logger:
baud_rate: 0
level: DEBUG
uart:
baud_rate: 2400
tx_pin: 16
rx_pin: 17
debug:
direction: BOTH
dummy_receiver: true
after:
delimiter: "\r\n"
sequence:
- lambda: |-
UARTDebug::log_string(direction, bytes);
float s1=0;
float s2=0;
float s3=0;
float s4=0;
float s5=0;
float s6=0;
float s7=0;
float s8=0;
float s9=0;
float s10=0;
float s11=0;
float s12=0;
float s13=0;
float s14=0;
float s15=0;
float s16=0;
float s17=0;
float s18=0;
float s19=0;
float s20=0;
float s21=0;
float s22=0;
float s23=0;
float s24=0;
std::string str(bytes.begin(), bytes.end());
if (sscanf(str.c_str(), "(%f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f %f", &s1, &s2, &s3, &s4, &s5, &s6, &s7, &s8, &s9, &s10, &s11, &s12, &s13, &s14, &s15, &s16, &s17, &s18, &s19, &s20, &s21, &s22, &s23, &s24) ) {
id(inverter_1).publish_state(s1);
id(inverter_2).publish_state(s2);
id(inverter_3).publish_state(s3);
id(inverter_4).publish_state(s4);
id(inverter_5).publish_state(s5);
id(inverter_6).publish_state(s6);
id(inverter_7).publish_state(s7);
id(inverter_8).publish_state(s8);
id(inverter_9).publish_state(s9);
id(inverter_10).publish_state(s10);
id(inverter_11).publish_state(s11);
id(inverter_12).publish_state(s12);
id(inverter_13).publish_state(s13);
id(inverter_14).publish_state(s14);
id(inverter_15).publish_state(s15);
id(inverter_16).publish_state(s16);
id(inverter_17).publish_state(s17);
id(inverter_18).publish_state(s18);
id(inverter_19).publish_state(s19);
id(inverter_20).publish_state(s20);
id(inverter_21).publish_state(s21);
id(inverter_22).publish_state(s22);
id(inverter_23).publish_state(s23);
id(inverter_24).publish_state(s24);
# AC IN
device_class: voltage
unit_of_measurement: 'V'
device_class: frequency
unit_of_measurement: 'Hz'
# AC OUT
device_class: apparent_power
unit_of_measurement: 'VA'
device_class: power
unit_of_measurement: 'W'
# BUS
unit_of_measurement: '%'
# BATTERY
device_class: current
unit_of_measurement: 'A'
device_class: battery
# TEMPERATURE
device_class: temperature
unit_of_measurement: '°C'
# PV
# BATTERY
button:
on_press:
- uart.write: [0x51, 0x50, 0x49, 0x52, 0x49, 0xF8, 0x54, 0x0D]
on_press:
- uart.write: [0x51, 0x50, 0x49, 0x47, 0x53, 0xB7, 0xA9, 0x0D]
interval:
- interval:
seconds: 30
then:
# Send QPIGS
Thats part of new code
But i dont like the output
[D][uart_debug:158]: >>> "QPIGS\xB7\xA9\r"
[D][uart_debug:158]: <<< "(235.0 50.1 235.0 50.1 0000 0000 000 303 03.00 000 000 0017 00.0 000.0 00.00 00000 00010000 00 00 00000 011 0 00 0000\x98n\r"
[D][sensor:094]: 'inverter_ac_in_voltage': Sending state 235.00000 V with 1 decimals of accuracy
[D][sensor:094]: 'inverter_ac_in_frequency': Sending state 50.10000 Hz with 1 decimals of accuracy
[D][sensor:094]: 'inverter_ac_out_voltage': Sending state 235.00000 V with 1 decimals of accuracy
[D][sensor:094]: 'inverter_ac_out_frequency': Sending state 50.10000 Hz with 1 decimals of accuracy
[D][sensor:094]: 'inverter_ac_out_apparent_power': Sending state 0.00000 VA with 1 decimals of accuracy
[D][sensor:094]: 'inverter_ac_out_active_power': Sending state 0.00000 W with 1 decimals of accuracy
[D][sensor:094]: 'inverter_bus_utilization': Sending state 0.00000 % with 1 decimals of accuracy
[D][sensor:094]: 'inverter_bus_voltage': Sending state 303.00000 V with 1 decimals of accuracy
[D][sensor:094]: 'inverter_battery_voltage': Sending state 3.00000 V with 1 decimals of accuracy
[D][sensor:094]: 'inverter_battery_ac_charging_current': Sending state 0.00000 A with 1 decimals of accuracy
[D][sensor:094]: 'inverter_battery_capacity': Sending state 0.00000 % with 1 decimals of accuracy
[D][sensor:094]: 'inverter_temperature': Sending state 17.00000 °C with 1 decimals of accuracy
[D][sensor:094]: 'inverter_battery_pv_charging_current': Sending state 0.00000 A with 1 decimals of accuracy
[D][sensor:094]: 'inverter_pv_in_voltage': Sending state 0.00000 V with 1 decimals of accuracy
[D][sensor:094]: 'inverter_battery_voltage_scc': Sending state 0.00000 V with 1 decimals of accuracy
[D][sensor:094]: 'inverter_battery_discharge_current': Sending state 0.00000 A with 1 decimals of accuracy
[D][sensor:094]: 'inverter_17': Sending state 10000.00000 with 1 decimals of accuracy
[D][sensor:094]: 'inverter_21': Sending state 0.00000 with 1 decimals of accuracy
[D][sensor:094]: 'inverter_18': Sending state 0.00000 with 1 decimals of accuracy
[D][sensor:094]: 'inverter_19': Sending state 0.00000 with 1 decimals of accuracy
[D][sensor:094]: 'inverter_20': Sending state 0.00000 with 1 decimals of accuracy
[D][sensor:094]: 'inverter_23': Sending state 0.00000 with 1 decimals of accuracy
[W][component:232]: Component uart took a long time for an operation (369 ms).
[W][component:233]: Components should block for at most 30 ms.
[D][uart_debug:158]: <<< "(NAKss\r"
Why i get multiple “(NAKss\r” replay back? Do i send something more?
Or esp32 is too slow for that? and will be better to pass that string to nodered?
