ESPHome - RC_switch with DSC sensors
Hello everyone. I’ve been trying to listen to 433 MHz DSC alarm sensors with no luck using the rc_switch platform. Is there any option I’m missing? I’m starting to believe that DSC sensors transmit on a proprietary protocol but I’m not sure.
Thanks!
Have you checked what is received with dump: all?
Have you tried tinkering with tolerance, filter, idle and buffer_size?
I’d suggest starting with least restrictive settings and if you’re seeing noisy signals then trial constraining them until they clean up.
remote_receiver:
  pin: D0
  dump: all
  # Settings to optimize recognition of RF devices
  tolerance: 50%
  filter: 250us
  idle: 4ms
  buffer_size: 2kb
Thanks for the reply. I started to receive many signals only from the Pronto protocol. Could this be because of the constant communication between the DSC panel and its sensors?
Not sure. Do they look consistent or “noisy”?
Maybe paste some samples.
Honestly I’m not enough experienced with RF outputs to determine a noisy output. These are some samples:
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0015 0000 000F 0010 000B 000D 000F 000C 000A 0009 000C 000C 000E 0009 000B 0009 000D 000B 000A 000B 000D 000D 000B 0009 000C 000C 000E 0008 000B 0009 000C 000A 000C 000D 000B 000D 000A 000E 000C 000B 0011 000C 0014 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 001B 0000 000E 0009 000C 000A 000D 000B 000C 000E 000D 000B 000B 0009 000B 0009 000A 000C 000B 000A 000B 000E 000B 0009 0016 0017 0013 000C 000F 0014 003E 000A 000D 0035 000D 000B 004C 0023 000A 0008 000B 000D 000C 000F
[20:35:24][D][remote.pronto:240]: 000A 0008 000A 000A 000B 000E 000C 0009 000A 0009 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0001 0000 0009 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0002 0000 0010 000C 000A 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0001 0000 000B 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0003 0000 000C 000C 000C 000C 0008 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0001 0000 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000B 000C 000B 000C 000F 0010 000E 000F 000B 000D 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 002C 0000 003C 0015 0075 000B 000A 000C 0008 000A 0009 0010 000B 000D 000A 000C 000C 000A 0009 000F 000C 001F 000A 000C 000C 000C 0009 000D 0022 000B 000C 001E 0011 000D 0030 000C 0009 000C 000A 0011 0008 000D 000F 001D
[20:35:24][D][remote.pronto:240]: 0041 000B 000A 000C 000B 000D 0019 000F 0009 0013 000B 000B 0008 000C 000D 000C 0009 000D 000C 000B 000E 000B 0008 000A 000B 000F 0009 000C 000A 000E 0009 000B 000A 000A 000A 000A 0009 000D 0009 0027 0009 000B 000A 0012 000B 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0013 0000 000C 000A 000B 000F 000E 000B 000C 000B 0009 000B 000E 000D 000B 000C 0010 000F 000B 000E 0009 005D 0012 0027 000F 001C 000E 001A 000E 000D 000B 000E 000B 0021 0008 000C 000B 000A 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 000E 0008 000F 008D 000B 0008 0016 000C 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0009 0000 0015 0011 000E 000B 000C 000B 000B 000D 0009 0010 0010 0015 0019 0013 002D 000E 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0014 0000 000B 000C 000E 0009 000A 0009 000C 000D 000D 000C 0010 0008 000B 000C 000B 0009 000A 0017 0010 001B 0068 000A 002E 002C 000C 000C 000C 0009 0013 000E 000D 0012 000B 000B 000D 000E 000A 000C 000B 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000F 000C 0022 0063 005C 000A 000F 0009 0019 000E 000C 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000B 0015 0009 0018 0052 0010 005D 000D 000D 000E 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000C 000B 000B 000C 0011 000C 000A 0017 0040 0043 003F 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0002 0000 000F 000D 000B 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0019 0000 000A 000B 000A 0011 0012 000E 000A 000C 000B 000B 000B 000A 000B 0010 000B 000C 000C 000C 0023 001B 0028 0012 001E 0012 004B 0050 0027 000C 000F 0010 0012 000E 0009 000B 000B 000C 000D 000C 000B 000C 000B 000B
