ESPHome reuse code
I have several sonoff mini (same version) with esphome running behind light wall switch. they all have same code, I used substitute to change device, sensor etc name. So basically apart from substitute part, all others are same. Can I write the code in one yaml file and call that file in main device file?
For example:
Full code:
substitutions:
  device_name: eh-${location}-sw
esphome:
  platform: ESP8266
  board: esp8285
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
wifi:
  ssid: !secret wifi_ssid_NOT
  password: !secret wifi_password_NOT
  fast_connect: true
  ap:
    ssid: "${device_name}_Hotspot"
captive_portal:
# Enable Web server
web_server:
  port: 80
# Extra sensor to keep track of plug uptime
  - platform: uptime
    filters:
      - lambda: return x / 3600;
    unit_of_measurement: "hours"
    accuracy_decimals: 2
# Extra sensor for WiFi signal
  - platform: wifi_signal
    update_interval: 60s
# Device specific Config Begins Below #
switch:
  - platform: gpio
    pin: GPIO12
    restore_mode: restore_default_on
button:
  - platform: restart
binary_sensor:
  - platform: gpio
    internal: true
    pin: GPIO00
    filters:
      - invert:
      - delayed_off: 10ms
    on_press:
      - switch.toggle:
  - platform: gpio
    pin: GPIO04
    on_press:
      then:
        - switch.toggle:
    on_release:
      then:
        - switch.toggle:
I want maybe like this:
device.yaml
substitutions:
!include esphome_common.yaml
!include sonoff_mini_common.yaml
esphome_common.yaml
esphome:
  platform: ESP8266
  board: esp8285
# Enable logging
logger:
api:
ota:
wifi:
  fast_connect: true
  ap:
captive_portal:
# Enable Web server
web_server:
  port: 80
  - platform: uptime
    filters:
switch:
  - platform: gpio
    pin: GPIO12
button:
  - platform: restart
binary_sensor:
  - platform: gpio
    internal: true
    pin: GPIO00
    filters:
      - invert:
      - delayed_off: 10ms
    on_press:
      - switch.toggle:
  - platform: gpio
    pin: GPIO04
    on_press:
      then:
        - switch.toggle:
    on_release:
      then:
        - switch.toggle:
Yes you can, works just like any program with multiple files you would make. I do this with my ESP32’s with display to maintain fonts/colors/sensor files etc. Make your default common file and then in each device file add something like this towards the top:
<<: !include base.yaml
I keep this right under the esp32: board module section.
