So I got these “Playbulb Candles” for free, they have been sitting on my desk and I had no idea wtf I was going to do with them or use them for,
Turns out, they make really handy LED status indicators to indicate the status of entities and internet connection,
Now WiFi instead of bluetooth.
Flashes orange when the internet is down, 8.8.8.8 is unreachable.
Flashes red when any esphome device disconnects from the wifi.
More to be decided.
Simple single WS2812 LED and esp8266.
tom_l
April 7, 2024, 2:30am
2
Great idea. It would be nice if you also included your esphome config.
DigiH
April 7, 2024, 12:27pm
3
Nice hack!
I just control and regularly poll the battery status of my Playbulb Candles, as they came, via Bluetooth, and appreciate their portability with rechargeable batteries inside
Sure, current config to date.
wifi:
networks:
- ssid: !secret wifi_ssid
bssid:redacted
fast_connect: true
on_connect:
- light.turn_on:
brightness: 100%
red: 0%
green: 100%
blue: 0%
effect: none
on_disconnect:
- light.control:
state: on
effect: ERROR
captive_portal:
light:
- platform: fastled_clockless
pin: 23
chipset: WS2812
num_leds: 1
rgb_order: GRB
# restore_mode: ALWAYS_OFF
effects:
# Use default parameters:
- random:
# Customize parameters
- random:
name: "My Slow Random Effect"
transition_length: 30s
update_interval: 30s
- random:
name: "My Fast Random Effect"
transition_length: 4s
update_interval: 5s
- random:
name: Random Effect With Custom Values
transition_length: 5s
update_interval: 7s
- pulse:
transition_length: 0.5s
update_interval: 0.5s
min_brightness: 0%
max_brightness: 100%
- pulse:
# transition_length: 1s # defaults to 1s
update_interval: 2s
- strobe:
name: Strobe Effect With Custom Values
colors:
- state: true
brightness: 100%
red: 100%
green: 90%
blue: 0%
duration: 500ms
- state: false
duration: 250ms
- state: true
brightness: 100%
red: 0%
green: 100%
blue: 0%
duration: 500ms
- flicker:
name: Flicker Effect With Custom Values
alpha: 95%
intensity: 1.5%
- addressable_rainbow:
name: Rainbow Effect With Custom Values
speed: 10
width: 50
- addressable_color_wipe:
name: Color Wipe Effect With Custom Values
colors:
- red: 100%
green: 100%
blue: 100%
num_leds: 1
- red: 0%
green: 0%
blue: 0%
num_leds: 1
add_led_interval: 100ms
reverse: false
- addressable_scan:
name: Scan Effect With Custom Values
move_interval: 100ms
scan_width: 1
- addressable_twinkle:
name: Twinkle Effect With Custom Values
twinkle_probability: 5%
progress_interval: 4ms
- addressable_random_twinkle:
name: Random Twinkle Effect With Custom Values
progress_interval: 32ms
- addressable_fireworks:
name: Fireworks Effect With Custom Values
update_interval: 32ms
spark_probability: 10%
use_random_color: false
fade_out_rate: 120
- addressable_lambda:
update_interval: 50ms
lambda: |-
static int x = 40;
static int y = 0;
if (initial_run) {
x = 40;
y = 0;
it.all() = ESPColor::BLACK;
if (x < it.size(), (y < it.size())) {
it[x, y] = current_color;
y += 1;
x += 1;
update_interval: 16ms
lambda: |-
static int x = -400;
float y = 0.35+0.65*exp(-pow(x, 2)/49000);
int8_t r = ceil(current_color.r * y);
int8_t g = ceil(current_color.g * y);
int8_t b = ceil(current_color.b * y);
it.all() = ESPColor(r,g,b);
x += 1;
if (x == 400)
x = -400;
update_interval: 12ms
lambda: |-
static int x = 0;
if (initial_run) {
x = it.size();
if (x > 0) {
x -= 1;
it[x] = ESPColor::BLACK;
- lambda:
update_interval: 1s
lambda: |-
static bool state = false;
auto call = id(led).turn_on();
call.set_transition_length(500);
call.set_rgb(1, 0, 0);
if (!state) {
call.set_brightness(1);
} else {
// If using 0, it freaks Home Assistant UI.
call.set_brightness(0.01);
call.perform();
state = !state;
- lambda:
update_interval: 1s
lambda: |-
call.set_rgb(0, 1, 0);
if (!state) {
} else {
call.perform();
state = !state;
