ESPHome Renogy smart Battery 12v 100AH configuration
Hi there,
I’ve been troubleshooting this all day, but finally got it working!
I ordered a Renogy smart LFP battery for my van/RV and ordered the one WITHOUT bluetooth! Since I don’t want to have a app that monitors my battery, I want a local esphome solution.
After a lot of learning, and using ChatGPT as my personal modbus tutor I finally got it working. Below you’ll find the config, and I’m just posting for anyone else wanting to run ESPHome to monitor a Renogy battery.
Required hardware:
Required tools:
  • RJ45 pliers/cutters to create a connections
  • Dupont cables
  • Screwdriver
I might add a wiring diagram later using fritzing, but for now I’m done sitting behind my laptop haha.
With the help of the following sources:
https://github.com/Grmume/renogy-smart-battery/files/8134043/Lithium.Iron.Battery.BMS.Modbus.Protocol.V1.7.zh-CN.en.1.pdf
ESPHome code:
esphome:
  friendly_name: Renogy Battery
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
web_server:
  port: 80
  local: true
# Enable Home Assistant API
api:
ota:
  password: ""
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "renogy-battery Fallback Hotspot"
    password: ""
captive_portal:
uart:
  tx_pin: 16
  rx_pin: 17
  baud_rate: 9600
modbus:
  flow_control_pin: 5  # This is the DE/RE pin on the MAX485
modbus_controller:
  - id: renogy
    ## the Modbus device addr
    address: 0xF7
    modbus_id: mod_bus
    setup_priority: -10
    #update_interval: 5s
  - platform: modbus_controller
    modbus_controller_id: renogy
    address: 0x1388
    register_type: holding
    value_type: U_WORD
    unit_of_measurement: ""
    address: 0x13b3
    value_type: U_WORD
    unit_of_measurement: "V"
    accuracy_decimals: 1
    filters:
      - multiply: 0.10
    name: "Cell Voltage 1"
    address: 0x1389
    value_type: U_WORD
    filters:
      - multiply: 0.10
    name: "Cell Voltage 2"
    address: 0x138a
    value_type: U_WORD
    filters:
      - multiply: 0.10
    name: "Cell Voltage 3"
    address: 0x138b
    value_type: U_WORD
    filters:
      - multiply: 0.10
    name: "Cell Voltage 4"
    address: 0x138c
    value_type: U_WORD
    filters:
      - multiply: 0.10
    name: "Cell Temp 1"
    address: 0x139a
    value_type: U_WORD
    unit_of_measurement: "°C"
    filters:
      - multiply: 0.10
    name: "Cell Temp 2"
    address: 0x139b
    value_type: U_WORD
    filters:
      - multiply: 0.10
    name: "Cell Temp 3"
    address: 0x139c
    value_type: U_WORD
    filters:
      - multiply: 0.10
    name: "Cell Temp 4"
    address: 0x139d
    value_type: U_WORD
    filters:
      - multiply: 0.10
    address: 0x13b2
    value_type: U_WORD
    unit_of_measurement: "A"
    address: 0x13b4
    value_type: U_WORD
    unit_of_measurement: "Ah"
    address: 0x140a
    value_type: U_WORD
button:
  - platform: restart
