I have just upgraded my office RGB lights to the latest esphome firmware and right after the lights started going off for a couple of seconds every few minutes.
ESPHome log shows this:
INFO Reading configuration /config/esphome/rgb-light-office.yaml...
INFO Starting log output from 192.168.1.17 using esphome API
WARNING 192.168.1.17: Connection error occurred: Timeout waiting for response for <class 'api_pb2.ConnectRequest'> after 10.0s
WARNING Can't connect to ESPHome API for 192.168.1.17: Timeout waiting for response for <class 'api_pb2.ConnectRequest'> after 10.0s
INFO Trying to reconnect to 192.168.1.17 in the background
INFO Successfully connected to 192.168.1.17
[08:56:32][I][app:102]: ESPHome version 2023.2.1 compiled on Feb 16 2023, 08:22:53
[09:01:20][I][ota:113]: Boot seems successful, resetting boot loop counter.
File "/usr/local/lib/python3.9/dist-packages/aioesphomeapi/connection.py", line 520, in send_message_await_response_complex
await fut
asyncio.exceptions.CancelledError
await fut
File "/usr/local/lib/python3.9/dist-packages/async_timeout/__init__.py", line 129, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.9/dist-packages/async_timeout/__init__.py", line 212, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
File "/usr/local/lib/python3.9/dist-packages/aioesphomeapi/connection.py", line 303, in _keep_alive_loop
await self._ping()
File "/usr/local/lib/python3.9/dist-packages/aioesphomeapi/connection.py", line 628, in _ping
await self.send_message_await_response(PingRequest(), PingResponse)
File "/usr/local/lib/python3.9/dist-packages/aioesphomeapi/connection.py", line 537, in send_message_await_response
res = await self.send_message_await_response_complex(
File "/usr/local/lib/python3.9/dist-packages/aioesphomeapi/connection.py", line 522, in send_message_await_response_complex
raise TimeoutAPIError(
aioesphomeapi.core.TimeoutAPIError: Timeout waiting for response for <class 'api_pb2.PingRequest'> after 10.0s
INFO Disconnected from ESPHome API for 192.168.1.17
WARNING Disconnected from API
Prior to the upgrade they were working flawlessly.
I have already opened github issue
While I am waiting for some to look at it is there a way to revert the firmware back on on device to previous version without restoring whole ESPHome from backup?
