Clubb33LLC
(Bernard S Jones)
September 30, 2021, 9:24pm
1
Below is the error when I attempt to validate my yaml file in ESPhome, please help
‘’‘INFO Reading configuration /config/esphome/light-mcu-1.yaml…
Failed config
sensor.mqtt: [source /config/esphome/light-mcu-1.yaml:32]
Platform not found: ‘sensor.mqtt’.
platform: mqtt
state_topic: LightMCU/locator’’’
Check line 32 for error. Basically it say that sensor.mqtt is not available
Clubb33LLC
(Bernard S Jones)
October 1, 2021, 5:02am
3
I agree with that part I’m trying to figure out how to resolve it. I have MQTT installed have I failed to fully set it up? If so what part did I fail? I completed the test in MQTT and the configuration reads as follows:
Failed config
platform: mqtt
I also have the following in the log:
1633063596: Socket error on client , disconnecting.
1633063716: New connection from XXX.XX.XX.X on port 1883.
(the X’s remove the actual IP)
vincen
(Vincèn)
October 1, 2021, 6:13am
4
How do you expect to get correct help if you don’t share your esphome sketch ?
Clubb33LLC
(Bernard S Jones)
October 2, 2021, 4:35pm
5
I’m a noob I thought the error would be a better place to start, the yaml file is below:
platform: mqtt
state_topic: “LightMCU/locator”
the ‘’’- platform: mqtt’’’ is where the error starts, the rest of the code is fine
francisp
(Francis)
October 2, 2021, 4:56pm
6
A .yaml with 4 lines won’t compile. You need to add a lot more.
vincen
(Vincèn)
October 3, 2021, 8:32am
7
Clubb33LLC:
platform: mqtt
As stated by @francisp if your sketch has only that it can’t work, you should first read in details ESPHome documentation and understand how it works
Clubb33LLC
(Bernard S Jones)
October 3, 2021, 8:13pm
8
I failed to attach all of the code
esphome:
platform: ESP8266
board: nodemcuv2
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
password: ""
wifi:
ssid: ""
password: ""
ap:
ssid: "Backyard-Light Fallback Hotspot"
password: "I3W8U5yZc4P4"
captive_portal:
- platform: mqtt
state_topic: "LightMCU/locator"
light:
- platform: mqtt
command_topic: "LightMCU/power"
state_topic: "LightMCU/powerState"
brightness_command_topic: "LightMCU/brightness"
brightness_state_topic: "LightMCU/brightnessState"
brightness_scale: 255
white_value_command_topic: "LightMCU/modifier"
white_value_state_topic: "LightMCU/modifierState"
white_value_scale: 500
effect_command_topic: "LightMCU/effect"
effect_state_topic: "LightMCU/effectState"
effect_list:
- Color_Chase
- Color_Glitter
- Single_Race
- Double_Crash
- Rainbow
- Blocked_Colors
- BPM
- Twinkle
- Fire
- Fill_Solid
- Spooky_Eyes
- LED_Locator
retain: true
- platform: mqtt
command_topic: "LightMCU/ColorPower"
rgb_command_topic: "LightMCU/color1"
rgb_state_topic: "LightMCU/color1State"
retain: true
- platform: mqtt
rgb_command_topic: "LightMCU/color2"
rgb_state_topic: "LightMCU/color2State"
retain: true
- platform: mqtt
rgb_command_topic: "LightMCU/color3"
rgb_state_topic: "LightMCU/color3State"
retain: true
- platform: mqtt
state_topic: "LightMCU/glitter/state"
command_topic: "LightMCU/addEffects"
payload_on: "Glitter On"
payload_off: "Glitter Off"
rgb_command_topic: "LightMCU/glitterColor"
rgb_state_topic: "LightMCU/glitterColorState"
white_value_command_topic: "LightMCU/glitterChance"
white_value_state_topic: "LightMCU/glitterChanceState"
white_value_scale: 255
retain: true
- platform: mqtt
state_topic: "LightMCU/lightning/state"
payload_on: "Lightning On"
payload_off: "Lightning Off"
white_value_command_topic: "LightMCU/lightningChance"
white_value_state_topic: "LightMCU/lightningChanceState"
retain: true
##Example Group
group:
houseLights:
control: hidden
entities:
- light.holiday_lights
- light.color_1
- light.color_2
- light.color_3
- light.glitter
- light.lightning
- sensor.current_led
##Example Lovelace
cards:
- type: entities
title: Holiday Lights
show_header_toggle: false
entities:
- light.color_1
- light.color_2
- light.color_3
- light.glitter
- light.lightning
Clubb33LLC
(Bernard S Jones)
9
Here is all of it
esphome:
platform: ESP8266
board: nodemcuv2
# Enable logging
logger:
api:
ota:
password: ""
wifi:
ssid: ""
password: ""
ap:
captive_portal:
- platform: mqtt
light:
- platform: mqtt
effect_list:
- Color_Chase
- Color_Glitter
- Single_Race
- Double_Crash
- Rainbow
- Blocked_Colors
- BPM
- Twinkle
- Fire
- Fill_Solid
- Spooky_Eyes
- LED_Locator
retain: true
- platform: mqtt
retain: true
- platform: mqtt
retain: true
- platform: mqtt
retain: true
- platform: mqtt
retain: true
- platform: mqtt
retain: true
##Example Group
group:
houseLights:
control: hidden
entities:
- light.color_1
- light.color_2
- light.color_3
- light.glitter
- light.lightning
##Example Lovelace
cards:
- type: entities
entities:
- light.color_1
- light.color_2
- light.color_3
- light.glitter
- light.lightning
Clubb33LLC
(Bernard S Jones)
October 3, 2021, 8:15pm
10
I removed the wifi info as I know that is correct and the OTA password
vincen
(Vincèn)
October 4, 2021, 5:37am
12
Instead of editing your code before sharing it here, put all credentials in secrets file
Clubb33LLC:
Here is all of it
How do you expect to subscribe at MQTT topics without first declaring how to connect at MQTT Server ? I would strongly advise you to read ESPHome documentation about MQTT here MQTT Client Component — ESPHome to properly setup it and also perhaps read a little of documentation about MQTT to understand properly how it works (Documentation | Eclipse Mosquitto )
Clubb33LLC
(Bernard S Jones)
October 4, 2021, 7:04pm
13
Excellent point, I just read up on that last night and I’m reconfiguring all of my code to operate that way
vincen
(Vincèn)
October 4, 2021, 8:05pm
14
and feel free to share your sketch again if you still have some issues after having updated it
