At the moment i own a Sonoff dual running ESPeasy using some extra plug-in because of the serial chip on this (older) version .
The Sonoff uses this plugin : ESPeasy forum
When i have a look at the ESPhome website it tells me that i must use the GPIO ports, but is there a way to talk/ use the serial port on this Sonoff dual together with ESPhome ?
googled around, and found this : Github
, so i tried this , what makes my config :
esphome:
platform: ESP8266
board: esp01_1m
wifi:
ssid: "xx"
password: "xxxx"
fast_connect: true
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
uart:
tx_pin: GPIO01
rx_pin: GPIO03
baud_rate: 19200
switch:
- platform: uart
data: [0xA0, 0x04, 0x00, 0xA1]
- platform: uart
data: [0xA0, 0x04, 0x01, 0xA1]
- platform: uart
data: [0xA0, 0x04, 0x02, 0xA1]
- platform: uart
data: [0xA0, 0x04, 0x03, 0xA1]
turn_on_action:
if:
condition:
switch.is_off: relay2
then:
- switch.turn_on: relay_1_on
else:
- switch.turn_on: relay_12_on
turn_off_action:
if:
condition:
then:
- switch.turn_on: relay_12_off
else:
- switch.turn_on: relay_2_on
optimistic: true
turn_on_action:
if:
condition:
switch.is_off: relay1
then:
else:
turn_off_action:
if:
condition:
then:
else:
optimistic: true
status_led:
pin:
number: GPIO13
inverted: yes
# Example configuration entry
web_server:
port: 80
Flash this tomorrow and hope solves this
