I’ve been using ESPHome and a couple of Raspberry Pi Pico Ws for a year or so via a Docker hosted ESPHome Dashboard. It’s worked very well.
In the last few days I’ve been unable to building any of my code.
Basically anything I build fails. See below for the errors. This is with Docker ESPHome hosted Dashboard 2024.9.1. I’ve tried a couple of earlier versions with the same.
I’ve also installed ESPHome 2024.9.1 in a python venv and get the same building with “esphome compile script”.
Interestingly if I change the platform to esp32 I can build.
Is anyone else seeing the same building for Raspberry PI Pico W?
Thanks,
Steve
Compiling .pioenvs/picow-6/FrameworkArduino/wiring_shift.cpp.o
Archiving .pioenvs/picow-6/libFrameworkArduino.a
Linking .pioenvs/picow-6/firmware.elf
/config/.esphome/platformio/packages/toolchain-rp2040-earlephilhower/bin/../lib/gcc/arm-none-eabi/14.2.0/../../../../arm-none-eabi/bin/ld: /config/.esphome/platformio/packages/toolchain-rp2040-earlephilhower/bin/../lib/gcc/arm-none-eabi/14.2.0/../../../../arm-none-eabi/lib/thumb/libc.a(libc_a-findfp.o): in function `std':
/workdir/repo/newlib/newlib/libc/stdio/findfp.c:93:(.text+0xda): undefined reference to `__retarget_lock_init_recursive'
/config/.esphome/platformio/packages/toolchain-rp2040-earlephilhower/bin/../lib/gcc/arm-none-eabi/14.2.0/../../../../arm-none-eabi/bin/ld: /workdir/repo/newlib/newlib/libc/stdio/findfp.c:93:(.text+0x124): undefined reference to `__retarget_lock_init_recursive'
/config/.esphome/platformio/packages/toolchain-rp2040-earlephilhower/bin/../lib/gcc/arm-none-eabi/14.2.0/../../../../arm-none-eabi/bin/ld: /workdir/repo/newlib/newlib/libc/stdio/findfp.c:93:(.text+0x17c): undefined reference to `__retarget_lock_init_recursive'
/config/.esphome/platformio/packages/toolchain-rp2040-earlephilhower/bin/../lib/gcc/arm-none-eabi/14.2.0/../../../../arm-none-eabi/bin/ld: /config/.esphome/platformio/packages/toolchain-rp2040-earlephilhower/bin/../lib/gcc/arm-none-eabi/14.2.0/../../../../arm-none-eabi/lib/thumb/libc.a(libc_a-findfp.o): in function `__sfp':
/workdir/repo/newlib/newlib/libc/stdio/findfp.c:201:(.text+0x1ea): undefined reference to `__retarget_lock_init_recursive'
collect2: error: ld returned 1 exit status
*** [.pioenvs/picow-6/firmware.elf] Error 1
