Hi there. I have some ESP Temperature and Humidity Sensors. After initial Problems I now face a Problem I dont get through with.
The Sensors Measure Temperature and Humidity and after this I have a Template Sensor Calculating the Dewpoint.
Every so often ESPHome trys to calculate the Dewpoint before the other Values got in. Then it sends NaN as Value and Homeassistant prints “Non numeric Value”
How can I get past this?
Here the Logoutput when this happens:
[13:12:31][D][sensor:093]: 'WZ_Dew': Sending state -nan °C with 1 decimals of accuracy
[13:12:37][D][dht:048]: Got Temperature=25.6°C Humidity=64.8%
[13:12:37][D][sensor:093]: 'WZ_Temp': Sending state 25.60000 °C with 1 decimals of accuracy
[13:12:37][D][sensor:093]: 'WZ_Humi': Sending state 64.80000 % with 0 decimals of accuracy``
type or paste code here
and my Code:
esphome:
friendly_name: Luftqualitaet Wohnzimmer
esp8266:
board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "/+WycRcYqUeo5A5aUZqYgLqB7If6ogRcR32EIEmO38k="
ota:
password: "0ab4e2c9af038305b048e091f4accea9"
wifi:
ssid: !secret wifi_ssid
fast_connect: true
manual_ip:
static_ip: 192.168.128.12
gateway: 192.168.178.1
subnet: 255.255.128.0
dns1: 192.168.178.1
ap:
ssid: "Air-K Fallback Hotspot"
password: "8acVOYkjEfz2"
captive_portal:
- platform: dht
pin: GPIO2
model: AM2302
temperature:
unit_of_measurement: "°C"
humidity:
unit_of_measurement: "%"
lambda: |-
return (243.5*(log(id(WZ_Humi).state/100)+((17.67*id(WZ_Temp).state)/
(243.5+id(WZ_Temp).state)))/(17.67-log(id(WZ_Humi).state/100)-
((17.67*id(WZ_Temp).state)/(243.5+id(WZ_Temp).state))));
unit_of_measurement: °C
icon: 'mdi:thermometer-alert'
deep_sleep:
run_duration: 60s
sleep_duration: 300s
