Anyone know if the Shelly Pro 1PM is supported ? The Shelly Pro 1 is but i can’t find any information about the 1PM.
Thank you
Thank you
Is there any reason you want to use ESPHome on the Shelly 1 PM?
It works exceptionally well locally with the HA Shelly integration.
Yes;
1/ I don’t use HA. I use a custom interface in React and some piece of Python.
2/ I don’t want to have a device i don’t don’t fully control with mqtt access
But i love esphome, it make complex automations very simple !
By the way i have directly ask shelly cloud if the Pro 1PM is esp32 based, I wait for an answer. i will keep you inform
Yes, AFAIK all shellys will work with esphome.
I use a lot of them with esphome.
Another reason for me is to add “extra options” and extra actions in the device I could not do with the native firmware.
Shelly.cloud answer me and confirm it’s ESP based. So i have ordered one to investigate.
It’s esp based with the same chip as the Shelly Pro 1, and most of the board look like the same.
I taked pictures of the pcb and post them on this github: https://github.com/nduhamel/shelly-pro-1PM-esphome.
Now i have to figure out how the ADE7953 power meter component is connected.
But i don’t now where to start.
If anyone could help me ?
I was going to ask why you are on the Home Assistant Forum then but…
I guess we do that now too. So fair enough.
Download the datasheet and start tracing pins back to the ESP module https://www.analog.com/en/products/ade7953.html
Pins 22 (IRQ), 26 (SDA) and 27 (SCL) of the ADE7953 are the only ones you have to trace to the ESP GPIOs.
Hi Nicolas,
may I kindly ask you to keep us updated on your progress?
I have a project in my mind where I’d like to use a SHELLY PRO 1 PM with ESPHOME so I’m very interested in your results!
Thanks in advance and continuous good luck
I would start with this:
I will dig this. Thanks.
Of course, i will share all my progress.
Thank you, i already contact the guy behind the Shelly Pro 1 support. He is working on the Shelly Pro 1PM too.
By the way, i also directly contacted shelly support, who knows maybe they will simply share the pinout with us.
Hi
I’m currently trying to setup my Shelly Pro 1PM with esphome. My “usual” way (as done with Shelly Plug S) does not seem to work.
Did you make any further progress with this? Or are “we” currently stuck with the stock firmware?
Any update would be appreciated !
have a nice day,
Cheers!
I recently bought a Shelly Pro 1PM, any updates to use energy monitoring with esphome ?
I’m currently using Tasmota for having energy monitoring and ready to migrate to esphome. So I hope the ADE7953 chip on SPI will be implemented soon.
Cheers
Helloooo!
Is there any progress on this?
I’ve got a Shelly that I would like to flash with ESPHome.
Hello @all,
I have some progress here with a “Shelly pro 1PM” just bought. The device works well. I mixed up the things known from the esphome “Shelly pro 1/2” and the tasmota support for “Shelly pro 1PM”. My esphome version used: 2024.12.4
What is missing/known issues:
Here is my config:
esphome:
friendly_name: shelly 1 pro pm Test
on_boot:
- priority: 700
then:
- switch.turn_off: ade7953_reset
- delay: 2ms
- switch.turn_on: ade7953_reset
esp32:
board: esp32dev
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxxxx"
ota:
- platform: esphome
password: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "Shelly-1-Pro-Pm-Test Hotspot"
password: "1234567890987654321"
captive_portal:
web_server:
port: 80
#ethernet: STILL TO BE DEFINED
# type: LAN8720
# mdc_pin: GPIO23
# mdio_pin: GPIO18
# clk_mode: GPIO17_OUT
button:
- platform: restart
binary_sensor:
- platform: status
on_press:
then:
switch.turn_off: rgb_b
on_release:
then:
switch.turn_on: rgb_b
- platform: gpio
pin:
number: 35
inverted: true
on_click:
- min_length: 3s
max_length: 6s
then:
- button.press: restart_1
- min_length: 200ms
max_length: 500ms
then:
- switch.toggle: light1
- platform: gpio
pin:
number: 38
on_press:
then:
- platform: gpio
pin:
number: 39
sn74hc595:
- id: 'sn74hc595_hub'
type: spi
latch_pin: GPIO4
sr_count: 1
switch:
- platform: gpio
internal: True
pin: 2
- platform: gpio
pin:
sn74hc595: sn74hc595_hub
number: 0
inverted: false
# - platform: gpio
# id: out2
# pin:
# sn74hc595: sn74hc595_hub
# number: 1
# inverted: false
- platform: gpio
pin:
number: 2
inverted: True
- platform: gpio
pin:
number: 3
inverted: True
- platform: gpio
pin:
number: 4
inverted: True
spi:
clk_pin: GPIO14
mosi_pin: GPIO13
miso_pin: GPIO12
# Example configuration entry for SPI
- platform: ade7953_spi
cs_pin: GPIO00
irq_pin: GPIO32
update_interval: 20s
voltage:
filters:
- clamp:
max_value: 500
ignore_out_of_range: true
frequency:
filters:
- clamp:
min_value: 45
max_value: 65
current_a:
power_factor_a:
name: "Power Faktor A"
apparent_power_a:
name: "Apparent Power A"
active_power_a:
reactive_power_a:
name: "Reactive Power A"
# current_b:
# name: "Current B"
# power_factor_b:
# name: "ADE7953 Power Factor B"
# apparent_power_b:
# name: "Apparent Power B"
# active_power_b:
# name: "Power B"
# reactive_power_b:
# name: "Reactive Power B"
voltage_gain: 4128372
current_pga_gain_a: 4x
current_gain_a: 3179758
active_power_gain_a: 4174540
current_pga_gain_b: 4x
current_gain_b: 3179758
active_power_gain_b: 4174540
# NTC Temperature
- platform: ntc
sensor: temp_resistance_reading
name: "Gerät Temperatur"
calibration:
b_constant: 3350
reference_resistance: 10kOhm
reference_temperature: 298.15K
- platform: resistance
sensor: temp_analog_reading
configuration: DOWNSTREAM
resistor: 15kOhm
- platform: adc
update_interval: 60s
attenuation: 12db
pin: 36
