Esphome smart plug showing wrong consumption under energy tab
After last upate my esphome smart plug is showing wrong consumption under energy tab:
energy tab showing as 3,03
in reality it’s just a little over 0,3KWh.
Is there anything I can do to fix this? thank you
You didn’t say whether you updated HA or ESPHome or both. Normally I would recommend to check the changelog and look for breaking changes or any other changes that may impact the way you calculate the daily consumption.
Are you sure that the sensor in the energy tab is exactly the same as in the UI screenshot? In the energy tab you can click on the bar to see the standard pop-up window for the sensor and from there you can see the entity id.
updated both + the device itself. No breaking changes and total consumption still works fine, its just displayed wrong on the energy tab. Yes its the same sensor, will try downgrading my HA installation and see if that helps.
