EspHome Projekt for reading D0 Smartmeters
I would like to readout my D0-IR-Interface of Easymeter Q3C.
There are a lot of aproaches to get it into HA (with MQTT, Tasmota and whatever)
It would be nice to have an easy solution like the Homeassistant Glow
Best regards,
Stefan
@r100gs, I don’t know where you are from, but in Poland you can buy this device:
Not so expensive and it does exactly what you are looking for. (You need either a phone or a RaspberryPi to transfer the Bluetooth data to their servers first.) Maybe there are similar projects in your country, or some open-source one. There is a similar size Bluetooth device for similar purpose what can be bought from botland. It is called iNode as I can remember. Check that as well.
I´m from Germany.
Looks interesting, but is sold out
It was sold out 2 months ago as well, but you could find from other sellers (re-sellers) for a higher price or similar.
I’ve got one from the local market place Allegro from a private seller, who couldn’t use it with his meter due to incompatibility. The operator changed the meter one PV was installed and installed a meter which had a blocked communication port.
I’ve looked quickly to Allegro and OLX as well, but there are 0 pieces for sale currently.
But here is one which states that they have in stock…
https://soltec.pl/pl/monitoring-bezpieczeństwo-optymalizacja/563-onemeter-home-pv-5903714210084.html
If you consider it is a cheap solution. Cheaper than most smart meters what you would install together with a PV system. Probably the local PV installers bought the stocks and selling it together with the installations.
In theory, any Energy supplier could use it as well if the meter has a working port. They could just do reading with a passing by solution, and they would have historical and current data as well.
Otherwise look at iNode:
https://inode.pl/
It is kinda an equivalent of Home Assistant Glow but in a smaller/compact form.
Actually I’ve just came across this today, from Tasmota. I’ve seen it in another topic.
And looking at the ESPHome documentation, it seems to be there is something as well for DSMR meters.
But really this is what you need for your meter, because it uses SML (Smart Meter Language).
@ GSzabados
Thanks! I will look into this and hope to get it running.
Best regards,
Stefan
You are very welcome! Lucky you as I just came across that post in the other topic where the user was using Tasmota. What seems to be straightforward to use.
But the ESPHome version looks easy as well, just need to pull the external_component.
Let me know how you succeed.
Hi there, I create an ESPHome external component for smart meters with an OBIS D0 interface:
Hello together,
I tried some ways to get my data from my Easymeter q3c with no luck.
I tried the esphome sml component and @mampfes D0 component.
At least I get some data from the hitchi sensor.
Maybe somebody can help me, please.
