I use HA with a couple of ESP32s running ESPHome in the greenhouse to monitor temperature and open vents/fans.
Just recently the ESPHome Addon has stopped working but the ESP32s are still working and temperature readings are coming in to home Assistant as normal. If I click on the sidebar it says ‘This addon is not running, would you like to start it?’. If I say ‘Yes’ I get ‘Error starting the addon’.
IF I try to uninstall the ESPHome addon I get this:
I have tried manually pulling the image as advised in another post but that doesn’t work either:
Should I try to delete the file that the error message says already exists to allow the new version to be created?
Anyone suggestions?
THanks
