Esphome pulse S0 Meter into energy dashboard
I have some long time esphome pulse counter for 3 solar strings running that I would like to add to the energy dashboard as seperate systems.
Right now I cannot select them
I have this in esphome;
esphome:
  platform: ESP8266
  board: nodemcuv2
wifi:
  ssid: ""
  password: ""
  ap:
    ssid: "solar"
    password: ""
captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
web_server:
  port: 80
# Sync time with Home Assistant.
time:
  - platform: homeassistant
# Text sensors with general information.
text_sensor:
  # Expose ESPHome version as sensor.
  - platform: version
    name: solar ESPHome Version
  # Expose WiFi information as sensors.
  - platform: wifi_info
    ip_address:
    ssid:
    bssid:
# Sensors with general information.
  # Uptime sensor.
  - platform: uptime
  # WiFi Signal sensor.
  - platform: wifi_signal
    name: solar WiFi Signal
    update_interval: 60s
  - platform: pulse_counter
    pin: GPIO5
    unit_of_measurement: 'kW'
    name: 'Energy solar huis zuid'
    device_class: energy
    state_class: total_increasing
    filters:
      - multiply: 0.06
    pin: GPIO4
    name: 'Energy solar tuinhuis'
    filters:
      - multiply: 0.06
    pin: GPIO14
    name: 'Energy solar oost'
    filters:
      - multiply: 0.06
i already added
in one counter, but to no available
Does it work if you change the units from kW to kWh?
no, no difference
So it doesn’t show up if it has?
UoM: kWh
Could try it as a template sensor I suppose
Something like…
template:
  - sensor:
      - name: "Energy solar huis zuid"
        unit_of_measurement: "kWh"
        state: >
           {{ states('sensor.energy_solar_huis_zuid') }}
