ESPHOME ST7789v modifications to use a 240x320 pixel screen?
i have a 240x320 pixel IPS screen and when i use the example in EspHome, my image just use the hardcode 135x240 pixel like the TTgo screen.
Is there a way to specify the size of the screen in Esphome, platform st7789v please?
i see TFT_HEIGHT and TFT_WIDTH but i dont know if i can and how can i use it?
Same problem here but even worst it shows like the bellow.
There already exists an ESPHome issue for this:
You could add your findings there. That will also help to not let it auto close.
I have no idea how the st7789v works. But in the code of esphome (st7789v.cpp) there are some hardcoded offsets. (method “write_display_data” line 137 - 140) and the “get_width_internal” and “get_height_internal” return hardcoded resolution values.
If I were in your situation I would play around with those values.
You could try:
  uint16_t x1 = 0;   // _offsetx
  uint16_t x2 = 239;  // _offsetx
  uint16_t y1 = 0;   // _offsety
  uint16_t y2 = 321;  // _offsety
int ST7789V::get_height_internal() {
  return 320;
int ST7789V::get_width_internal() {
  return 240;
Tried it but did not seem to work
Does it still log the wrong resolution in the log output even with those changes?
Yes the same wrong resolution.
But i believe i am changing it in the wrong place. I have the addon of esphome (docker installation)
And i made the change under \config\esphome\project name
Yes very likely it got overwriten when you rebuild the firmware (if you open the file again it will be the original file again).
I don’t know where the esphome addon stores its source code. Normaly you are not supposed to edit that. But for a quick test to see if that fixes the issue (then you can provide that info into the issue in github and some dev may fix it) I think it is OK.
Grab the ST7789v source code from Github (see below), and copy it to a folder beneath Home Assistant’s esphome directory named custom_components/st7789v/. Then edit the CPP and H source files there; they will be used to compile, and they will not be overwritten.
https://esphome.io/api/dir_b2210092d2d495a0f63f571914756838.html
You should probably also get the files
__init__.py
display.py
from here:
and place them in the same folder.
Hi, Somebody found a solution ?
i give up month ago, because i have made what @FredTheFrog tell to do at first but without any luck…post here after to ask…nothing more found about those screens…
i just stay on my ILI9341 320x240 3.2", its cheap and reliable.
