ESPHome Storing Stepper position on Flash
Hi, I have a UL2003 driver and a 28BYJ-48 stepper motor which I’m using to operate the tilt on my blinds with a 8266 D1 mini. I have created a custom 3D print and spindle for my unique blinds.
I can successfully automate the opening and closure of the blinds (tilt) with ESPHome. However, I’m struggling to store the motor position to flash, as the position resets to 0 when rebooted or flash a firmware update. I tried using node-red in HA, and can get the position and reset it with in ‘inject’ feature, but I want to do this on boot of the 8266 D1 Mini.
Any help or advice appreciated or any example code?
This is my ESPHome config:
#Setting up ESPHomme
esphome:
  platform: ESP8266
  board: d1_mini
  esp8266_restore_from_flash: True
  on_boot:
    - priority: -200.0 #is this right priority?
      then:
      - stepper.report_position: #restore
          position: !lambda return id(stepper_position);
      - stepper.set_target:
          target: !lambda return id(stepper_position);
#Define a global variable that can be restored from Flash
globals:
  - id: stepper_position
    type: int
    restore_value: true
#Defined values to make cloning of this easier
substitutions:
  stepperid: stepper3
  blindname: "Blind 3"
  blindid: blind3
api:
  services:
    - service: control_blind #HA service to control blind
      variables:
        target: int
      then:
            target: !lambda 'return target;'
        - sensor.template.publish:
            state: !lambda 'return target;'
    - service: reset_blind #HA service to reset the position
      variables:
        target: int
      then:
            position: !lambda 'return target;'
cover:
    device_class: blind
    open_action: #Just an example to open the blind by increasing steps by 100
          target: !lambda return id($stepperid).current_position+100;
          state: !lambda return id($stepperid).target_position;
    close_action: #Just an example to close the blind by decreasing steps by 100
          target: !lambda return id($stepperid).current_position-100;
    stop_action: #Stop any movement
          target: !lambda return id($stepperid).current_position;
            state: !lambda return id($stepperid).current_position;
    position_action:
     - globals.set: # Set global variable to current position
          value: !lambda return id($stepperid).current_position;
    optimistic: true
    assumed_state: true
    name: "$blindname Position"
#  - platform: homeassistant #this is a HA input_number helper as experiemented using HA to store the stepper. Not used in this script
#    id: current_ha_position
#    name: "$blindname HA Position"
#    entity_id: input_number.blind3_position
stepper:
  - platform: uln2003
    pin_a: D1
    pin_b: D2
    pin_c: D3
    pin_d: D4
    max_speed: 250 steps/s
    sleep_when_done: true #Puts the stepper to sleep to reduce power consumption and heat
    acceleration: inf
    deceleration: inf
binary_sensor:
  - platform: gpio
    pin:
      number: D6 #Physical push button to rotate the blind manually by 100 steps
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      then:
            target: !lambda return id($stepperid).current_position +100;
        - logger.log: "CW Button Pressed"
    on_double_click: #Double click will move 1100 steps
      then:
            target: !lambda return 1100;
    on_release:
      then:
  - platform: gpio
    pin:
      number: D5 #Physical push button to rotate the blind manually by -100 steps
      mode: INPUT_PULLUP
      inverted: True
    on_press:
      then:
            target: !lambda return id($stepperid).current_position -100;
        - logger.log: "CCW Button press"
    on_double_click: #Double click will move -1100 steps
      then:
            target: !lambda return -1100;
    on_release:
      then:
#Board configuration
wifi:
  ssid: !secret wifissid
  password: !secret wifipass
web_server:
  port: 80
logger:
ota:
  password: !secret blind3_otapass
hi pj
Have you found a solution?
I’m looking for the same .
Thanks in advance
