hello,
well i’ll have a issue…
i have a OLED display SSD1306 connected to my ESP32 to show Temp /humid from the bmp280.
have also a 4 x relay for light and a PWM channel for LED light dimming…
all works well and i’ll can display the states of the relay and all other info on my display…
the last info i’ll need is the PWM or lets say the light brightness value
i’ll have done some different constellations… but could not find any info on the web how to get that value on my oled…
here is my code:
- platform: homeassistant
entity_id: light.grow1_light
internal: true
name: "${device_name} brightness"
internal: true
update_interval: 25ms
# Ensure on_value only triggered when brightness (0-255) changes
filters:
delta: 0.8
# Read brightness (0 - 1) from light , convert to (0-255) for MCU
lambda: |-
if (id(light_main).remote_values.is_on()) {
return (int(id(light_main).remote_values.get_brightness() * 255));
else {
return 0;
# On Change send to MCU via UART
on_value:
then:
- logger.log:
level: INFO
format: "Sensor Value Change sent to UART %3.1f"
args: ["id(sensor_g_bright).state"]
text_sensor:
internal: true
display:
- platform: ssd1306_i2c
i2c_id: bus_b
model: "SSD1306 128x32"
#reset_pin: D0
address: 0x3D
update_interval: 5s
lambda: |-
// Print time in HH:MM format
//it.strftime(0, 6, id(font7), TextAlign::BASELINE_LEFT, "GROW1: %H:%M", id(esptime).now());
it.printf(0, 6, id(font3), TextAlign::BASELINE_LEFT, "LED: %s", id(grow1_led).state ? "ON" : "OFF");
it.printf(0, 12, id(font3), TextAlign::BASELINE_LEFT, "PWM: %.1%%", id(sensor_g_bright).state);
it.printf(0, 18, id(font3), TextAlign::BASELINE_LEFT, "UV: %s", id(grow1_uv).state ? "ON" : "OFF");
it.printf(0, 24, id(font3), TextAlign::BASELINE_LEFT, "IR: %s", id(grow1_ir).state ? "ON" : "OFF");
it.printf(0, 30, id(font3), TextAlign::BASELINE_LEFT, "VEN: %s", id(grow1_vent).state ? "ON" : "OFF");
// Print outside temperature (from homeassistant sensor)
if (id(grow1_temp).state == id(grow1_temp).state) {
it.printf(127, 10, id(font1), TextAlign::BASELINE_RIGHT , "%.1f °C", id(grow1_temp).state);
} else {
it.print(127, 10, id(font3), TextAlign::BASELINE_RIGHT , "...waiting...");
// Print outside humidity (from homeassistant sensor)
if (id(grow1_hum).state == id(grow1_hum).state) {
it.printf(127, 23, id(font1), TextAlign::BASELINE_RIGHT , "%.0f %%", id(grow1_hum).state);
} else {
it.print(127, 23, id(font3), TextAlign::BASELINE_RIGHT , "...waiting...");
// Print outside pressure (from homeassistant sensor)
if (id(wifi_sig).state == id(wifi_sig).state) {
it.printf(127, 30, id(font3), TextAlign::BASELINE_RIGHT , "%.0f", id(wifi_sig).state);
} else {
it.print(127, 30, id(font3), TextAlign::BASELINE_RIGHT , "...waiting...");
font:
- id: font1
file: "fonts/open-sans/OpenSans-Semibold.ttf"
- file: 'fonts/slkscr.ttf'
- file: "fonts/open-sans/OpenSans-Semibold.ttf"
- file: 'fonts/Saira-Bold.ttf'
binary_sensor:
- platform: status
switch:
- platform: restart
- platform: gpio
inverted: true
pin: 25
restore_mode: RESTORE_DEFAULT_OFF
interlock_wait_time: 0ms
- platform: gpio
inverted: true
pin: 26
- platform: gpio
inverted: true
pin: 27
- platform: gpio
inverted: true
pin: 14
# Example configuration entry
output:
- platform: ledc
pin: 19
frequency: 5000
# Example usage in a light
light:
- platform: monochromatic
output: ledc_pmw
