See the procedure here:
I have downloaded the diagnostics which looks like this:
"home_assistant": {
"installation_type": "Home Assistant Supervised",
"version": "2022.9.0",
"dev": false,
"hassio": true,
"virtualenv": false,
"python_version": "3.10.5",
"docker": true,
"arch": "x86_64",
"timezone": "Europe/Stockholm",
"os_name": "Linux",
"os_version": "5.4.0-125-generic",
"supervisor": "2022.08.6",
"host_os": "Ubuntu 20.04.5 LTS",
"docker_version": "20.10.17",
"chassis": "laptop",
"run_as_root": true
"custom_components": {
"sonoff": {
"version": "v2.4.3",
"requirements": [
"pycryptodome>=3.6.6"
"integration_manifest": {
"domain": "esphome",
"name": "ESPHome",
"config_flow": true,
"documentation": "https://www.home-assistant.io/integrations/esphome",
"requirements": [
"aioesphomeapi==10.13.0"
"zeroconf": [
"_esphomelib._tcp.local."
"dhcp": [
"registered_devices": true
"codeowners": [
"@OttoWinter",
"@jesserockz"
"after_dependencies": [
"bluetooth",
"zeroconf",
"tag"
"iot_class": "local_push",
"loggers": [
"aioesphomeapi",
"noiseprotocol"
"is_built_in": true
"data": {
"config": {
"entry_id": "1d80e984815a4bab9a1427ef6a68d9c6",
"version": 1,
"title": "bikupan",
"data": {
"host": "192.168.1.229",
"password": "**REDACTED**",
"port": 6053
"options": {},
"pref_disable_new_entities": false,
"pref_disable_polling": false,
"source": "zeroconf",
"unique_id": "bikupan",
"disabled_by": null
"storage_data": {
"device_info": {
"compilation_time": "Jun 15 2022, 22:09:00",
"esphome_version": "2022.2.1",
"has_deep_sleep": false,
"mac_address": "**REDACTED**",
"model": "nodemcuv2",
"name": "bikupan",
"uses_password": true
"sensor": [
"accuracy_decimals": 1,
"force_update": false,
"icon": "",
"key": 1248880791,
"name": "Smart Scale Initial Zero",
"object_id": "smart_scale_initial_zero",
"unique_id": "bikupansensorsmart_scale_initial_zero",
"unit_of_measurement": ""
"icon": "",
"key": 3432680542,
"name": "Smart Scale Auto Tare Difference",
"object_id": "smart_scale_auto_tare_difference",
"unique_id": "bikupansensorsmart_scale_auto_tare_difference",
"accuracy_decimals": 2,
"icon": "",
"key": 2862096017,
"name": "Smart Scale HX711 Value",
"object_id": "smart_scale_hx711_value",
"unique_id": "bikupansensorsmart_scale_hx711_value",
"unit_of_measurement": "kg"
"services": [],
"switch": [
"assumed_state": false,
"icon": "",
"key": 1059271594,
"name": "Smart Scale Continuous Tare Enabled",
"object_id": "smart_scale_continuous_tare_enabled",
"unique_id": "bikupanswitchsmart_scale_continuous_tare_enabled"
"icon": "",
"key": 3374029174,
"name": "Smart Scale Manual Tare Action",
"object_id": "smart_scale_manual_tare_action",
"unique_id": "bikupanswitchsmart_scale_manual_tare_action"
"text_sensor": []
It appears that it is looking for the sensor at 192.168.1.229… Which is not the correct IP for the sensor… hm…