[20:35:24][D][remote.pronto:240]: 000A 000A 000A 000C 000D 000D 000A 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000D 000E 000F 0016 0009 000E 000C 000A 000B 000C 000C 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0007 0000 000B 000D 0010 000C 000B 0010 000D 0009 000A 000A 000B 0009 000F 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0004 0000 000D 0009 000D 000D 000A 000B 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 0012 005A 0009 000C 0038 000D 0008 0014 000D 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 0012 000D 0009 000E 000A 000E 000A 000F 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 000B 000A 0011 0009 0010 000D 000B 000D 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0014 0000 001D 000C 000A 0022 004E 000C 000A 000B 0009 0011 000F 000B 000B 0010 0018 000C 000A 000C 000B 000B 000C 000D 000F 000C 0009 000A 000B 000D 0009 0010 0009 000B 000D 000D 0009 000C 000B 000E 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0003 0000 0015 000D 000B 002A 0010 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000E 000B 0008 000D 000A 0012 000B 000B 0009 0010 0009 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 000A 0000 0009 000D 000A 000B 000A 000B 000D 000D 000E 000A 000A 0015 002B 002F 0069 000C 000A 000A 0011 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 000D 000C 000B 000A 0009 0010 000A 0036 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0004 0000 000A 000C 000E 000C 000B 000A 000B 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0002 0000 000A 000B 000F 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0007 0000 000F 0010 0021 004C 000B 000A 000C 0008 000A 000F 000D 0008 000A 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0013 0000 000A 0016 000C 000B 000B 000C 000E 000C 0012 0011 0025 0014 0072 0009 000B 000A 000E 000A 000B 000F 000C 0013 000F 000F 000D 0009 0011 000D 000B 0009 000B 000B 000B 000C 000D 0009 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0014 0000 000C 0010 000B 000B 0011 000D 000A 0011 000A 000B 000A 000B 000B 000C 0008 000D 0009 000A 0009 000D 000C 000A 000B 000D 000A 000D 000B 000E 000D 000C 000D 000D 0010 000D 0008 000B 0013 000A 000E 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0019 0000 0009 000E 0011 0016 000A 000A 000C 000E 000B 000C 000C 000E 000D 000A 0009 000C 000A 000F 0012 000F 0015 001B 004A 0021 000A 000B 0009 000D 000A 0014 0016 000C 000C 000B 000C 000E 0009 000C 000E 000C 000D 000E
[20:35:24][D][remote.pronto:240]: 000D 000B 000C 000A 000B 000A 000A 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 000E 0000 0009 000C 0010 000F 0008 000B 000A 0011 0009 000B 000C 000E 000B 0011 000A 000C 000B 000E 000A 000B 0021 001B 0050 0016 0009 000C 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0010 0000 000B 0014 000A 000B 000B 000C 000D 0009 000C 0009 000E 000A 000B 000A 000D 000B 0012 0010 000E 001E 0079 0009 000F 000B 000B 000A 0017 0012 000E 000A 0012 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0012 0000 001D 0009 000A 0008 000B 000E 0011 0028 0079 000D 000D 0011 0010 000B 000D 000A 0010 000C 0015 000A 000C 000C 000E 0009 000D 0008 000C 000F 0011 000B 000F 0008 000B 000D 000B 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0003 0000 000C 000F 000E 0009 000D 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0004 0000 000D 000C 000D 000A 000D 000A 0010 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000C 0009 000D 000A 000A 000B 000B 000C 0010 0018 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0014 0000 0009 001B 0019 0018 000B 000D 0009 000E 000B 000A 000D 