a year ago a i replaced default sonoff s26 firmware to ESPHome following this setup.
I used default setup, only i replaced SSID and password:
# Basic Config
esphome:
platform: ESP8266
board: esp01_1m
board_flash_mode: dout
wifi:
ssid: "XX__MYSSID__XX"
password: "XX__wifi_password__XX"
ap:
ssid: "ap_ssid"
password: "Password"
domain: ".domain.com"
status_led:
pin:
number: GPIO13
inverted: false
logger:
api:
password: "api_password"
ota:
password: "OTA_password"
web_server:
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
name: "Sonoff S26_1 Button"
on_press:
- switch.toggle: relay
- platform: status
name: "Sonoff S26_1 Status"
- platform: wifi_signal
name: "sonoffs26_1 WiFi Signal"
update_interval: 60s
switch:
- platform: gpio
name: "Sonoff S26_1 Relay"
pin: GPIO12
- platform: restart
Now i need to modify “SSID” and “Password” and i tried to update firmware by OTA. I replaced SSID and password in yaml file and tried to update it by the device web interface. I select the file to upload and press update button but instatly i receive this error “Update Failed: ERROR[10]: Magic byte is wrong, not 0xE9”.
Can someone tel me if i i’m doing some wrong and how could i change ssid and paswword to the device? I try to avoid to open again the device to update the firmware.
