Esphome: Probe Request Unsuccessful
Playing around with a esp8266 nodemcu
I getting “Probe Request Unsuccessful”
[17:07:50][W][wifi:451]: Error while connecting to network.
[17:07:55][D][wifi:304]: Starting scan...
[17:08:01][D][wifi:319]: Found networks:
[17:08:01][I][wifi:365]: - 'MYLE-2' (D8:5D:4C:E5:80:FE) ▂▄▆█
[17:08:01][D][wifi:366]:     Channel: 11
[17:08:01][D][wifi:367]:     RSSI: -65 dB
[17:08:01][D][wifi:369]: - 'MYLE' (18:F1:45:C2:E1:27) ▂▄▆█
[17:08:01][D][wifi:369]: - 'DIRECT-0A-HP MYLE' (F4:39:09:A4:6A:0B) ▂▄▆█
[17:08:01][D][wifi:369]: - '' (00:1F:1F:CB:7E:00) ▂▄▆█
[17:08:01][I][wifi:193]: WiFi Connecting to 'MYLE-2'...
[17:08:07][W][wifi_esp8266:334]: Event: Disconnected ssid='MYLE-2' reason='Probe Request Unsuccessful'
[17:08:07][W][wifi:451]: Error while connecting to network.
[17:08:07][I][wifi:193]: WiFi Connecting to 'MYLE-2'...
[17:08:13][W][wifi_esp8266:334]: Event: Disconnected ssid='MYLE-2' reason='Probe Request Unsuccessful'
have a esp32 and that join the MYLE-2 network OK
google finds
mmmmmmmmmm
thanks
its a esphome problem
just put tasmota on it and it work :slight_smile:
Tried to install Tasmota on this device to resolve issue as suggested and the same styles of problems. Very unreliable hardware appears to be the cause. I was originally expecting that if Tasmota works then it is code not hardware but found that as soon as you start to fill memory with larger programs, the crashes start to occur with disconnects and system hanging. Message from all this, is that you should purchased only the shielded units. Not sure that the cheaper units should even be allowed to be sold in Australia. ACMA have strict rules about RF interference. Would not expect these devices to pass.
