #define BOARD_SPI_MISO      8
# #define BOARD_SPI_MOSI      17
# #define BOARD_SPI_SCK       18
# #define BOARD_TFT_CS        39
# #define BOARD_TFT_RST       47
# #define BOARD_TFT_DC        9
# #define BOARD_TFT_BL        48
# #define BOARD_SD_CS         14
# #define BOARD_SENSOR_IRQ    21
# #define BOARD_TOUCH_RST     13
# #define BOARD_TOUCH_IRQ     7
# #define BOARD_TFT_WIDTH     222
# #define BOARD_TFT_HEIHT     480
display:
  - platform: ili9xxx
    # update_interval: 2s
    model: ST7796
    dimensions:
      height: 480
      width: 222
    #   height: 480
    #   width: 222
      offset_height: 0
      offset_width: 49
    # transform:
    #   swap_xy: true
    #   mirror_x: true             #####90 degrees - use swap_xy with mirror_x - 180 degrees - use mirror_x with mirror_y - 270 degrees - use swap_xy with mirror_y With 90 and 270 rotations you will also need to swap the height and width in dimensions.
      # mirror_y: true
    color_order: bgr
    data_rate: 80MHz
    cs_pin: 39  ### https://github.com/Xinyuan-LilyGO/T-Display-S3-Pro/blob/9ec738e7be324d9897d71498f760474e2dd15669/examples/UnitTest/utilities.h
    # cs_pin: 8
    dc_pin: 9
    reset_pin: 47
    # spi_mode: MODE3
    invert_colors: true
    pages:
      - id: weather
        lambda: |-
          // clear screen
          it.clear();
          // draw the time up top
          std::string time = id(time_ha).now().strftime("%I%M");
          //std::string dayofweek = id(time_ha).now().strftime("%a, %b %e");
          it.print(0, 0, id(roboto), id(color_red), TextAlign::TOP_LEFT, time.c_str());
          it.print(60, 60, id(roboto), id(color_green), TextAlign::TOP_LEFT, time.c_str());
          it.print(0, 450, id(roboto), id(color_blue), TextAlign::TOP_LEFT, time.c_str());
          //it.print(1, 0, id(font1), id(color_white), TextAlign::BOTTOM_CENTER, dayofweek.c_str());
font:
  - file: "gfonts://Roboto"
color:
  - id: color_light_grey
    hex: BBBBBB
  - id: color_dark_grey
    hex: 5F5F5F
  - id: color_white
    hex: FFFFFF
  - id: color_red
    hex: FF0000
  - id: color_green
    hex: 14FF00
  - id: color_yellow
    hex: FFFF00
  - id: color_blue
    hex: 0000FF
# font:
#   - file: "gfonts://Roboto"
#     id: roboto
#     size: 30
# ##### https://github.com/Xinyuan-LilyGO/T-Display-S3-Pro/blob/9ec738e7be324d9897d71498f760474e2dd15669/examples/UnitTest/utilities.h
#  * @file      utilities.h
#  * @author    Lewis He ([email protected])
#  * @license   MIT
#  * @copyright Copyright (c) 2023  Shenzhen Xin Yuan Electronic Technology Co., Ltd
#  * @date      2023-09-25
# #pragma once
# // https://www.lilygo.cc/products/t-display-s3-pro
# // T-Dispaly-Pro pinmap
# //! Using T-Display-Pro V1.0 , uncomment use V1.1 ,
# //! The difference between V1.0 and V1.1 is the backlight driver.
# // #define USING_DISPLAY_PRO_V1
# // LTR553 , TOUCH , SY6970 , Camera share I2C Bus
# #define BOARD_I2C_SDA       5
# #define BOARD_I2C_SCL       6
# // BUTTON Pinmap
# #define BOARD_USER_BUTTON   {0 /*btn1*/,12/*btn2*/,16/*btn3*/}
# #define BOARD_USER_BTN_NUM  3
# // Camera Shield pinmap
# #define CAMERA_PIN_RESET    (-1)
# #define CAMERA_PIN_SIOD     BOARD_I2C_SDA
# #define CAMERA_PIN_SIOC     BOARD_I2C_SCL
# #define CAMERA_PIN_VSYNC    (7)
# #define CAMERA_PIN_PWDN     (46)
# #define CAMERA_PIN_HREF     (15)
# #define CAMERA_PIN_Y9       (4)
# #define CAMERA_PIN_XCLK     (11)
# #define CAMERA_PIN_Y8       (10)
# #define CAMERA_PIN_Y7       (3)
# #define CAMERA_PIN_Y6       (1)
# #define CAMERA_PIN_Y5       (42)
# #define CAMERA_PIN_Y4       (40)
# #define CAMERA_PIN_Y3       (41)
# #define CAMERA_PIN_Y2       (45)
# #define CAMERA_PIN_PCLK     (2)
# #define CAMERA_WHITH_LED    (38)
# #define XCLK_FREQ_HZ        20000000
# #define CAMERA_LEC_CH               0
# #define LEDC_TFT_CH                 1
# #define LEDC_WHITE_CH               2
# // #define LEDC_IR_CH          1
# // #define CAMERA_IR_LED       (46)
# #ifdef USING_DISPLAY_PRO_V1
# #define BRIGHTNESS_MAX_LEVEL        255
# #else
# #define BRIGHTNESS_MAX_LEVEL        16
# #endif
Just discovered and wanted to share, got the touch enabled, woot:
esphome:
  platformio_options:
    build_flags:
esp32:
  board: esp32s3box