The readings from my smartmeter are:
[10:48:01][D][uart_debug:114]: <<< 8E:60:62:1E:00:64:0B:FC:F4:81:20:08:01:00:65:11:1C:69:00:00:00:40:D7:50:FF:05:C1:72:22:89:79:52:FD:01:77:07:01:05:C1:72:F2:60:62:1E:52:05:77:07:C1:04:C1:72:00:60:62:1E:D2:05:77:07:01:AC:C1:72:FF:0C:89:79:02:2B:77:07:FD:63:41:B0:32:0C:89:79:FA:27:40:D7:00:63:41:B0:F2:31:60:62:1E:00:79:01:77:87:63:41:B0:02:0C:89:79:D5:5C:77:07:FF:63:41:B0:FE:0C:0C:89:39:00:71:01:77:FF:01:01:62:00:03:E2:01:F7:04:FF:01:01:FE:AD:45:C1:07:00:FF:01:00
[10:48:03][D][uart_debug:114]: <<< FF:FE:F3:9D:3A:00:FF:01:55:FF:63:FF:04:15:05:1F:C1:01:01:FD:76:05:01:0F:72:65:00:F0:02:59:00:00:02:9E:38:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:F8:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:A3:A3:A3:01:01:01:76:05:00:72:65:00:D0:50:D4:95:00:45:53:59:01:FF:00:01:63:0C:0C:82:91:62:00:FE:74:01:77:01:40:07:1B:37:F6:40
[10:48:03][D][uart_debug:114]: <<< 59:44:E4:00:81:C7:82:83:04:45:53:59:01:08:FF:63:59:44:E4:00:14:00:00:64:37:07:01:02:02:93:89:05:FD:80:1E:52:FC:09:DA:D4:01:F7:14:FF:63:41:C4:E4:62:E2:14:39:DF:01:00:90:FF:63:41:44:E4:62:00:00:00:6E:01:68:FF:63:01:14:C4:E4:62:FE:00:00:00:6F:01:88:FF:63:F9:56:C4:E4:22:00:00:6E:F1:21:05:FF:63:00:45:1C:8E:E2:00:00:00:6F:00:08:06:FF:63:65:11:1C:8E:02:02:00:00:79:FF:08:E8:FF:23:59:44:E4:FE:65:00:29:57:07:00:08:08:FF:F3:40:59:44:E4:01:00:00:F1:01:07:00
[10:48:05][D][uart_debug:114]: <<< FF:00:55:FF:FC:F2:80:45:10:03:F9:55:FF:FE:0A:00:29:07:00:2A:55:FF:FE:50:00:3D:07:24:E5:55:FF:1D:01:00:20:01:63:41:F0:F8:76:00:00:62:00:F2:AE:63:A3:01:1B:1B:1A:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:C0:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:1B:1B:1B:1B:01:01:01:2C:62:00:FE:01:76:01:01:07:80:A8:21:50:D4:37:36
[10:48:05][D][uart_debug:114]: <<< 76:01:01:01:0F:C1:F4:65:00:00:07:00:A0:AA:15:87:90:89:05:65:00:77:07:81:81:40:40:40:50:00:01:01:01:08:FF:2E:AC:65:11:A4:FC:69:00:FC:18:01:77:07:F8:63:41:B0:F2:47:8C:89:79:3F:16:3D:C7:40:40:28:03:05:65:11:1C:40:59:41:02:01:01:08:02:FF:B1:40:59:44:00:01:65:00:00:FC:14:01:08:03:AC:65:11:FC:15:65:00:00:01:01:08:C4:B1:40:59:44:00:65:00:80:A0:01:08:05:89:05:65:11:A9:40:59:00:00:01:01:08:FE:06:05:65:11:AA:65:00:F8:0A:02:02:08:89:05:65:F1:52:01:65:00:00
[10:48:07][D][uart_debug:114]: <<< 01:02:02:88:72:62:01:65:00:52:01:65:00:40:00:01:07:23:2A:55:FF:D7:50:00:05:58:23:2A:FD:40:D7:50:00:62:1B:52:FE:BD:77:07:01:01:62:1B:D2:12:01:77:07:00:01:01:01:01:D0:1D:F7:00:80:70:65:2C:48:01:71:01:00:1B:1B:1B:FF:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:1B:1B:1B:00:C1:96:62
[10:48:07][D][uart_debug:114]: <<< E0:00:01:01:76:45:CD:43:CB:D0:74:B2:02:00:76:05:01:2C:72:65:00:21:50:D4:F5:93:57:72:02:66:F1:00:77:FF:F4:01:01:01:05:77:07:01:FD:41:B0:72:62:00:96:79:52:FC:0B:FC:F4:18:00:40:08:FF:E3:2A:45:1C:8E:00:A0:00:00:3F:D0:D7:50:01:01:60:72:62:01:FD:62:1E:52:01:05:1D:01:01:F1:40:72:62:01:79:52:01:E5:D7:50:01:00:B0:72:62:81:20:24:15:00:D7:50:01:05:93:89:05:2C:24:15:FF:DD:1D:01:01:C1:72:62:F9:89:79:52:01:40:D7:50:F1:41:B0:72:62:00:96:79:52:C1:01:77:07:01:00
