so it appears that in 2023.4.2 the todoist integration is broken again. I’ve done a restore, back to 2023.3.6 but now I cant get access to the whole config folder (It appears it only did a partial backup before the last update). Ill have to restore back to the broken todoist version to get everything working. But hopefully this is enough info FML lol
sensors:
esphome_to_do:
friendly_name: "ESPHome Alexa To-Do"
value_template: '{{states.calendar.alexa_to_do_list.attributes.all_tasks | replace(''['','''') | replace('']'','''') | replace("''","")}}'
sensors:
epshome_shopping_list:
friendly_name: "ESPHome Alexa Shopping List"
value_template: '{{states.calendar.alexa_shopping_list.attributes.all_tasks | replace(''['','''') | replace('']'','''') | replace("''","") }}'
So I have a value template for each that removes brackets , and the ’ and outputs that to a new entity that the ESPhome.yaml uses, looks like
As you can see we have “stuff 1” though “stuff 4” but when looking at the actual display the first entry is missing, the order is also reversed, but that does not matter (you can see this for both the to do list and the shopping list).
And lastly here is the code I have in the esphome.yaml. I’ve just sanitized it a little, but everything important is there.
esphome:
on_boot:
priority: 200.0
then:
- component.update: eink_display
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Global variables for detecting if the display needs to be refreshed. (Thanks @paviro!)
globals:
- id: data_updated
type: bool
restore_value: no
initial_value: 'false'
- id: initial_data_received
type: bool
restore_value: no
# Include custom fonts
font:
- file: fonts/materialdesignicons-webfont.ttf
glyphs:
- "\U000F0590" # weather-cloudy
- "\U000F0F2F" # weather-cloudy-alert
- "\U000F0E6E" # weather-cloudy-arrow-right
- "\U000F0591" # weather-fog
- "\U000F0592" # weather-hail
- "\U000F0F30" # weather-hazy
- "\U000F0898" # weather-hurricane
- "\U000F0593" # weather-lightning
- "\U000F067E" # weather-lightning-rainy
- "\U000F0594" # weather-night
- "\U000F0F31" # weather-night-partly-cloudy
- "\U000F0595" # weather-partly-cloudy
- "\U000F0F32" # weather-partly-lightning
- "\U000F0F33" # weather-partly-rainy
- "\U000F0F34" # weather-partly-snowy
- "\U000F0F35" # weather-partly-snowy-rainy
- "\U000F0596" # weather-pouring
- "\U000F0597" # weather-rainy
- "\U000F0598" # weather-snowy
- "\U000F0F36" # weather-snowy-heavy
- "\U000F067F" # weather-snowy-rainy
- "\U000F0599" # weather-sunny
- "\U000F0F37" # weather-sunny-alert
- "\U000F14E4" # weather-sunny-off
- "\U000F059A" # weather-sunset
- "\U000F059B" # weather-sunset-down
- "\U000F059C" # weather-sunset-up
- "\U000F0F38" # weather-tornado
- "\U000F059D" # weather-windy
- "\U000F059E" # weather-windy-variant
- "\U000F050F" # mdi-thermometer
- "\U000F18D7" # sun-thermometer-outline
- "\U000F0F55" # home-thermometer-outline
- file: 'fonts/GothamRnd-Bold.ttf'
glyphs:
['&', '@', '!', ',', '.', '"', '%', '(', ')', '+', '-', '_', ':', '°', '0',
'1', '2', '3', '4', '5', '6', '7', '8', '9', 'A', 'B', 'C', 'D', 'E',
'F', 'G', 'H', 'I', 'J', 'K', 'L', 'M', 'N', 'O', 'P', 'Q', 'R', 'S',
'T', 'U', 'V', 'W', 'X', 'Y', 'Z', ' ', 'a', 'b', 'c', 'd', 'e', 'f',
'g', 'h', 'i', 'j', 'k', 'l', 'm', 'n', 'o', 'p', 'q', 'r', 's', 't',
'u', 'v', 'w', 'x', 'y', 'z', '/','[', ']',"'"]
glyphs:
# Check whether the display needs to be refreshed every minute,
# based on whether new data is received or motion is detected. (Thanks @paviro!)
time:
- platform: homeassistant
on_time:
- seconds: 0
minutes: /1
then:
- if:
condition:
lambda: 'return id(data_updated) == true;'
then:
- lambda: 'id(initial_data_received) = true;'
- if:
condition:
binary_sensor.is_on: motion_detected
then:
- logger.log: "Sensor data updated and activity in home detected: Refreshing display..."
- lambda: 'id(data_updated) = false;'
else:
- logger.log: "Sensor data updated but no activity in home - skipping display refresh."
