since one of the last updates of ESPHome I’m not anymore able to compile my nodes. Same issue appears with all the nodes. In the past was working without any problems …
During compilation I get following issue:
INFO Reading configuration /config/esphome/gartensensor2.yaml...
INFO Generating C++ source...
INFO Compiling app...
Processing gartensensor2 (board: esp01_1m; framework: arduino; platform: platformio/espressif8266 @ 2.6.2)
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
Dependency Graph
|-- <ESPAsyncTCP-esphome> 1.2.3
| |-- <ESP8266WiFi> 1.0
|-- <ESPAsyncWebServer-esphome> 2.0.0
| |-- <Hash> 1.0
| |-- <ArduinoJson-esphomelib> 5.13.3
|-- <AsyncMqttClient-esphome> 0.8.6
|-- <ESP8266mDNS> 1.2
|-- <DNSServer> 1.1.1
Compiling /data/gartensensor2/.pioenvs/gartensensor2/src/esphome/components/adc/adc_sensor.cpp.o
In file included from src/esphome/components/adc/adc_sensor.h:3:0,
from src/esphome/components/adc/adc_sensor.cpp:1:
src/esphome/core/component.h:3:18: fatal error: string: No such file or directory
#include <string>
compilation terminated.
Compiling /data/gartensensor2/.pioenvs/gartensensor2/src/esphome/components/captive_portal/captive_portal.cpp.o
In file included from src/esphome/components/captive_portal/captive_portal.cpp:3:0:
src/esphome/components/captive_portal/captive_portal.h:5:18: fatal error: memory: No such file or directory
#include <memory>
Compiling /data/gartensensor2/.pioenvs/gartensensor2/src/esphome/components/deep_sleep/deep_sleep_component.cpp.o
*** [/data/gartensensor2/.pioenvs/gartensensor2/src/esphome/components/adc/adc_sensor.cpp.o] Error 1
*** [/data/gartensensor2/.pioenvs/gartensensor2/src/esphome/components/captive_portal/captive_portal.cpp.o] Error 1
Compiling /data/gartensensor2/.pioenvs/gartensensor2/src/esphome/components/dht/dht.cpp.o
In file included from src/esphome/components/deep_sleep/deep_sleep_component.h:3:0,
from src/esphome/components/deep_sleep/deep_sleep_component.cpp:1:
#include <string>
*** [/data/gartensensor2/.pioenvs/gartensensor2/src/esphome/components/deep_sleep/deep_sleep_component.cpp.o] Error 1
In file included from src/esphome/components/dht/dht.h:3:0,
from src/esphome/components/dht/dht.cpp:1:
#include <string>
*** [/data/gartensensor2/.pioenvs/gartensensor2/src/esphome/components/dht/dht.cpp.o] Error 1
========================== [FAILED] Took 6.92 seconds ==========================
Anybody discovered similar topics?