000A 000D 000C 0009 000E 000A 000C 000E 000D 000C 000C 0009 000A 000A 000A 000D 000B 000C 000D 000D 0010 0009 000A 0009 0012 000C 0019 0017 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0002 0000 0009 000B 000D 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0015 0000 0010 000B 000D 000E 000E 0009 000A 000E 000C 0009 000B 000A 000A 000A 000D 0008 000B 0009 000E 0008 000C 000D 000C 0010 000B 0010 000B 000D 000A 0008 000A 0009 000A 0009 000A 000B 0010 000A 0014 000B 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 0009 000F 0086 0013 000B 003B 000C 000B 000B 000E 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0001 0000 000A 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0008 0000 0010 0009 0010 0009 000B 000A 000D 0009 0011 0009 000E 000A 000F 0018 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0003 0000 0015 000E 000B 000C 0009 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000F 000B 0009 0011 0013 000D 0011 000B 000D 000A 0010 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0015 0000 000C 0014 0014 0018 0014 005E 000A 000A 0009 000A 0010 000D 000E 0010 0010 000A 0009 000E 0009 0017 000D 000E 0011 000F 0008 000A 000D 000C 000A 000D 000A 000B 000A 000D 000E 000A 0009 0013 000A 000B 000C 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 0029 0000 0008 000B 000F 000B 0011 000B 0009 0010 0008 000D 000A 000A 0011 000B 000A 000A 000B 0012 000C 0011 000A 0011 0009 000D 000F 0010 000E 0017 000A 000B 0019 001B 0060 000B 000A 000F 000A 000F 0013 000A 0009 000A
[20:35:24][D][remote.pronto:240]: 0009 0010 000A 000C 000B 000B 0008 000C 0009 000A 000B 000C 0008 000B 0009 000A 000E 0010 000B 000F 0009 000C 000F 000C 0008 000E 000F 000C 0009 000D 000F 0010 000A 000D 000E 006A 000B 000A 06C3
[20:35:24][D][remote.pronto:238]: Received Pronto: data=0000 006D 000C 0000 0019 0009 002B 0009 000C 001A 0016 000F 0014 000E 000C 0009 000A 0008 000C 000C 000C 000A 000C 0009 000D 000A 000D 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0024 0000 000C 002B 000B 000F 000C 000A 000C 000A 000E 000B 000E 000E 0035 0095 000E 000C 0011 000E 0024 0009 000F 000C 000C 0009 000C 0009 000B 0009 000D 000C 000B 000B 000C 000B 000D 0008 000C 0008 000D 000C 000A 000B
[20:35:25][D][remote.pronto:240]: 0011 0013 000B 000D 0018 0032 001A 000A 0014 000D 000D 001F 003D 000B 000B 0008 000B 000C 000A 0009 000C 0009 000C 000D 000A 0009 000C 0008 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 000C 0000 0009 000C 0009 000C 0009 000A 000C 000A 000A 000F 0009 000A 0008 0014 0010 0010 0011 0026 0038 0056 0034 000B 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0009 0000 000D 0009 000E 000B 000A 0008 000C 000A 000A 000A 000B 0009 000B 001F 0017 0034 0032 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0002 0000 000A 000D 000E 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 000B 0000 0018 0009 0017 001C 0013 0052 000A 000E 000D 000D 000A 000A 0011 000B 000F 0009 000A 000D 000C 000C 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0008 0000 0008 000C 000A 000B 000E 0014 0016 000C 0009 0053 000B 000A 0009 000B 000C 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 0009 000A 000F 000B 000F 000C 000E 000E 000A 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 000E 0000 000C 000A 000E 000B 000A 000B 000B 000C 000A 000B 000D 000E 0008 000B 0009 000B 000B 000C 000D 0012 0014 0010 0014 0040 000E 0010 000D 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0003 0000 0008 000B 000C 000D 000B 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 000F 0047 0008 000B 000D 000E 000A 0010 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 0014 0009 000B 000D 000A 0008 000E 0010 000F 0008 0029 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0004 0000 000D 000B 000C 0009 000C 0011 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 000C 0000 0008 