[10:48:09][D][uart_debug:114]: <<< 05:C1:72:62:96:79:52:01:01:77:07:01:FF:05:C1:72:02:96:79:52:FF:01:77:07:01:01:62:1B:F2:4F:0B:77:07:01:01:62:FB:A7:B4:01:77:FF:01:01:E2:FE:EE:2F:01:00:00:FF:01:01:FD:FF:5D:D0:01:00:05:FF:01:FD:0B:01:01:03:50:0F:C1:F8:95:01:00:02:60:00:00:00:FB:00:2A:FF:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
[10:48:09][D][uart_debug:114]: <<< 00:00:00:00:00:00:1B:00:AB:01:0F:C1:92:95:01:00:01:80:51:AA:15:FD:4D:65:05:07:03:AC:A3:3E:FE:11:2C:62:00:77:01:0B:FE:1D:1B:37:36:16:C4:E4:68:F1:C7:82:03:FF:00:80:53:59:01:F7:A0:63:41:00:1C:8E:68:62:02:00:64:0B:00:01:02:02:08:FC:97:05:65:11:2A:69:00:FC:E5:0A:77:07:63:41:B0:F2:E4:68:62:1E:EC:17:77:C7:63:41:B0:00:E4:68:62:1E:00:2B:77:07:63:41:B0:FE:8E:0C:4B:19:6F:01:77:FF:FF:63:41:30:E4:68:62:FE:00:6E:01:77:FF:63:41:F0:1C:8E:68:62:00:00:6F:01:F7:E8
[10:48:10][D][uart_debug:114]: <<< 63:41:00:1C:8E:68:62:80:79:01:03:D0:63:41:FE:44:E4:68:02:4A:D5:5C:FF:00:FF:63:41:00:C4:E4:68:F2:04:00:71:01:00:00:00:FF:01:81:FD:FC:EF:29:00:00:07:00:FF:01:55:FE:A6:00:4A:10:FF:55:FF:FE:0B:3D:07:00:FF:E5:55:FF:7F:00:60:05:E5:8D:05:C1:01:00:76:05:C1:24:01:72:65:00:80:2C:56:11:23:23:A0:06:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
[10:48:11][D][uart_debug:114]: <<< 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:40:40:57:50:00:2C:72:05:01:07:45:F3:21:50:D4:95:00:05:01:63:E3:0F:C1:9D:62:00:00:07:01:77:AB:07:1B:03:40:59:44:FC:07:81:81:C7:00:04:45:53:FF:01:01:08:00:1F:40:59:44:E4:FC:69:00:00:00:77:07:01:C2:41:B0:72:62:00:96:79:52:FC:51:4A:93:01:08:01:FF:63:2A:45:1C:8E:00:41:8E:DF:FF:00:02:FF:63:59:44:E4:FE:59:00:00:2E:80:68:FF:E3:40:59:44:E4:B0:00:00:EF:0A:08:04:FF:01:65:11:1C:8E:40:59:00:00:40:A8:FF:FF
[10:48:12][D][uart_debug:114]: <<< 40:59:44:E4:59:00:00:FF:40:40:C8:3F:65:11:1C:FE:01:65:00:00:00:40:20:E8:FF:05:65:11:1C:00:80:59:29:57:12:02:08:08:03:40:59:44:F4:A0:16:00:00:01:07:00:FF:F9:55:FF:3C:00:15:07:F8:92:F9:55:FF:00:00:29:E7:1B:52:FE:55:00:EA:01:00:3D:62:1B:52:FE:01:D7:50:00:FF:01:01:01:63:01:00:AF:07:FE:47:2C:62:00:71:01:63:FF:6D:1B:1B:1A:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:40:00:00:00:00:00
[10:48:13][D][uart_debug:114]: <<< 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:01:01:01:01:30:26:01:62:00:01:76:01:01:D5:1A:2D:06:01:37:36:76:01:FF:15:01:0F:01:E4:65:00:00:FF:A8:4D:65:05:72:62:01:F5:7C:77:07:01:01:01:01:84:77:07:01:01:01:72:62:01:65:79:52:FC:69:00:1F:14:77:FF:FA:63:41:B0:00:E4:6C:62:FE:10:3F:16:3D:80:40:40:28:2E:AC:65:11:15:65:00:C1:28:01:01:08:00:89:05:65:11:49:05:65:00:00:01:01:01:08:FF:97:05:65:01:AA:65:00:FE:14:01:01
