ESPHome RF module capture a 433.92MHz signal?
I would like to capture a 433.92MHz with the ESPHome RF receiver but it mentions that it works with 433MHz.
Does the 0.92Hz effect that it would not be able to receive that signal or does the RF module captures everything from 433.xx?
I don’t have the module yet, just wanted to know this before I buy that module.
The 433 MHz frequency band is an unlicensed frequency band that spans 433.05 MHz to 434.79 MHz. You should be OK as long as the device transmits an unsecured protocol. Like a fan remote, for example.
I use the Sonoff RF Bridge. What is the ESPHome RF Module? (Link please).
It’s the sonoff one that you use.
Ok good to know that it should work.
I think it will be unsecured, it’s a thermostat that send a signal to a panel, so just on and off signal probably.