000F 0009 000C 000B 000C 000A 000D 0009 0013 000E 000E 0008 0011 000D 000D 000E 0075 003A 000A 000E 000D 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 000D 0000 001F 0009 000C 0014 000D 0009 0011 000D 000A 000F 001D 0047 0068 000C 0010 0010 0010 000E 000F 000E 000A 000E 000C 000C 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0003 0000 0009 000C 000A 000E 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0008 0000 000D 0009 000A 0012 000C 0009 000B 000B 000F 0009 000E 0009 000B 000A 000E 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 000D 0000 001C 000F 0048 000B 000C 000B 000C 0008 000B 000B 000D 000A 000B 000C 000B 000A 000A 000E 000A 000A 000B 000C 000F 000B 0011 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0002 0000 002D 000A 000A 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000C 000C 0011 0008 000D 0009 000C 000A 0012 000B 000C 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0001 0000 000B 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 0011 000D 000E 000F 000C 000B 0014 000A 0010 0009 000C 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0001 0000 000C 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 000A 0000 0019 0012 0059 000A 000C 000B 000C 000C 000D 000A 000A 0008 000B 0008 000F 000B 000C 000A 000B 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0008 0000 0010 0015 000A 0024 0067 0009 000C 000B 000D 0009 000B 000A 000C 000A 000E 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0002 0000 000C 0010 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0008 0000 0013 000B 0010 000D 0008 000B 000B 000B 000A 000B 000B 000A 0008 000E 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0016 0000 0028 0013 004D 000C 000B 000C 000F 000E 000F 000A 000A 000E 000B 000E 000D 000B 000D 0009 000B 000A 000C 000B 000C 000A 000A 000B 000B 000B 000B 000C 000E 0010 0014 000A 000E 0009 000B 0010 000B 000C 000C 0009
[20:35:25][D][remote.pronto:240]: 000A 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 000C 000A 000E 0009 000C 000B 000A 000A 000A 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0001 0000 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0014 0000 000A 000D 000F 000A 0011 000B 000A 000C 0009 000A 000B 000D 0009 000D 000A 0012 000E 0018 000C 001F 0060 000E 0009 000C 000C 000B 000E 000B 000A 000C 0018 001A 000B 000B 000C 000D 000F 000C 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0008 0000 000B 000D 000D 0008 0012 0011 000A 000C 000D 000A 000B 0015 001B 0009 000D 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 000E 0000 000C 0008 000E 000F 0016 0009 0098 000D 0022 0017 000D 0009 000B 000E 000D 0014 000E 001A 0010 0013 000B 000F 000C 000B 000D 000A 000C 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 000D 0000 0013 001D 0012 002D 004F 0025 0021 000F 000F 000B 000C 0009 000A 000C 000E 0015 0012 0010 000A 000E 000E 000B 000B 000C 000B 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 001B 0000 0014 000D 000D 0017 000F 0030 006D 000A 0017 000B 000D 000C 000A 000D 000C 0009 000B 000B 000C 000A 000A 0009 000B 000D 000B 000E 000D 0013 000E 001C 0039 000B 0038 0028 000C 000B 000F 001E 000A 000B 000D 0019
[20:35:25][D][remote.pronto:240]: 0014 000D 0012 000F 000D 0009 000D 000A 000C 000C 000C 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0003 0000 0011 000F 000B 000E 0013 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0011 0000 000F 0009 000B 000B 000F 000B 000B 000C 000C 000B 000B 000C 000C 000F 000C 000A 000C 000F 0013 000A 000F 000A 000B 000A 0046 000C 000F 001A 0033 0015 0013 000B 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 000A 0011 000D 0010 0009 000B 0031 0013 0009 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0012 0000 000D 000F 0009 0016 000E 003C 0009 0020 0016 000D 000C 0010 000B 000E 002D 000C 000C 000B 000B 000A 000F 000B 0008 000E 