[10:48:14][D][uart_debug:114]: <<< 08:40:89:05:65:F1:92:05:65:00:00:01:01:E8:6C:2E:AC:65:40:AA:65:80:50:01:01:00:72:62:01:65:FF:24:15:65:00:07:01:02:02:FE:B0:72:62:01:05:24:15:65:F8:D7:50:02:02:93:89:05:E5:04:24:15:65:1D:01:00:81:62:1B:52:FE:01:66:07:01:00:40:AC:23:2A:40:D7:50:FE:50:62:1B:12:C0:14:77:07:F9:01:01:62:1B:C9:01:77:F7:FF:01:01:01:00:01:63:96:D5:0F:C1:A1:62:00:00:02:01:71:40:1B:1B:0B:FF:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
[10:48:15][D][uart_debug:114]: <<< 00:00:01:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:01:01:FF:41:40:28:A2:00:00:01:01:F6:59:51:33:43:07:1B:37:F6:70:76:05:01:62:00:72:E5:A0:21:50:D4:00:36:76:01:72:FF:CC:2B:00:03:40:A0:01:01:FF:15:77:07:01:AC:C1:72:FA:CC:4B:79:12:C0:0B:FC:F4:F8:00:08:00:FF:00:65:11:1C:8E:7F:5A:00:00:00:77:07:01:01:28:93:89:05:2C:24:15:FF:74:1D:01:01:50:93:89:E5:4B:79:52:01:77:07:01:E1
[10:48:16][D][uart_debug:114]: <<< 05:C1:72:62:00:4B:79:52:C1:01:77:07:01:00:05:C1:72:62:B7:2C:24:05:00:D7:50:05:C1:72:62:6E:62:1E:52:FF:00:77:07:01:AC:C1:72:F2:73:89:79:52:05:77:07:C1:63:41:B0:72:00:62:4B:79:D2:5C:77:07:00:63:41:B0:72:CC:4B:79:02:5C:40:D7:D0:01:01:62:1B:68:01:77:FF:FF:01:01:62:00:AB:F3:01:F7:02:FF:01:01:00:E0:FE:F3:1E:81:07:00:FF:01:00:FE:FF:61:57:15:05:FF:01:20:01:01:01:FF:15:01:0F:01:AE:16:00:FA:7A:00:00:00:40:D5:FD:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00
[10:48:17][D][uart_debug:114]: <<< 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:1B:1B:01:01:01:01:76:05:01:03:72:65:00:00:50:D4:95:05:AA:15:07:05:63:3B:7C:00:9A:01:62:FC:00:77:01:0B:D0:74:B2:F2:45:1C:8E:70:C7:82:03:FF:51:AA:15:01:00:FF:63:C1:11:1C:8E:70:00:00:00:64:0B:50:02:02:00:72:62:01:65:FF:8F:2A:69:00:84:58:77:FF:FD:63:41:B0:E4:70:62:FE:39:DF:01:77:00
[10:48:17][D][uart_debug:114]: <<< FF:63:41:B0:C4:E4:70:62:00:00:6E:01:77:F4:63:41:00:1C:8E:70:62:04:6F:01:37:08:FF:63:41:FC:00:E4:70:02:00:6E:01:F7:05:FF:63:41:00:C4:E4:70:E2:00:00:6F:01:00:D0:63:41:22:E4:70:02:00:00:79:01:E8:FF:63:01:44:E4:70:FE:80:4A:15:2E:10:08:FF:63:F1:01:C4:E4:70:00:00:71:E1:07:00:FF:01:00:A0:FD:07:30:D1:10:FF:01:55:FF:FE:AE:04:29:07:00:03:FE:55:FF:FE:FF:40:3D:07:00:00:55:FF:FF:50:00:60:05:00:63:41:B0:E1:07:76:05:00:62:00:72:65:A0:2C:B9:00:1B:1A:02:A9:00:00
[10:48:19][D][uart_debug:114]: <<< 00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:1B:1B:1B:1B:01:01:01:01:62:00:72:FD:05:01:07:45:14:06:45:53:F9:B2:05:01:63:0F:C1:A9:E2:00:00:07:01:00:B2:01:07:1B:62:01:65:11:00:80:50:81:C7:FF:A0:04:45:03:40:40:08:FF:2B:65:11:1C:69:00:00:F8:05:77:07:01:05:C1:72:E2:81:89:79:52:00:90:91:9A
[10:48:19][D][uart_debug:114]: <<< 6A:40:28:FF:03:65:11:1C:8E:A8:01:41:8E:03:01:08:02:FF:FF:40:59:44:E4:16:00:00:FE:0A:08:03:FF:00:65:11:1C:EE:40:59:00:00:01:08:04:FF:40:59:44:04:65:00:00:00:50:08:05:0F:40:40:59:44:F4:40:59:00:00:00:40:C8:FF:2B:65:11:1C:65:00:00:F0:12:02:08:07:05:65:11:DC:05:65:00:29:00:02:02:08:88:B1:40:59:44:01:65:00:00:08:01:07:00:2A:55:FF:FD:00:00:15:07:24:E5:55:FF:1D:01:00:29:6D:52:FE:D5:D0:D7:50:00:00:62:1B:52:FE:BB:77:07:01:80:40:40:40:EC:AB:E7:01:00:AA:62