  # variant: ESP32S3
  framework:
    type: arduino
    version: latest
  flash_size: 16MB
  - source: github://clydebarrow/esphome@cst226 ####https://community.home-assistant.io/t/any-way-to-get-the-new-t-display-s3-amoled-to-work-with-esphome/601414/20
    # refresh: 10min
    components: [ cst226 ]
psram:
  speed: 80MHz
i2c:
   - id: bus_a
     sda:
      number: 5
     scl:
      number: 6
    #  scan: False
    #  frequency: 100kHz
logger:
  baud_rate: 0
  level: DEBUG
  logs:
    # esp32_ble: DEBUG
    # ble_dist: INFO
    # sensor: INFO
    # vl53l0x: NONE
    light: INFO
    ltr_als_ps: INFO
    # ledc.output: INFO
    # component: INFO
    # ili9xxx: WARN
    # tt21100: WARN
    # tdisplays3: DEBUG
    # touchscreen: WARN
    # wifi: DEBUG
    # es8311: WARN
    # i2s_audio: DEBUG
    # es7210: WARN
    # graph: ERROR
api:
  encryption:
    key: !secret api
ota:
  - platform: esphome
    # safe_mode: true
wifi:
  fast_connect: on
time:
button:
  - platform: restart
    icon: mdi:restart
output:
  - platform: ledc
    pin: 48
    channel: 1
    frequency: 20000
  - platform: ledc
    pin: 38
    channel: 2
light:
    address: 0x23
    auto_mode: false
    gain: 2x
    ambient_light:
    ps_cooldown: 1 s
      then:
        - delay: 50ms
      then:
        - delay: 50ms
binary_sensor:
    filters:
      - delayed_off: 10s
    on_press:
      then:
        # - delay: 3s
        #       id: proximity
        - delay: 50ms
        # - light.turn_on:
        #     id: back_light
    on_release:
      then:
        - delay: 50ms
        # - light.turn_off:
        #     id: back_light
  - platform: gpio
    pin:
      number: 12
      inverted: true
    # internal: True
  - platform: gpio
    pin:
      number: 16
      inverted: true
    # internal: True
    # filters:
    # - invert:
    # on_press:
    #   then:
#   - port: 8080
#     mode: stream
#   - port: 8081
#     mode: snapshot
# esp32_camera:
#   name: "CAM"
#   id: cam
#   #internal: False
#   external_clock:
#     pin: 11
#   i2c_pins:
#     sda: 5
#     scl: 6
#   vsync_pin: 7
#   href_pin: 15
#   reset_pin: 46
#   resolution: UXGA
#   # aec_mode: auto
#   # aec2: false
#   # ae_level: 0
#   # aec_value: 300
#   # gain settings
#   # agc_mode: auto
#   # agc_value: 0
#   wb_mode: OFFICE
spi:
  mosi_pin: 17
  clk_pin: 18
  # miso_pin: 8
touchscreen:
  - platform: cst226
    # interrupt_pin: 9
    reset_pin: 2
    on_update:
    - lambda: |-
          for (auto touch: touches)  {
              if (touch.state <= 2) {
                 ESP_LOGI("Touch points:", "id=%d x=%d, y=%d", touch.id, touch.x, touch.y);
display:
  - platform: ili9xxx
    model: ST7796
    dimensions:
      height: 480
      width: 222
    #   height: 480
    #   width: 222
      offset_height: 0
      offset_width: 49
    # transform:
    #   swap_xy: true
      # mirror_y: true
    color_order: bgr
    data_rate: 80MHz
    # cs_pin: 8
    dc_pin: 9
    reset_pin: 47
    # spi_mode: MODE3
    invert_colors: true
    pages:
      - id: weather
        lambda: |-
          // clear screen
          it.clear();
font:
color:
    hex: BBBBBB
    hex: 5F5F5F
  - id: color_white
    hex: FFFFFF
  - id: color_red
    hex: FF0000
  - id: color_green
    hex: 14FF00
  - id: color_yellow
    hex: FFFF00
  - id: color_blue
    hex: 0000FF
# font:
#     id: roboto
#     size: 30
#  * @license   MIT
# #pragma once
# // BUTTON Pinmap
# #else
# #endif
Bonus. Figured the integrated button would work as normal gpio and it did ;-), here is the working code:
####Screen integrated button at the bottom of the screen.
  - platform: gpio
    pin:
      number: 21
      inverted: true
    # internal: True
    filters:
      - delayed_off: 1s
#### boot key = on the bottom left
  - platform: gpio
    pin:
      number: 0
      inverted: true
    # internal: True
todo: Figure out the mess on the cam pinout… will post with my findings.
Hey @ManRiver
Thank you so much! I just found this post and it’s being super helpful.
Any new findings since your last post?
has anybody gotten any further with this device? would be neat to have battery status and get the camera operational?
Does it work with the LVGL widgets?
