ESPHome Sensor value after restart
I use ESPHome to create sensor “base” from Linky, the issue is when I restart HA or the ESP the value become unavailable and HA record a crazy value at this moment in the “sensor.energy_total_daily”.
Is there a solution to avoid this issue, by example save the last value when unavailable ?
PS : Impossible to use “restore_mode: RESTORE_LAST_VALUE” in ESPHome for my sensor.
  • utility_meter:
    energy_total_usage_daily:
    source: sensor.linky_base
    cycle: daily
  • platform: template
    sensors:
    energy_total_daily:
    friendly_name: “Energy Consumed Today”
    entity_id:
    - sensor.energy_total_usage_daily
    value_template: ‘{{ (states(’‘sensor.energy_total_usage_daily’’) | float / 1000) | round(3) }}’
    unit_of_measurement: kWh
  • platform: teleinfo
    tag_name: “BASE”
    name: “Linky - Base”
    unit_of_measurement: “Wh”
    teleinfo_id: myteleinfo
Hi
Show your ESPhome code in the preformatted text way </> minus sensitive data like your wifi password and it may stimulate some responses.
substitutions:
friendly_name: “WeMos Teleinfo”
esphome:
esp32:
board: esp32dev
framework:
type: arduino
Enable logging
logger:
Enable Home Assistant API
api:
encryption:
key: “********************************”
ota:
password: “****************************”
wifi:
ssid: !secret wifi_ssid
fast_connect: on
i2c:
sda: GPIO21 #D2=pin 19
scl: GPIO22 #D1=pin 20
scan: True
uart:
rx_pin: GPIO23
#tx_pin: GPIO1
baud_rate: 1200
parity: EVEN
data_bits: 7
teleinfo:
uart_id: uart_a
update_interval: 10s
historical_mode: true
LED
light:
  • platform: partition
    default_transition_length: 0s
    segments:
    • id: rgb_led
      to: 0
  • platform: neopixelbus
    num_leds: 1
    pin: GPIO18
    name: “${friendly_name} RGB strip”
    variant: ws2812
Sensor Configuration
Index option Base
    tag_name: “BASE”
    icon: mdi:flash
Alot of people have been searching for the answer to this using the API. Much easier to fix if you use mqtt instead. In mqtt you just make sure the birth and last will topics are different. The value of sensor doesn’t change until device comes back available and sends a new value.
mqtt:
  birth_message:
    topic: myavailability/topic
    payload: online
  will_message:
    topic: myavailability/anything as long as it's not topic
    payload: offline
I don’t have an answer for using API.