[10:48:21][D][uart_debug:114]: <<< 00:62:FE:0A:71:01:63:B4:B4:B4:A4:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:1B:1B:1B:1B:01:00:AB:62:00:62:A0:76:01:01:80:33:43:0B:06:DA:37:36:76:01:76:05:01:0F:FF:90:95:01:00:50:D4:95:95:57:72:62:01:00:77:07:E1:01:01:01:01:D7:50:01:C1:B0:72:62:01:00:58:24:C5:69:F4:18:01:17:00
[10:48:21][D][uart_debug:114]: <<< FF:63:41:FF:00:E4:74:02:00:3F:16:FE:07:01:01:01:08:2E:AC:65:F1:00:05:65:00:00:01:01:01:C8:9B:89:05:65:52:01:65:00:50:01:01:00:72:62:01:65:FF:1E:52:01:65:00:50:01:01:FC:9B:89:05:05:24:15:65:F0:1D:01:01:01:93:89:05:E5:96:24:15:25:07:01:01:01:B0:72:62:01:01:79:52:01:65:1D:01:02:02:93:89:05:FD:62:1E:52:01:05:D7:50:02:FE:05:93:89:05:79:52:01:E5:D7:50:00:00:62:1B:52:FE:9F:77:07:01:00:01:62:1B:52:CB:01:77:07:01:01:01:62:1B:FF:F6:C3:01:77:07:01:01:62:FF
[10:48:23][D][uart_debug:114]: <<< FF:66:3E:01:07:80:01:01:E1:14:01:63:AC:28:AD:62:80:02:01:00:00:1B:1B:FA:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:76:05:01:FF:01:72:65:00:07:45:53:D9:A8:4D:65:05:00:01:63:96:90:70:4D:01:00:50:77:01:40:D0:74:B2:80:59:44:E4:FE:81:81:C7:82:03:50:D4:95:95:84:00:FF:63:56:C4:E4
[10:48:23][D][uart_debug:114]: <<< F6:0B:00:00:64:1D:01:02:82:C1:72:62:01:00:24:C5:69:3A:14:01:07:01:FF:63:41:FF:11:1C:8E:76:02:50:EC:17:FF:09:FF:63:41:44:E4:76:F2:08:00:6E:01:03:FF:63:C1:00:1C:8E:76:00:00:00:6F:01:21:D0:63:01:44:E4:76:10:00:6E:01:A8:FF:63:FD:2B:C4:E4:16:00:00:6F:F9:08:06:FF:63:45:1C:8E:F6:03:00:00:79:00:40:E8:FF:63:65:11:1C:8E:00:00:29:57:C8:20:08:E8:03:65:11:1C:8E:FE:50:16:00:00:01:00:10:FF:F9:55:FF:FD:15:15:07:00:FF:E1:55:FF:FE:00:29:07:00:52:FE:55:FF:00:01:00
[10:48:25][D][uart_debug:114]: <<< 3D:07:1B:52:FE:55:03:1D:01:00:60:FF:0A:01:63:41:00:05:76:FD:01:62:00:32:05:63:59:E3:09:23:23:20:00:00:00:00:00:0E:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:01:00:00:00:00:E0:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:01:01:05:01:0F:C1:B1:00:00:01:01:FE:4D:65:45:CD:03:40:D0:74:B2:67:00:76:05:62:00:72:E5:01:0B:06:45:00:20:B2:05:72:E4:78:F1:00:00:03:FF
[10:48:25][D][uart_debug:114]: <<< 01:01:FF:56:40:D7:50:AC:C1:72:FE:0C:89:79:12:D6:88:F4:F8:02:02:08:00:7F:65:11:1C:CE:FC:69:00:00:00:77:07:01:01:00:93:89:05:00:79:52:01:00:D7:50:01:C1:72:62:FD:2F:2C:24:15:77:07:01:F1:05:C1:72:62:89:79:52:E1:05:77:07:01:05:C1:72:E2:38:2C:24:15:01:77:07:01:56:C1:72:02:89:79:52:FF:01:77:07:01:AC:C1:72:FA:0C:89:79:12:05:77:07:E1:63:41:B0:72:00:0C:89:79:D2:21:01:77:07:00:63:41:B0:72:72:78:62:1E:00:5C:40:D7:D0:01:01:62:1B:25:65:01:77:FF:FD:01:01:62:B8
[10:48:27][D][uart_debug:114]: <<< 7F:01:F7:04:FF:01:01:FE:FF:68:C1:1D:00:FF:01:00:FF:FF:6D:7E:AB:05:FF:01:0B:01:01:FF:15:01:0F:01:5C:59:00:FE:8D:00:00:00:91:02:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:40:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:00:12:1B:1B:1B:01:01:01:01:00:62:00:72:FD:05:01:07:05:0B:06:45:53:FD:D9:76:01:01:63:0F:C1:B5:E2:00:00:07:01:00
