I have an Ultrasonic sensor for measuring the quantity of heating oil in a tank.
Update time is 1h but for deliveries, I’d like to be able to change to 1 second it from Home Assistant when the delivery is taking place and then revert back when the delivery is complete.
Have an input_boolean in Home Assistant that controls the update_interval would be the way to go.
Is this possible? If so, where do I start?
My sensor is set up thus:
- platform: ultrasonic
trigger_pin: D1
echo_pin: D2
timeout: 1.5m
name: "Oil level in litres"
accuracy_decimals: 0
update_interval: 1h
filters:
- sliding_window_moving_average:
window_size: 15
send_every: 15
- lambda: return (1.25-x)*100*44;
on_value_range:
above: 1.08 # 750 litres
below: 0.9 # 1500 litres
then:
- switch.turn_on: oil_re_order