0010 000A 0009 000A 000D 0014 0009 0011 000B 000E 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0011 0000 000C 000A 000B 0010 000C 0009 0010 000C 000C 000F 000B 0009 000A 0008 000E 000C 000B 000B 000B 000C 000B 0010 000C 0009 000D 003C 000E 000B 000D 000A 000A 0015 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0012 0000 0023 0011 000A 000F 003D 000B 002A 0012 0012 0021 0036 000F 000A 0010 000A 0012 000D 000B 000F 000B 0012 000D 000A 001A 000B 000C 000D 000B 0008 000B 000E 000A 0009 000A 0009 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0013 0000 000E 000B 000A 000B 000B 000A 000B 000F 000B 000D 0009 000D 000B 000F 000B 000E 0010 000D 0010 000D 0085 000D 000F 000C 0009 000E 0009 000D 0010 001F 0017 0010 0032 002A 0009 000B 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0013 0000 0011 0009 000C 0012 000B 000A 001D 0035 000B 000B 0012 000A 000C 000B 000A 000C 000A 000C 000D 000C 000A 000C 000E 000B 001E 000D 000C 000D 000B 0014 000D 000A 0011 000B 0027 0013 008F 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0014 0000 000B 000A 0018 000A 000F 000A 000B 0009 0015 0008 000D 000C 000E 0009 000E 0008 000C 000E 000C 000C 000C 005A 000D 0011 000D 000D 002F 000F 0022 0019 000F 0015 000B 000C 0014 000E 0011 0008 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0015 0000 000B 000F 0012 0011 000A 0020 000F 0016 0020 000D 000B 0014 000A 002E 000C 000B 0008 000C 000D 001D 0014 000A 000B 000E 000E 0014 000A 000A 000C 000C 000D 000E 0011 000F 000C 000B 000A 000B 0008 000B 000A 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 001B 0000 000B 000A 001E 000F 000A 000E 0015 000B 000D 000B 000A 000E 000C 000A 000B 000B 000A 000A 0008 000F 0009 000E 0010 001D 0016 001E 0010 000B 000C 002B 000A 000B 0020 0025 0009 000E 0009 000B 0009 0010 000C 000B
[20:35:25][D][remote.pronto:240]: 0008 000A 000C 000E 000A 000C 0009 0011 000B 000C 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0002 0000 000A 000C 000A 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0001 0000 0010 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0003 0000 000A 0011 000B 0009 001A 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000C 000C 000D 000B 000B 000F 000C 000B 000E 000A 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 002C 0000 0028 0011 000A 0008 000B 000D 001D 0010 000A 000E 0010 000B 000C 000C 0012 0011 000F 000A 000C 000C 000B 0009 000D 0013 000B 000E 0010 000B 000B 000C 000F 000B 000B 0009 0014 0014 000D 000D 0010 0012 005E 0009
[20:35:25][D][remote.pronto:240]: 000C 000D 000D 0008 000A 0009 000E 0008 000C 0009 000B 000A 000A 0009 000B 000B 000D 0008 0011 000A 000A 000C 0010 0008 000C 000A 000E 000A 000A 000A 000C 0009 000E 000C 000A 000A 000D 000E 000C 000E 0011 0009 0021 0012 006D 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0013 0000 000D 001B 000F 000D 000C 000A 000B 000C 000E 000C 000C 000F 000C 000B 000B 000B 000A 000A 000E 000D 000A 0009 0011 000C 0019 0011 000E 0018 000C 0009 000D 000C 000C 000C 000D 0009 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 0019 000F 000C 0015 000F 000A 000B 000F 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0009 0000 0019 0008 000E 000A 000D 0061 001B 001B 0014 0012 000B 0009 0010 000B 000D 000C 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0014 0000 0009 001D 0010 0015 000B 0010 0009 0010 0016 0012 0009 0010 0015 0013 0023 000A 0021 000B 0009 000B 0009 000D 000C 000C 0010 0015 000E 000E 000E 000D 0009 000A 000A 000B 000A 000B 000C 000E 000A 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000C 0012 000E 000C 0012 000B 000D 000B 000B 000C 0009 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000D 0009 000B 0009 000C 000D 000E 0008 000B 000B 06C3
[20:35:25][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000C 000E 000E 0010 000A 000B 000B 0013 000F 000C 000B 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0002 0000 000A 000E 000D 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0019 0000 000B 0012 000C 0009 0012 000B 000D 000A 000B 0009 000B 0011 001E 0019 000A 0016 000B 000A 000F 0019 000C 000B 001D 0009 0011 000F 000F 000F 000C 000D 0011 000B 000B 000E 0011 0008 0011 000A 000D 000A 0010 0009
[20:35:26][D][remote.pronto:240]: 000C 0008 0010 000A 000E 0011 001D 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 0016 000C 000C 000A 000A 0009 000D 0009 000B 000C 000D 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0001 0000 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0007 0000 001B 0011 0027 000C 0020 004E 002F 002A 000A 000E 000D 000F 0014 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0004 0000 000D 000F 000A 000D 000C 000E 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 000B 0012 000B 000A 000D 000A 000E 000D 000C 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 0015 0008 0017 0066 0014 000B 000D 000B 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 0008 000C 000B 000A 000A 000A 0009 000C 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0014 0000 000B 0009 000B 0009 000C 000E 000C 000C 000B 0008 0010 0009 000D 000A 000D 000B 000A 000C 000A 000B 000C 0009 000C 000B 000D 000A 0011 0009 0011 000A 0011 0009 000E 0008 0010 0015 0010 000E 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0003 0000 000F 000B 000D 0009 0019 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000B 000A 000A 000C 000B 000B 0010 0010 000B 000B 0014 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 000A 0000 000D 000D 000D 000B 000D 000D 000A 0009 000C 000C 000B 0009 000E 000B 0010 0009 000B 000D 000C 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0005 0000 000C 000A 0010 000B 000C 000C 000E 000C 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0004 0000 0012 000F 0009 000D 000C 0012 0015 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0002 0000 0008 000A 000A 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0007 0000 0010 000D 0010 000B 0017 000C 0012 000F 0027 001C 001A 0018 000D 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0013 0000 0012 0017 000A 000A 0009 0015 0011 000C 0011 0014 0008 000C 000C 000C 0009 0010 000A 000C 000B 000B 000A 000C 000B 000E 0009 000C 000B 000A 000A 000E 000C 000A 000A 0010 000D 000B 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0014 0000 000D 000E 000C 000B 0011 000B 000C 000A 000E 000E 000B 000A 000E 000A 000D 000D 000C 0009 000C 000B 000F 000C 0011 000B 000A 000A 000B 000B 000C 0019 000A 000A 0018 0015 0061 000A 000A 0008 000A 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0019 0000 0015 001F 000C 000A 000B 000B 000F 0008 000D 000D 000D 000B 000C 000C 001D 0049 000B 000A 000C 000D 000D 000B 0017 000C 000C 0010 000A 0021 0010 000F 000F 000A 000E 001A 000D 000D 000F 000B 0012 0009 000A 0009
[20:35:26][D][remote.pronto:240]: 000A 000B 0044 000A 0010 000A 000A 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 000E 0000 000B 000A 0014 000A 000B 0009 0011 0009 000C 0009 000C 000C 000C 000A 000D 000A 000B 000C 000B 0011 000E 0026 0032 000E 000C 0009 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0010 0000 0009 001A 000A 000C 0009 0046 001A 002A 0038 000B 000E 000E 0009 000D 0014 0011 000C 0014 0011 0010 0013 000E 000C 000D 000A 000B 000A 000F 000A 0010 000F 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0012 0000 000D 0017 0011 000B 001A 0047 0015 000C 000B 0018 0018 0010 000D 000D 000B 000B 0009 000B 000C 000A 0009 000E 0008 000D 000F 000B 000E 000C 000A 0010 000B 000B 000C 000C 000E 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0003 0000 0009 000A 000D 0010 0011 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0004 0000 000F 0017 000B 000E 0008 000D 0018 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 000A 000F 