[10:48:27][D][uart_debug:114]: <<< 95:15:07:9B:2E:AC:65:11:00:1D:81:81:C7:01:01:04:45:03:01:01:08:00:FF:10:40:59:44:00:69:00:00:FC:14:77:07:01:05:C1:72:F2:D3:89:79:52:B2:3E:D8:AC:01:08:01:FF:00:65:11:1C:8E:A0:16:41:8E:01:01:08:02:FF:FF:01:65:11:1C:06:59:00:00:FE:40:40:68:07:65:11:1C:FE:54:01:00:00:00:01:08:04:FF:03:65:11:1C:00:65:00:00:00:05:01:08:05:01:40:40:59:44:FC:01:65:00:00:00:40:40:C8:FF:AC:65:11:1C:65:00:00:F8:00:02:08:07:00:58:40:59:44:15:65:00:29:02:02:08:88:62:01:65:11
My esphome yaml is:
substitutions:
  device_name: stromzaehler
  device_description: "Stromzaehler"
  friendly_name: Stromzaehler
esphome:
esp32:
  board:  nodemcu-32s #orig:esp32dev
#  framework:
#    type: arduino
wifi:
  ssid: !secret wifi_ssid
  password: !secret wifi_pswd
  ap:
    ssid: "${friendly_name}"
    password: !secret esp_ap_fb
captive_portal:
web_server:
  port: 80
  auth:
    username: !secret esp_wsrv_usr
    password: !secret esp_wsrv_pswd
# Enable logging
logger:
 hardware_uart: UART1
 baud_rate: 9600
 #level: VERY_VERBOSE
 level: DEBUG
## Bluetooth Test
#esp32_ble_tracker:
#  scan_parameters:
#    interval: 1100ms
#    window: 1100ms
#    active: true
#bluetooth_proxy:
# Bluetooth Test Ende#
# Enable Home Assistant API
api:
  password: !secret esp_api_pswd
  encryption:
    key: !secret esp_api_encrypt_key
ota:
  password: !secret esp_ota_pswd
time:
  - platform: homeassistant
button:
  - platform: restart
uart:
  rx_pin: 22
#  rx_buffer_size: 380
  baud_rate: 9600
  data_bits: 8
  parity: none
  stop_bits: 1
  debug:
    direction: BOTH
#    dummy_receiver: false
#    after:
#      delimiter: "\n"
#    sequence:
#      - lambda: UARTDebug::log_string(direction, bytes);
#sml Test Bus Settings####
sml:
  uart_id: uart_bus
###### Ende SML Bus Settings
#####d0 Einstellungen Test Start #######
#external_components:
#  - source:
#      type: local # original
#      path: custom_components # original
#      #type: git
#      #url: https://github.com/BMOD89/esphome_compontens.git
#      #ref: d0
#    components: [ d0 ]
#d0:
#  id: myd0
#  uart_id: uart_bus
## mampfes d0 OBIS Test ##
#  - source: github://mampfes/esphome_obis_d0
#obis_d0:
#  id: my_sm
#  uart_id: uart_bus
#sensor:
#  - platform: obis_d0
#    name: "Strom Gesamtverbrauch"
#    obis_d0_id: my_sm
#    obis_code: "1-0:1.8.0*255"
#    unit_of_measurement: kWh
#    accuracy_decimals: 4
#    state_class: total_increasing
#    device_class: energy
#    value_regex: "\\d{6}\\.\\d{8}\\*kWh"
#text_sensor:
#    name: "Stromzähler IdentNr"
#    obis_d0_id: my_sm
#    obis_code: "1-0:96.1.0*255"
#    entity_category: diagnostic
#    value_regex: "\\w{14}"
#sensor:
#  - platform: d0
#    name: "Gesamtenergie"
#    d0_id: myd0
#   # server_id: "0123456789abcdef"
#    obis_code: "1-0:1.8.0" #orig: "1-0:1.8.0*255"
#    accuracy_decimals: 1
#  - platform: d0
#    name: "Aktuelle Leistung"
#    d0_id: myd0
#    #server_id: "0123456789abcdef"
#    obis_code: "1-0:16.7.0" #orig:"1-0:15.7.0*255"
#    unit_of_measurement: W
#text_sensor:
