I’m struggling with something and I’m hopping someone here came across similar problem.
I have a M4Atom Lite box and I want to use the built-in led to reflect the status of an automation.
here is the relevant bit of my esphome config:
binary_sensor:
- platform: homeassistant
entity_id: automation.workshop_alarm
internal: true
on_state:
then:
- if:
condition:
binary_sensor.is_on: workshop_alarm
then:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
else:
- light.turn_on:
red: 0%
green: 100%
blue: 0%
light:
- platform: fastled_clockless
pin: GPIO27
chipset: SK6812
num_leds: 1
rgb_order: grb
restore_mode: ALWAYS_ON
on_turn_on:
then:
- light.turn_on:
red: 100%
green: 0%
blue: 0%
Right now when I switch on the device the LED will turn red, then I have to manually toggle the automation and after that everything works as I want it to.
what I want to achieve is that when the device is switched on the light should turn either red or green depending if one of my automatons is on or off.
Is that possible?