0009 000F 000E 0011 000A 000B 0009 000A 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0011 0000 0011 0014 000B 0010 000E 000D 000B 0008 000E 0009 000D 000B 000B 0008 000D 000F 000A 000E 000C 0009 0014 000A 000B 000F 0013 001B 0018 0008 000F 000E 000B 0014 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0004 0000 000A 000A 000F 000C 000C 000B 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0002 0000 0020 0015 000A 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0015 0000 001B 000F 0009 000B 000B 000B 0009 000B 000A 000A 000B 000C 0009 000C 000C 000E 0008 0011 000D 000D 000A 0014 001B 001F 0013 0017 0009 0015 000F 0012 000C 000A 000D 000B 0009 0010 0009 000B 000A 000E 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 0015 0015 0015 0053 000F 0009 000C 000B 002B 000B 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0001 0000 000B 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0008 0000 000D 000A 000D 000D 000B 0010 0024 0021 000C 0010 0010 0018 000C 0010 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0003 0000 000C 0009 000B 0009 000A 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0006 0000 0014 000F 000D 000A 000C 000C 000C 000A 000D 0008 000D 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0015 0000 000C 000B 000A 0009 000A 000F 000A 0009 0012 000E 000B 0016 000F 000F 000D 000B 000E 000A 0010 000D 000F 000E 0012 0013 0012 000A 000D 0012 000E 000B 000B 000A 000D 000B 0065 0009 000C 000B 000D 000B 000B 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0029 0000 0010 002F 000B 000B 000D 0013 000A 007F 000C 000C 0011 000C 0015 000A 000C 000D 000A 0015 000E 0010 000B 0008 000B 000A 000C 0008 000C 0009 000C 0009 000C 000B 000D 000B 000C 0009 0010 0009 000B 0010 000A 000F
[20:35:26][D][remote.pronto:240]: 0012 0012 000D 0029 000C 000C 000F 0016 001A 0028 000D 000D 000D 000A 000F 0025 000A 0009 000C 000D 000A 0014 000C 000A 000A 000A 000D 000B 000B 000A 000A 000C 000C 000A 000E 000A 000E 000A 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 000C 0000 000B 000A 0009 0015 000B 000B 000D 000E 000E 000B 000D 0013 000B 000D 000A 000A 0009 000B 0009 000A 0009 000D 000C 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0024 0000 0009 000E 000B 001F 000C 000F 000B 000D 000A 000C 000A 000D 0009 000D 000D 000A 000B 000E 000C 0014 000C 003E 002B 000E 000A 000B 0056 0014 000A 000A 0009 000C 000D 000C 000B 000C 000C 000F 0009 000B 0009 000D
[20:35:26][D][remote.pronto:240]: 000B 000E 0009 000C 0008 0011 000B 000E 0009 0010 0017 0011 000B 000E 000C 000C 0023 0011 000F 0016 0010 001E 0010 0010 000F 0038 0014 000D 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 000C 0000 000F 0014 000D 000C 000F 000D 0011 0009 000B 0010 0010 000A 000E 000E 0028 001C 000C 000C 000D 0011 000A 0013 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0009 0000 000B 0013 000B 000F 0034 000E 000E 0012 0018 0010 000E 000F 0010 000A 000A 000A 001A 06C3
[20:35:26][D][remote.pronto:238]: Received Pronto: data=0000 006D 0002 0000 000D 000D 000B 06C3
Any thoughts?
Thanks!
I’m not sure either.
I wouldn’t have thought there would have been too large a volume of regular signals being sent, but I don’t know much about these things either. I suspect you’ve got a fair bit of noise there, as there are a lot of irregular signals, as opposed to very consistent ones.
It’s quite typical to have a lot of background noise when dumping raw at least.
Some security sensitive applications (like car remotes) use “rolling codes” which can complicate things.
I found this on a quick search but not sure how much use it is.
Not sure I can offer much more help.
You could try understanding and playing with these settings now and see if your pronto signals clean up. But you may have some kind of proprietry protocol.
  tolerance: 50%
  filter: 250us
  idle: 4ms
  buffer_size: 2kb