#  - platform: d0
#    name: "Hersteller"
#    d0_id: myd0
#    obis_code: "129-129:199.130.3*255"
#  - platform: d0
#    name: "Gesamtenergie Text"
#    d0_id: myd0
#####Ende d0 Test ######
##### Start SML Config    #####
  - platform: sml
    sml_id: sml0
    name: "${friendly_name} Bezug Zählerstand"
    filters:
      - multiply: 0.0001
      - throttle: 30s
  - platform: sml
#  - platform: d0 #war sml
    name: "Bezug Tarif T1 kWh"
    sml_id: sml0
    #d0_id: myd0
    obis_code: "1-0:1.8.1"
    filters:
      - multiply: 0.0000001
      - throttle: 30s
  - platform: sml
    name: "Einspeisung T7 kWh"
    sml_id: sml0
    #d0_id: myd0
    obis_code: "1-0:1.8.7"
    filters:
      - throttle: 30s
  - platform: sml
    sml_id: sml0
    obis_code: "1-0:2.8.0"
    accuracy_decimals: 2
    filters:
      - throttle: 30s
  - platform: sml
    name: "Akt. Leistung Gesamt W"
    sml_id: sml0
    device_class: power
    state_class: measurement
    filters:
      - multiply: 0.01
      - throttle: 10s
#  - platform: sml
#    name: "Akt. Leistung L1 W"
#    sml_id: sml0
#    obis_code: "1-0:36.7.0"
#    accuracy_decimals: 2
#    filters:
#      - multiply: 0.01
#      - throttle: 10s
#  - platform: sml
#    name: "Akt. Leistung L2 W"
#    sml_id: sml0
#    obis_code: "1-0:56.7.0"
#    device_class: power
#    state_class: measurement
#    filters:
#      - multiply: 0.01
#      - throttle: 10s
#  - platform: sml
#    name: "Akt. Leistung L3 W"
#    sml_id: sml0
#    obis_code: "1-0:76.7.0"
#    filters:
#      - multiply: 0.01
#      - throttle: 10s
#  - platform: sml
#    name: "Spannung Phase 1"
#    sml_id: sml0
#    obis_code: "1-0:32.7.0"
#    unit_of_measurement: V
#    device_class: voltage
#    filters:
#      - multiply: 0.1
#      - throttle: 30s
#  - platform: sml
#    name: "Spannung Phase 2"
#    sml_id: sml0
#    obis_code: "1-0:52.7.0"
#    filters:
#      - multiply: 0.1
#      - throttle: 30s
#  - platform: sml
#    name: "Spannung Phase 3"
#    sml_id: sml0
#    obis_code: "1-0:72.7.0"
#    filters:
#      - multiply: 0.1
#      - throttle: 30s
text_sensor:
#  - platform: obis
#    channel: "0-0:96.1.255*255"
#    name: "Serial Number"
#   - platform: sml
#     sml_id: sml0
#     obis_code: "129-129:199.130.3"
#     format: text
#   - platform: sml
#     name: "Server ID"
#     sml_id: sml0
#     obis_code: "1-0:0.0.9"
#     format: hex
##### Ende SML Config####
# Wifi und IP Info
  - platform: version
    hide_timestamp: true
    name: "${friendly_name} - ESPHome Version"
  - platform: wifi_info
    ip_address:
       name: "${friendly_name} - IP Address"
       icon: mdi:wifi
    ssid:
       name: "${friendly_name} - Connected SSID"
       icon: mdi:wifi-strength-2
According to the documentation, your smart meter uses SML-D0. Therefore please try SML (Smart Message Language) — ESPHome
