I have an issue where my ESPHome node is occasionally (eg one time out of nine maybe) not responding to button presses. The device is connected to the LAN and powered by ethernet rather than wifi and is connected to a Home Assistant instance via the API. Would really appreciate some tips on what might be causing this? I’d be surprised if it was the mechanical buttons themselves but open to any suggestions. Thank you!
I guess I’m wondering if it’s the code - or the API?
What’s super weird is that if I send an MQTT command while the device seemingly isn’t responding to the button presses, it responds.
esphome:
platform: ESP32
board: esp32-poe
mqtt:
broker: 192.168.2.30
client_id: TL
topic_prefix: T
will_message:
topic: craffid/avail
payload: offline
on_message:
- topic: craffid/green/on
then:
- switch.turn_on: relay1
- switch.turn_on: gindicator
- topic: craffid/green/off
then:
- switch.turn_off: relay1
- switch.turn_off: gindicator
- topic: craffid/red/on
then:
- switch.turn_on: relay2
- switch.turn_on: rindicator
- topic: craffid/red/off
then:
- switch.turn_off: relay2
- switch.turn_off: rindicator
#captive_portal:
# Enable logging
logger:
# Enable Home Assistant API
api:
password: "x"
ota:
password: "x"
ethernet:
type: LAN8720
mdc_pin: GPIO23
mdio_pin: GPIO18
clk_mode: GPIO17_OUT
phy_addr: 0
power_pin: GPIO12
switch:
- platform: gpio
pin: 13
interlock: [relay2]
- platform: gpio
pin: 15
interlock: [relay1]
- platform: gpio
pin: 14
- platform: gpio
name: "Green Indicator"
pin: 3
interlock: [rindicator]
- platform: gpio
name: "Red Indicator"
pin: 2
interlock: [gindicator]
binary_sensor:
- platform: gpio
pin:
number: 39
mode: INPUT_PULLUP
inverted: True
on_press:
then:
- switch.turn_on: buzzer
on_release:
then:
- switch.turn_off: buzzer
- platform: gpio
pin:
number: 36
mode: INPUT_PULLUP
inverted: True
on_press:
then:
- platform: gpio
pin:
number: 34
mode: INPUT_PULLUP
inverted: True
on_press:
