Hey
I have build a simple weather station with a Nodemcu esp32s board running esphome and with a AM2301 temp & humidity sensor.
In the moment the code are setup to send sensor data to home assistant and after send the state data back to nodemcu esp32s for to print it to the lcd display.
I would like to skip the home assistant step and directly let nodemcu esp32s send the temp & humidity sensor data to the display locally.
How could the code look out ?
I post here my code as it is in the moment then its stille are running together with home assistant.
# | Sensorer |
- platform: dht
pin: 27
model: dht22
temperature:
humidity:
name: "SenseNode Humidity"
update_interval: 25s
display:
- platform: lcd_pcf8574
dimensions: 20x4
address: 0x27
lambda: |-
// Print office temperature (from homeassistant sensor)
it.print(0, 0, "VEJRSTATION:"); it.print(0, 1, "Temp:"); it.print(0, 2, "Humidity:");
if (id(sensenode_temp_2).state == id(sensenode_temp_2).state)
it.printf(5, 1,"%.1fC", id(sensenode_temp_2).state);
if (id(sensenode_humidity_2).state == id(sensenode_humidity_2).state) {
it.printf(9, 2,"%.1f%%\n", id(sensenode_humidity_2).state);
it.printf(0, 3,"", id(my_time));
it.strftime(0, 3, "%H:%M:%S %d.%m.%Y", id(my_time).now());
} else {
it.print(4, 3, "Loading Wait!");
# Home assistant Sensor
- platform: homeassistant
entity_id: sensor.sensenode_temp_2
internal: true
entity_id: sensor.sensenode_humidity_2
internal: true
Best regards slindberg
