Ok,
so I thought I would add a quick post, to possibly help someone trying to create a 2 way (i.e 2 switches 1 light ) (or 3 way) depending on which side of the pond you are, using Sonoff T1’s and EspHome . I did ask the question in this thread here and I got a great answer from @Petrica on using home assistant to automate the 2 way switch .
Through a little trial and error I managed to incorporate this automation in the Sonoff configs and utilise the homeassitant service call to do the switching for me.
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: '*************'
password: '*************'
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
name: "Sonoff Hallway Touchpad 1"
on_press:
- switch.toggle: relay_1
- platform: gpio
pin:
number: GPIO9
mode: INPUT_PULLUP
inverted: True
name: "Sonoff Hallway Touchpad 2"
on_press:
then:
- homeassistant.service:
service: switch.toggle
data: {"entity_id": "switch.sonoff_landing_relay"}
- platform: status
name: "Sonoff Hallway Status"
switch:
- platform: gpio
name: "Sonoff Hallway Relay 1"
pin: GPIO12
- platform: gpio
name: "Sonoff Hallway Relay 2"
pin: GPIO5
output:
# Register the blue LED as a dimmable output ....
- platform: esp8266_pwm
pin: GPIO13
inverted: True
light:
# ... and then make a light out of it.
- platform: monochromatic
name: "Sonoff Hallway Blue LED"
output: blue_led
internal: true
this uses the second gang touchpad of the 2 gang switch in the hallway to utilise the homeassistant service call and toggle the landing light relay.
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: '****************'
password: '***************'
# Enable logging
logger:
api:
ota:
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
name: "Sonoff Landing Touchpad"
on_press:
- platform: status
name: "Sonoff Landing State"
- platform: gpio
pin:
number: GPIO12
name: "Sonoff Automation toggle"
on_state:
then:
data: {"entity_id": "switch.sonoff_hallway_relay_2"}
switch:
- platform: gpio
name: "Sonoff Landing Relay"
pin: GPIO12
output:
pin: GPIO13
inverted: True
light:
name: "Sonoff Landing Blue LED"
output: blue_led
internal: true
this then uses the state change of the gpio that the relay on landing uses and toggles the switch in the hallway this is essential so that they are both in sync.
I hope this helps someone
@Ottowinter I don’t know if this is something that you would add to your site if you find it useful .
