I’m trying to get a notification when ESPhome restarts, without success.
I have this binary sensor in my ESPHome:
name: "Pond control has restarted"
and this in on_boot
on_boot:
then:
- binary_sensor.template.publish:
state: ON
and in HA I have:
- alias: Pond control has restarted
initial_state: 'on'
- entity_id: binary_sensor.pond_control_has_restarted
platform: state
to: 'ON'
- service: notify.ALL_DEVICES
title: "Koi pond..."
message: "...control has restarted"
- service: binary_sensor.turn_off
Using States in Dev tools to toggle binary_sensor.pond_control_has_restarted
delivers the notification OK.
What am I missing here?
Try it without the from: 'OFF'
in the trigger.
My esphome binary sensors go from ‘unavailable’ to ‘on’ after a restart.
Thank you. I’d already tried that option without success.
Does the rest of it look OK to you.
Troon
(Troon)
June 15, 2020, 7:27am
4
It might be that the on_boot
action is failing because the network isn’t connected at that time. Perhaps add a delay or check for wifi connection ?
Alternatively, set up an uptime sensor and write the HA automation based off that (if the sensor drops below say 300s, send the notification).
Fixed it!
Interestingly, in states, the binary sensor shows as ‘On’ or ‘Off’ with the ESPhome publishing ON (as per the docs ) at boot.
Setting the automation trigger to ‘on’, ‘On’ or ‘ON’ failed to trigger the automation. However, when I set the publish to ‘On’ all works fine.
I’m missing the logic to that though
laca75tn
(My Home)
June 15, 2020, 8:19pm
6
I think that your problem was that you didn’t have the single quotes around ON.
You may well be correct, but the docs don’t call for quotes to be used.
I’ll give it another go with the quotes tomorrow and see what the differences are. It’s alway good to understand these anomalies.
EDIT: I may have mislead you with my post there. I don’t have On in quotes in the publish action, yet it all works fine.
state: On
initial_state: 'on'
platform: state
to: 'On'
laca75tn
(My Home)
June 15, 2020, 8:29pm
8
As far as I understand (don’t quote me on this), Esphome translates the YAML into C/C++ and C/C++ is case sensitive and very picky regarding syntax. Please try it and let us know the results. Thanks
We cross posted there. Please see above.
This is my understanding also.
