petizzz
(petizzz)
November 15, 2022, 10:03pm
1
Hi!
I have a school project, where I would like to do an automated Irrigation system.
I have an esp8266 mini D1 pro, a capacitive moisture sensor v1.2, and a basic 5V water pump with a MOSFET.
My previous project was this but in Arduino now I have to implement it in ESPhome.
My Arduino code:
void loop()
soil_moisture_value = analogRead(sensor);
soil_moisture_percent = map(soil_moisture_value, 720, 410, 0, 100);
Serial.print("Sensor_value: ");
Serial.println(soil_moisture_value);
Serial.print("Percentage: ");
Serial.print(soil_moisture_percent);
Serial.println("%");
if(soil_moisture_percent >5 && soil_moisture_percent < 100)
//Irrigation
if(soil_moisture_percent < 30){
Serial.println("Start irrigation...");
digitalWrite(D7, HIGH);
Serial.print("Irrigating for ");
Serial.print(irrigation_time);
Serial.println(" seconds");
delay(irrigation_time*1000);
digitalWrite(D7, LOW);
Serial.println("Stop irrigation...");
I connected the pump with the MOSFET so if the MOSFET Gate gets a high voltage the pump starts. (D7 pin).
I would like to do the same in HomeAssistant.
I have already made the code for the sensor and a switch, but I don’t know how to put voltage on the D7 pin if the required percentages meet. Plus I would like to start the pump manually.
ESPHome code:
- platform: adc
pin: A0
name: "Soil Moisture"
update_interval: 10s
unit_of_measurement: "%"
filters:
- median:
window_size: 7
send_every: 4
send_first_at: 1
- calibrate_linear:
- 0.396 -> 100.00
- 0.729 -> 0.00
- lambda: if (x < 1) return 0; else if (x > 100) return 100; else return (x);
accuracy_decimals: 0
switch:
- platform: gpio
pin: GPIO13
I’m not really good at coding. Can someone help me with how to do it? I’m working on the project too if I make any progress I will update the thread.
Sorry for my bad English.
I think you need an on_value_range automation on your soil moisture sensor.
@petizzz , did you manage the sensor coding i.a.w. with the pump? I would be interested in your final project due to I’ve the same setting as you.
R7BNB
December 12, 2023, 8:43pm
4
I made something similar, still in the testing phase but so far it works well.
Maybe you can use it for your project as well!
esphome:
platform: ESP8266
board: esp01_1m
# WiFi connection, correct these
# with values for your WiFi.
wifi:
ssid: !secret wifi_ssid
ap: {}
# Enable logging.
logger:
# Enable Home Assistant API.
api:
# Enable over-the-air updates.
ota:
# Enable Web server.
web_server:
port: 80
# Sync time with Home Assistant.
time:
- platform: homeassistant
# Text sensors with general information.
text_sensor:
# Expose ESPHome version as sensor.
- platform: version
name: PlantAssistant ESPHome Version
# Expose WiFi information as sensors.
- platform: wifi_info
ip_address:
ssid:
bssid:
# Sensors with general information.
# Uptime sensor.
- platform: uptime
# WiFi Signal sensor.
- platform: wifi_signal
name: PlantAssistant WiFi Signal
update_interval: 60s
# moisture sensor
- platform: adc
pin: A0
update_interval: 1s
icon: "mdi:sprout-outline"
unit_of_measurement: "v"
filters:
- multiply: 3.3
update_interval: 1s
lambda: return id(moisture_sensor_voltage_internal).state;
filters:
- calibrate_linear:
- 0.93 -> 100.00
- 1.63 -> 0.00
- clamp:
min_value: 0
max_value: 100
on_value_range:
# Only turn on the pump when watering is enabled.
- below: 10
then:
- if:
condition:
- switch.is_on: watering_enabled
then:
- switch.turn_on: pump
- above: 90
then:
- switch.turn_off: pump
name: "Soil moisture percentage"
update_interval: 10min
lambda: return id(moisture_sensor_percentage_internal).state;
name: "Soil Moisture voltage"
# Global to store the on/off state of the pump
globals:
- id: pump_state
type: bool
restore_value: true
initial_value: 'true'
# Exposed switches.
switch:
# Switch to restart.
- platform: restart
# Switch to turn on/off the automatic watering.
- platform: gpio
pin: GPIO14
# Switch to turn on/off watering automation
# It creates a "virtual" switch based
# on a global variable.
name: PlantAssistant watering enabled
restore_mode: RESTORE_DEFAULT_ON
turn_on_action:
- globals.set:
value: 'true'
turn_off_action:
- globals.set:
value: 'false'
lambda: |-
return id(pump_state);
