I have few Sonoff Slampher devices that are running using the common code:
#The substitution block has all the configurable details
substitutions:
name_of_board: bulbholder01
ota_password: !secret bulbholder01_ota
api_password: !secret bulbholder01_api_password
api_encryption_key: !secret bulbholder01_api_encryption
ip_address: !secret ip_address_bulbholder01
#YOU SHOULD NOT NEED TO EDIT BELOW THIS LINE
packages:
wifi_settings: !include common/basic_components.yaml
basics: !include common/basic_sensors.yaml
device_settings: !include common/slampher.yaml
So the only part I need to change for each device are the values in secrets file and all the devices (except one) are working fine. The one that has problem is showing weird symptoms:
- It works in HA i.e. I can toggle the light on/off and automations are working
- If I delete this device from ESPHome integration and it is detected right back in, the API password and key are working as it gets integrated back in like a charm
- But when I try to update the device using ESPHome web UI, I get following error:
========================= [SUCCESS] Took 3.38 seconds =========================
INFO Successfully compiled program.
INFO Connecting to 192.168.2.32
ERROR Connecting to 192.168.2.32:8266 failed: [Errno 113] No route to host
And in the HA system logs, I see few more details such as:
2022-08-16 23:55:42,941 INFO Running command 'esphome --dashboard run /config/esphome/bulbholder01.yaml --device OTA'
2022-08-16 23:55:46,504 INFO 304 GET /devices (0.0.0.0) 7.45ms
2022-08-16 23:55:50,712 INFO Process exited with return code 1
I am unable to understand why this one device is behaving so odd than the rest that are using the same code base.
Any pointers to resolve OTA are welcome!
