ESPHome Sprinkler Controller Component + Internal Scheduler
Super easy for someone with exprirence. This is my first aproach to ESPHome and ESP at all.
Im using ESPHome Sprinkler Controller Component and I want to add the start time internally to the ESP.
My current code is:
esphome:
esp8266:
  board: esp12f
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "qbiw79EQD/J3mq7dqj90vrXz7EVt88w4c1EKEY6gGhA="
ota:
  password: "713b41379d7e7a8716ec6867124a1bb8"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Sprinkler-Controller"
    password: "nsMf1LkjvyvT"
captive_portal:
sprinkler:
  - id: sc_controlador
    main_switch: "sc_interruptor_general"
    auto_advance_switch: "sc_avance_automatico"
    valve_overlap: 2s
    valves:
      - valve_switch: "Zona 1"
        enable_switch: "sc_Enable Zona 1"
        run_duration: 900s
        valve_switch_id: sc_relay_1
      - valve_switch: "Zona 2"
        enable_switch: "sc_Enable Zona 2"
        run_duration: 900s
        valve_switch_id: sc_relay_2
      - valve_switch: "Zona 3"
        enable_switch: "sc_Enable Zona 3"
        run_duration: 900s
        valve_switch_id: sc_relay_3
      - valve_switch: "Zona 4"
        enable_switch: "sc_Enable Zona 4"
        run_duration: 900s
        valve_switch_id: sc_relay_4
      - valve_switch: "Zona 5"
        enable_switch: "sc_Enable Zona 5"
        run_duration: 900s
        valve_switch_id: sc_relay_5
      - valve_switch: "Zona 6"
        enable_switch: "sc_Enable Zona 6"
        run_duration: 900s
        valve_switch_id: sc_relay_6
switch:
  - platform: gpio
    pin: GPIO16
    inverted: True
  - platform: gpio
    pin: GPIO14
    inverted: True
  - platform: gpio
    pin: GPIO12
  - platform: gpio
    pin: GPIO13
  - platform: gpio
    pin: GPIO15
  - platform: gpio
    pin: GPIO00
  - platform: gpio
    pin: GPIO04
  - platform: gpio
    pin: GPIO05
and I have an input_datetime.start_time_sprinkler helper in HA.
I’m sure this help will be a starter point to me to actually undestand how ESPHome works.
Thanks!!!