- platform: sntp
timezone: Australia/Sydney
servers:
- 0.pool.ntp.org
- 1.pool.ntp.org
- 2.pool.ntp.org
# Check if motion is detected in the bathroom.
binary_sensor:
entity_id: binary_sensor.bathroom_motion_sensor
# Call calender sensors from HA.
text_sensor:
entity_id: sensor.esphome_to_do
on_value:
then:
- lambda: 'id(data_updated) = true;'
entity_id: sensor.epshome_shopping_list
on_value:
then:
entity_id: weather.home
internal: true
entity_id: sensor.outside_temperature_sensor
on_value:
then:
entity_id: sensor.bedroom_temperature
on_value:
then:
# Define colors
# This design is white on black so this is necessary.
color:
- id: color_black
red: 0%
green: 0%
blue: 0%
white: 50%
- id: color_white
red: 0%
green: 0%
blue: 0%
white: 0%
- id: color_red
red: 0%
green: 0%
blue: 0%
white: 0%
# Pins for Waveshare ePaper ESP Board
spi:
clk_pin: GPIO13
mosi_pin: GPIO14
# Now render everything on the ePaper screen.
display:
- platform: waveshare_epaper
cs_pin: GPIO15
dc_pin: GPIO27
busy_pin: GPIO25
reset_pin: GPIO26
reset_duration: 2ms
model: 7.50in-bV2
update_interval: 1h
rotation: 90°
lambda: |-
// Fill background.
// it.fill(color_bg);
// Show loading screen before data is received.
if (id(initial_data_received) == false) {
it.printf(215, 190, id(font_title), color_black, TextAlign::TOP_CENTER, "Just Wait a Second");
it.printf(200, 410, id(font_title), color_black, TextAlign::TOP_CENTER, "It's Still Loading");
} else {
int time = id(ntp).now().hour * 100 + id(ntp).now().minute;
if (id(weather_icon).has_state()) {
std::map<std::string, std::string> weather_state {
{ "sunny", "\U000F0599" }, // mdi:weather-sunny
{ "clear-night", "\U000F0594" }, // mdi:weather-night
{ "cloudy", "\U000F0590"}, // mdi:weather-cloudy
{ "rainy", "\U000F0597" }, // mdi:weather-pouring
{ "windy", "\U000F059D" }, // mdi:weather-windy-variant
{ "fog", "\U000F0591" }, // mdi:weather-fog
{ "partlycloudy", "\U000F0595" }, // mdi:weather-partly-cloudy
if (time < 1900) {
it.printf(20, 90, id(icon_font), TextAlign::BASELINE_LEFT, weather_state[id(weather_icon).state.c_str()].c_str());
} else {
// Outside Temp
it.printf(80, 90, id(icon_font), TextAlign::BASELINE_LEFT, "\U000F18D7");
it.printf(135, 85, id(font_title), color_black, TextAlign::BASELINE_LEFT, "%2.0f°", id(weather_temperature).state);
// Inside Temp
it.printf(240, 90, id(icon_font), TextAlign::BASELINE_LEFT, "\U000F0F55");
it.printf(295, 85, id(font_title), color_black, TextAlign::BASELINE_LEFT, "%2.0f°", id(bedroom_temp).state);
// To Do List
it.printf(20, 150, id(font_title), color_black, TextAlign::BASELINE_LEFT, "To Do List");
it.line(240, 135, 480, 135);
std::string str1 = id(alexa_to_do_list).state;
// Display position and line height
int xPos1 = 20, yPos1 = 190, lineHeight1 = 20;
// Split into lines where comma is delimiter
std::size_t curPos1 = 0, commaPos1 = 0;
while ((commaPos1 = str1.find(',', curPos1)) != std::string::npos) {
it.print(xPos1, yPos1, id(font_small_bold), str1.substr(curPos1, commaPos1 - curPos1).c_str());
yPos1 += lineHeight1;
curPos1 = commaPos1 + 1;
// Shopping List
it.printf(20, 408, id(font_title), color_black, TextAlign::BASELINE_LEFT, "Shopping List");
it.line(320, 395, 480, 395);
std::string str = id(alexa_shopping_list).state;
int xPos = 20, yPos = 430, lineHeight = 20;
std::size_t curPos = 0, commaPos = 0;
while ((commaPos = str.find(',', curPos)) != std::string::npos) {
it.print(xPos, yPos, id(font_small_bold), str.substr(curPos, commaPos - curPos).c_str());
yPos += lineHeight;
curPos = commaPos + 1;
// FOOTER
//Divider draw a line from [x=0,y=0] to [x=50,y=50]
it.line(0, 665, 480, 665);
// Show date and time of last update
it.strftime(230, 700, id(font_small_bold), TextAlign::BASELINE_CENTER, "Updated: %Y-%m-%d %H:%M", id(ntp).now());
captive_portal:
