I hope a kind soul will help me. I am fairly new to this whole area of ESP32 and custom sensors so should probably have started with something a little easier but the main project that would help me is to have remote access to the state of my Pylontech batteries. So I decided to try to put together the hardware and integrate using the ESPHome Pylontech integration. I cobbled together what I thought was the appropriate wiring and soldered it up using a MAX3232 RS232 to TTL converter connected to an ESP32.
Following the schematic on the Pylontech Monitoring Github, I made an RJ45 connector with standard T-568B config on one end and then connected Pin 3 (white/green) to IN on the MAX3232 and Pin 6 (green) to OUT on the MAX3232 and finally Pin 8 (brown) to the NEGATIVE on the MAX3232.
Then I connected the TTL side up to the ESP32 and flashed and programmed it using some example YAML I found on this forum. Below is a photo showing the connections and the YAML that I used. Hopefully someone can spot the error that I have made because the device and sensors have been created fine but the device logs are showing NaN errors for the values and in HA all sensors show “unavailable” so clearly something has gone wrong.
substitutions:
friendly_name: Pylontech Monitor
esphome:
friendly_name: ${friendly_name}
min_version: 2024.6.0
name_add_mac_suffix: false
project:
version: '1.0'
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
hardware_uart: UART1
# Enable Home Assistant API
api:
# Allow Over-The-Air updates
ota:
- platform: esphome
# Allow provisioning Wi-Fi via serial
improv_serial:
wifi:
# Set up a wifi access point
ap: {}
# In combination with the `ap` this allows the user
# to provision wifi credentials to the device via WiFi AP.
captive_portal:
dashboard_import:
package_import_url: github://esphome/example-configs/esphome-web/esp32.yaml@main
import_full_config: true
# Sets up Bluetooth LE (Only on ESP32) to allow the user
# to provision wifi credentials to the device.
esp32_improv:
authorizer: none
# To have a "next url" for improv serial
web_server:
uart:
- id: uart_pylontech
tx_pin: GPIO1 # tx pin for pylontech uart
rx_pin: GPIO3 # rx pin for pylontech uart
baud_rate: 115200 # baudrate for pylontech uart
debug:
direction: BOTH
dummy_receiver: false
after:
delimiter: "\n"
sequence:
- lambda: UARTDebug::log_string(direction, bytes);
pylontech:
- id: pylontech0
uart_id: uart_pylontech
update_interval: 20s
- platform: pylontech
battery: 1
voltage:
name: "Battery 1 Voltage"
current:
name: "Battery 1 Current"
coulomb:
name: "Battery 1 Resistance"
temperature:
name: "Battery 1 Temperature"
battery: 2
voltage:
name: "Battery 2 Voltage"
current:
name: "Battery 2 Current"
coulomb:
name: "Battery 2 Resistance"
temperature:
name: "Battery 2 Temperature"
battery: 3
voltage:
name: "Battery 3 Voltage"
current:
name: "Battery 3 Current"
coulomb:
name: "Battery 3 Resistance"
temperature:
name: "Battery 3 Temperature"
battery: 4
voltage:
name: "Battery 4 Voltage"
current:
name: "Battery 4 Current"
coulomb:
name: "Battery 4 Resistance"
temperature:
name: "Battery 4 Temperature"
battery: 5
voltage:
name: "Battery 5 Voltage"
current:
name: "Battery 5 Current"
coulomb:
name: "Battery 5 Resistance"
temperature:
name: "Battery 5 Temperature"
battery: 6
voltage:
name: "Battery 6 Voltage"
current:
name: "Battery 6 Current"
coulomb:
name: "Battery 6 Resistance"
temperature:
name: "Battery 6 Temperature"
unit_of_measurement: W
lambda: |-
auto pwr1 = id(bat1_voltage).state * id(bat1_current).state;
auto pwr2 = id(bat2_voltage).state * id(bat2_current).state;
auto pwr3 = id(bat3_voltage).state * id(bat3_current).state;
auto pwr4 = id(bat4_voltage).state * id(bat4_current).state;
auto pwr5 = id(bat5_voltage).state * id(bat5_current).state;
auto pwr6 = id(bat6_voltage).state * id(bat6_current).state;
auto pwr = pwr1 + pwr2 + pwr3 + pwr4 + pwr5 +pwr6;
id(combined_charge_power).publish_state(max(pwr, 0.0f));
id(combined_discharge_power).publish_state(max(-pwr, 0.0f));
return pwr;
update_interval: 5s
device_class: power
state_class: measurement
- platform: integration
name: "Pylontech charging"
sensor: combined_charge_power
time_unit: h
state_class: total_increasing
device_class: energy
unit_of_measurement: "Wh"
name: "Pylontech discharging"
sensor: combined_discharge_power
time_unit: h
text_sensor:
battery: 1
base_state:
name: "Battery 1 Base State"
voltage_state:
name: "Battery 1 Voltage State"
current_state:
name: "Battery 1 Current State"
temperature_state:
name: "Battery 1 Temperature State"
battery: 2
base_state:
name: "Battery 2 Base State"
voltage_state:
name: "Battery 2 Voltage State"
current_state:
name: "Battery 2 Current State"
temperature_state:
name: "Battery 2 Temperature State"
battery: 3
base_state:
name: "Battery 3 Base State"
voltage_state:
name: "Battery 3 Voltage State"
current_state:
name: "Battery 3 Current State"
temperature_state:
name: "Battery 3 Temperature State"
battery: 4
base_state:
name: "Battery 4 Base State"
voltage_state:
name: "Battery 4 Voltage State"
current_state:
name: "Battery 4 Current State"
temperature_state:
name: "Battery 4 Temperature State"
battery: 5
base_state:
name: "Battery 5 Base State"
voltage_state:
name: "Battery 5 Voltage State"
current_state:
name: "Battery 5 Current State"
temperature_state:
name: "Battery 5 Temperature State"
battery: 6
base_state:
name: "Battery 6 Base State"
voltage_state:
name: "Battery 6 Voltage State"
current_state:
name: "Battery 6 Current State"
temperature_state:
name: "Battery 6 Temperature State"
