ESPhome servo controlled by a potentiometer
Has anyone ever controlled a servo with a potentiometer wired to a D1 mini ?
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
  services:
    - service: boat_servo    # add in config and add a automation
      variables:
        level: float
      then:
        - servo.write:
            level: !lambda 'return level / 100.0;'
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Boat Fallback Hotspot"
captive_portal:
  - platform: adc
    pin: A0
    update_interval: 5s
    filters:
      - multiply: 3.3
# Output platform
output:
  - platform: esp8266_pwm
    pin: D1
    frequency: 50 Hz
# Configuration entry
servo:
  - id: my_servo
    output: pwm_output
How can I take the number from the Pot and position the servo?
  - platform: adc
    pin: A0
    update_interval: 5s
    on_value:
      then:
        - servo.write:
            # For template values, range is [-1; 1]
            level: !lambda { return (x - 0.5) * 2 }
            # Converting [0;1] range of ADC to [-1;1]
# Output platform
output:
    pin: D1
    frequency: 50 Hz
servo:
  - id: my_servo
    output: pwm_output
That looks like it will work perfect. I’m getting a few errors compiling though.
/config/esphome/boat.yaml:57:24: warning: character constant too long for its type
   57 |             level: !lambda { return (x - 0.5) * 2 }
/config/esphome/boat.yaml:57:55: warning: character constant too long for its type
/config/esphome/boat.yaml:57:95: warning: character constant too long for its type
/config/esphome/boat.yaml:57:127: error: empty character constant
/config/esphome/boat.yaml: In lambda function:
/config/esphome/boat.yaml:57:8: error: expected identifier before '(' token
/config/esphome/boat.yaml:58:3: error: expected '{' before '}' token
   58 |             # Converting [0;1] range of ADC to [-1;1]
/config/esphome/boat.yaml:57:132: error: expected ';' before '}' token
/config/esphome/boat.yaml:58:3: error: no return statement in function returning non-void [-Werror=return-type]
cc1plus: some warnings being treated as errors
*** [/data/boat/.pioenvs/boat/src/main.cpp.o] Error 1
========================== [FAILED] Took 4.55 seconds ==========================
Solution
level: !lambda 'return (x - 0.5) * 2;'
Thank you Daryl
Good to see you got it working. Sorry - I always forget the quotes… :grinning:
